Hello,
I am new to the DATABASE.
I am using SQLite 3 database with esp32. I cant able to insert data more than 800 - 900 rows and number of entry changes every time when I restart the ESP32.
I can't find what is the problem.
Sounds like a memory issue, but without the code it’s hard to say.
I created database named BMS1 using sqlite3 browser software.
Database has one table called BMS1_DATA and ID,DATE,VOLT,CURRENT are the column in the table.
Here is my code ,
#include <stdio.h>
#include <stdlib.h>
#include <sqlite3.h>
#include <SPI.h>
#include <FS.h>
#include "SD.h"
hw_timer_t * timer = NULL;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
bool first_time = false;
const char* data = "Callback function called";
char *zErrMsg = 0;
int openDb(const char *, sqlite3 **);
int db_exec(sqlite3 *, const char *);
int db__exec(sqlite3 *, const char *);
static int callback(void *data, int argc, char **argv, char **azColName);
static int callback2(void *data, int argc, char **argv, char **azColName);
String date_1 = "DATE = '11-02-2024'";
String id_1 = "ID = 2";
String send_db = "Select * from BMS1_DATA where ID = 1";
//int i = send_db.length();
char send__db [100] ;
String add_db = "insert into BMS1_DATA(ID,DATE , VOLT , CURRENT) values(1,'25-02-2024' , 1 , 1)";
char add__db[100];
String delete_db = "delete from BMS1_DATA where ID = 2";
char delete__db[100];
String BUFF = "";
bool String_complete = false;
char INCOMING_DATA[50];
char DATE[30];
int counter=0;
int ID = 0;
char ID_1[10];
sqlite3 *BMS1_DATA;
int rc;
void IRAM_ATTR onTimer()
portENTER_CRITICAL_ISR(&timerMux);
counter++;
ID++;
// counter2++;
portEXIT_CRITICAL_ISR(&timerMux);
timer = timerBegin(0, 80, true);
timerAttachInterrupt(timer, &onTimer, true);
timerAlarmWrite(timer, 500000, true);// time value
timerAlarmEnable(timer);
// Serial.println(send_db);
// send_db.replace("DATE = '14-02-2024'" , date_1);
// send_db.toCharArray(send__db, sizeof(send__db));
// Serial.println(send__db);
Serial.println("START");
pinMode(1,OUTPUT);
digitalWrite(1,HIGH);
digitalWrite(1,LOW);
SPI.begin();
SD.begin();
sqlite3_initialize();
// if(openDb("/sd/BMS1.db", &BMS1_DATA))
// return;
/////////////////////////////////////////// To inseret data into database ////////////////////
// rc = db_exec(BMS1_DATA , "insert into BMS1_DATA(DATE , VOLT , CURRENT) values('15-02-2024' , 50 , 60)");
// if(rc != SQLITE_OK){
// sqlite3_close(BMS1_DATA);
// return;
// else
// Serial.println("New record created");
// rc = db_exec(BMS1_DATA , "Select * from BMS1_DATA");
// return;
/////////////////////////////// To read data from the database ////////////////////////////////
// rc = db_exec(BMS1_DATA, send__db);
// if (rc != SQLITE_OK) {
// return;
// rc = db_exec(BMS1_DATA, "Select * from BMS1_DATA where DATE = '14-02-2024'");
// return;
/////////////////////////////////To delete data////////////////////////////////////////
// rc = db_exec(BMS1_DATA, );
// sqlite3_close(BMS1_DATA , "delete from BMS_1 where ID = 2");
// return;
//sqlite3_close(BMS1_DATA);
void loop(){
// Serial.print(BUFF);
if(counter == 1)
counter = 0;
String WRITE_DATA = "values(1,'25-02-2024' , 1 , 1)";
// char WRITE__DATA[100];
itoa(ID,ID_1,10);
WRITE_DATA.replace("1" , ID_1);
// Serial.println(WRITE_DATA);
// Serial.println(ID_1);
return;
add_db.replace("values(1,'25-02-2024' , 1 , 1)", WRITE_DATA);
// Serial.println(add_db);
add_db.toCharArray(add__db, sizeof(add__db));
rc = db__exec(BMS1_DATA , add__db);
return;
rc = db__exec(BMS1_DATA , "Select * from BMS1_DATA");
return;
add_db.replace(WRITE_DATA,"values(1,'25-02-2024' , 1 , 1)");
WRITE_DATA.replace( ID_1 , "1");
BUFF.toCharArray(INCOMING_DATA, sizeof(INCOMING_DATA));
if(String_complete)
// if(INCOMING_DATA[0] == 'I' && INCOMING_DATA[1] == 'D')
// delete_db.replace("ID = 2" , BUFF);
// delete_db.toCharArray(delete__db, sizeof(delete__db));
// // Serial.println(BUFF);
// // Serial.println(send__db);
// return;
// rc = db_exec(BMS1_DATA, delete__db);
// return;
// send_db.replace(BUFF,"ID = 2");
// if(INCOMING_DATA[0] == 'v' && INCOMING_DATA[1] == 'a' && INCOMING_DATA[2] == 'l' && INCOMING_DATA[3] == 'u')
// return;
// add_db.replace("values('15-02-2024' , 50 , 60)" , BUFF);
// add_db.toCharArray(add__db, sizeof(add__db));
// rc = db__exec(BMS1_DATA , add__db);
// return;
// else
// rc = db__exec(BMS1_DATA , "Select * from BMS1_DATA");
// return;
// add_db.replace(BUFF,"values('15-02-2024' , 50 , 60)");
send_db.replace("ID = 1" , BUFF);
return;
return;
send_db.replace(BUFF,"ID = 1");
//delay(1000);
static int callback(void *data, int argc, char **argv, char **azColName) {
int i;
if (first_time) {
Serial.println((const char *) data);
for (i = 0; i<argc; i++) {
if (i)
Serial.print((char) '\t');
Serial.printf("%s", azColName[i]);
Serial.printf("\n");
first_time = false;
if (i)
Serial.printf("%s", argv[i] ? argv[i] : "NULL");
return 0;
static int callback2(void *data, int argc, char **argv, char **azColName) {
int i;
if (first_time) {
// Serial.println((const char *) data);
if (i)
// Serial.print((char) '\t');
// Serial.printf("%s", azColName[i]);
// Serial.printf("\n");
first_time = false;
if (i)
// Serial.printf("%s", argv[i] ? argv[i] : "NULL");
return 0;
int openDb(const char *filename, sqlite3 **db) {
int rc = sqlite3_open(filename, db);
if (rc) {
Serial.printf("Can't open database: %s\n", sqlite3_errmsg(*db));
return rc;
// Serial.printf("Opened database successfully\n");
return rc;
int db_exec(sqlite3 *db, const char *sql) {
Serial.println('\n');
int rc = sqlite3_exec(db, sql, callback, (void*)data, &zErrMsg);
Serial.printf("SQL error: %s\n", zErrMsg);
sqlite3_free(zErrMsg);
return rc;
int db__exec(sqlite3 *db, const char *sql) {
// Serial.println('\n');
int rc = sqlite3_exec(db, sql, callback2, (void*)data, &zErrMsg);
return rc;
void serialEventRun()
while(Serial.available())
int counter = 0;
BUFF = Serial.readString();
String_complete = true;
