Hello! I'm using a standard photoresistor template in Arduino's Examples.
The output (when just printing each argument without sprintf) is:
30984,255,1023.00,5.00
Time (ms), LightLevel (255 is good), Bytes (1023 is good), Voltage (5 volts)
With sprintf, and despite changing buffer sizes, or moving pieces of code around, I get the output full of errors (also notice time becomes negative):
32573, 0, <----- it seems to insert a 0, and I not print the dtostrf variables
-32444, 0,
-31405, 0, ÄÑÎ, 1023.00 <----- or gibberish
Here is my code:
#include <SPI.h>
#include <SD.h>
//Definitions
uint32_t timeStamp = 0;
const int sensorPin = 0;
const int ledPin = 9; // DO NOT USE PIN 10
//SPRINTF STUFF
char buffer1[100];
char bytesStr[10];
char voltsStr[10];
int lightLevel, high = 0, low = 1023;
float voltBytes = 4.01176471; //lightlevel (0–255) * this = 0–1023 resolution
float milliVolt = 0.00488759; //5v÷1023 resolution
String header1 = ("Begin string Test");
String header2 = ("Time,LightLevel,Bytes,Voltage");
const int chipSelect = 4; //SD card write
//SD Card
File dataFile; //name of file object
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
pinMode(ledPin, OUTPUT);
pinMode(10, OUTPUT); //Required for SD card module, do not use
//SD CARD
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
//Print initial startup – works!
dataFile = SD.open("newdoc.txt", FILE_WRITE);
if (dataFile) {
dataFile.println(""); //double spaces for now
dataFile.println(header1); //headers
dataFile.println(header2);
dataFile.close();
// debug
Serial.println("");
Serial.println(header1);
//debug
timeStamp = millis(); // this declaration must be in void loop
//definitions within the loop
float Bytes = lightLevel*voltBytes;
float Voltage = lightLevel*voltBytes*milliVolt;
dtostrf(Bytes,1,2, bytesStr); //convert to text
dtostrf(Voltage, 1,2, voltsStr);
sprintf(buffer1,"%d,%d,%s,%s",timeStamp,lightLevel,bytesStr,voltsStr); //combine
//PHOTORESISTOR
lightLevel = analogRead(sensorPin);
autoTune(); // have the Arduino do the work for us!
analogWrite(ledPin, lightLevel); //nightlight: add 255 - before lightlevel
// SD CARD
if (dataFile) {
dataFile.println(buffer1); // send to card
Serial.println(buffer1); //send to screen
dataFile.close();
// original code (works)
dataFile.print(timeStamp); // turn all reads into a string?
dataFile.print(",");
dataFile.print(lightLevel);
dataFile.print(Bytes);
dataFile.println(Voltage);
dataFile.close(); // close file
//debug
Serial.print("Time: ");
Serial.print(timeStamp);
Serial.print("\t Light Output: ");
Serial.print(lightLevel);
Serial.print("\t Bytes: ");
Serial.print(Bytes);
Serial.print("\t Voltage: ");
Serial.println(Voltage);
else {
Serial.println("error opening newdoc.txt");
//END SD card write
delay(2000);
void manualTune()
lightLevel = map(lightLevel, 0, 1023, 0, 255);
lightLevel = constrain(lightLevel, 0, 255);
void autoTune()
if (lightLevel < low)
low = lightLevel;
if (lightLevel > high)
high = lightLevel;
lightLevel = map(lightLevel, low+30, high-30, 0, 255);
//autotune END
