SQL connector Arduino complex_insert problem
Hello,
I have an Arduino Uno r4 Wifi, I would like to create a simple project in which, for example, lighting up a diode or activating a sensor will overwrite the existing SQL database. For this purpose, I started a local server on XAMPP, created an example database and using a ready example: MySQL connector Arduino / complex_insert.
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server_addr(10,0,1,35);  // IP of the MySQL *server* here
char user[] = "root";              // MySQL user login username
char password[] = "secret";        // MySQL user login password
// Sample query
char INSERT_DATA[] = "INSERT INTO test_arduino.hello_sensor (message, sensor_num, value) VALUES ('%s',%d,%s)";
char query[128];
char temperature[10];
EthernetClient client;
MySQL_Connection conn((Client *)&client);
  while (!Serial); // wait for serial port to connect
  Ethernet.begin(mac_addr);
  Serial.println("Connecting...");
  if (conn.connect(server_addr, 3306, user, password)) {
    // Initiate the query class instance
    MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
    // Save
    dtostrf(50.125, 1, 1, temperature);
    sprintf(query, INSERT_DATA, "test sensor", 24, temperature);
    // Execute the query
    cur_mem->execute(query);
    // Note: since there are no results, we do not need to read any data
    // Deleting the cursor also frees up memory used
    delete cur_mem;
    Serial.println("Data recorded.");
    Serial.println("Connection failed.");
  conn.close();
The problem is that when I enter the server address as 127.0.0.1 or as my computer's IP, nothing happens. No changes are made to the database.
Help, what am I doing wrong?
