Hallo,
Ich habe eigentlich wie hier beschrieben: How to Fix Arduino sprintf Float Not Formatting: Convert Float to Char String Correctly — tutorialpedia.org sprintf() aktiviert. Habe die entsprechende Datei angehängt und beim Compilen meine ich auch in der Ausgabe zu erkennen, dass er das aktiviert hat:
/home/david/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,-u,vfprintf -lprintf_flt -lm -mmcu=atmega328p -o /home/david/.var/app/cc.arduino.IDE2/cache/arduino/sketches/35FC6558740892C1AA7BFC9AEB9C1639/sketch_mar19a.ino.elf /home/david/.var/app/cc.arduino.IDE2/cache/arduino/sketches/35FC6558740892C1AA7BFC9AEB9C1639/sketch/sketch_mar19a.ino.cpp.o /home/david/.var/app/cc.arduino.IDE2/cache/arduino/sketches/35FC6558740892C1AA7BFC9AEB9C1639/../../cores/arduino_avr_uno_2c6520e3c8cd3fd575384f133191054e/core.a -L/home/david/.var/app/cc.arduino.IDE2/cache/arduino/sketches/35FC6558740892C1AA7BFC9AEB9C1639 -lm
platform.txt (8,4 KB)
Trotzdem tut es nicht, ich habe zum Testen diesen Code:
float lat = 48.3456789, lon = 9.9876543;
double altitude = 320.739;
int satellites = 7;
int hour = 13;
int minute = 42;
int sec = 7;
long unsigned int age = 95; // 4294967295
float BackupVoltage = 3.514777, MainVoltage = 3.60;
char PingSMS[500];
snprintf(PingSMS, sizeof(PingSMS), "omaps.app/map?v=1&ll=%.5f,%.5f&n=%02d:%02d:%02d_Al%.5f_S%d_Ag%d_BV%.2fblablablabla", BackupVoltage, lon, hour, minute, sec, altitude, satellites, age, BackupVoltage);
char test[20];
snprintf(test, sizeof(test), "%.2f", 5.412);
float humidity = 67.89;
char buffer[20];
Serial.print(F("test: "));
Serial.println(test);
Serial.print(F("PingSMS: "));
Serial.println(PingSMS);
sprintf(buffer, "Humidity: %.1f%%", humidity);
Serial.println(buffer);
Aber der gibt mir nur das aus:
test: 5.41
PingSMS: omaps.app/map?v=1&ll=3.51478,9.98765&n=13:42:07_Al320.73901_S7_Ag95_BV-3070091300000000000000000000000.00blablablabla
Humidity: 67.9%
Es liegt wohl nicht an der Variable, denn die erste Ausgabe funktioniert ja – die zweite aber nicht. Warum? Ich habe wirklich viel Verschiedenes ausprobiert, aber komme beim besten Willen nicht darauf. Danke im Voraus für eure Hilfe!
PS: Ich verwende einen Arduino Nano (Old Bootloader), habe auch einen Arduino Uno probiert – gleiches Ergebnis.
PPS: ich habe gerade festgestellt, das ich direkt nach dem Upload des Codes eine andere Ausgabe bekomme:
test: 5.41
PingSMS: omaps.app/map?v=1&ll=3.98765&n=13:42:07_Al320.73901_S7_Ag95_BV-3070091300000000000000000000000.00blablablabla
Humidity: 67.9%
test: 5.41
Humidity: 67.9%
test: 5.41
Humidity: 67.9%
Danach sind beim erneuten Reset drücken/Neustart durch Öffnen des seriellen Monitors die Ausgaben immer gleich. Keine Ahnung, vielleicht hilft das ja ![]()
