I came across a good website and found out a nice program about inverter I understand how the program flow a little bit. What I don't know is how am I going to convert this into arduino code. This is the code:
//Programmer: Syed Tahmid Mahbub
//Target Microcontroller: ATMEGA16
//Compiler: mikroC PRO for AVR (Can easily port to any other compiler)
unsigned int sin_table[32]={0, 100, 199, 296, 390, 480, 566, 645, 718,
783, 840, 889, 928, 958, 979, 989, 989, 979, 958, 928, 889, 840, 783,
718, 645, 566, 480, 390, 296, 199, 100,0};
#define MOSA PORTD0_bit
#define MOSB PORTD1_bit
#define MOSC PORTD2_bit
#define MOSD PORTD3_bit
unsigned char FlagReg;
#define Direction FlagReg.B0
//0 -> MOS A + D
//1 -> MOS B + C
unsigned int TBL_POINTER_NEW, TBL_POINTER_OLD, TBL_POINTER_SHIFT, SET_FREQ;
unsigned int TBL_temp;
unsigned char DUTY_CYCLE;
void interrupt() org IVT_ADDR_TIMER1_OVF{
TBL_POINTER_NEW = TBL_POINTER_NEW + SET_FREQ;
if (TBL_POINTER_NEW < TBL_POINTER_OLD){
if (Direction == 0){
MOSA = 0;
MOSD = 0;
MOSB = 1;
MOSC = 1;
Direction = 1;
else{
MOSB = 0;
MOSC = 0;
MOSA = 1;
MOSD = 1;
Direction = 0;
TBL_POINTER_SHIFT = TBL_POINTER_NEW >> 11;
DUTY_CYCLE = TBL_POINTER_SHIFT;
TBL_POINTER_SHIFT = sin_table[DUTY_CYCLE];
OCR1AH = TBL_POINTER_SHIFT >> 8;
OCR1AL = TBL_POINTER_SHIFT & 0x0F;
TBL_POINTER_OLD = TBL_POINTER_NEW;
void main() {
SET_FREQ = 410;
TBL_POINTER_SHIFT = 0;
TBL_POINTER_NEW = 0;
TBL_POINTER_OLD = 0;
DUTY_CYCLE = 0;
DDRC = 0xFF;
DDRD = 0XFF;
OCR1AH = 0;
OCR1AL = 0;
TCCR1A = 0x82;
ICR1H = 0x03;
ICR1L = 0xE7;
//ICR1 = 999 -> TOP -> 16kHz
TIMSK = 0x04;
TCCR1B = 0x19;
SREG_I_bit = 1;
while(1);
I'm totally noob in programming. much of my projects are just copy paste and modify a small portion of the code.
(to moderator, If i'm posting in wrong section please kindly delete this.
any help will be much appreciated.
thank you.
Moderator edit: Code tags. { sigh }
