sqlite3 insert fails
This is the relevant part of my code:
  char sHost[]    = "Zomaar een hostnaam";
  char sPath[]    = "Bedenk maar een path als je wilt";
  uint16_t sPort  = 65535;
  char sName[]    = "Een hele mooie naam is altijd mooi";
  /* Create SQL statement */
  sql = "INSERT INTO stations(sHost,sPath,sPort,sName) VALUES (?,?,?,?)",(sHost,sPath,sPort,sName);
  //sql = "INSERT INTO stations(sHost,sPath,sPort,sName) VALUES ('sHost url','sPath value',80,'sName station')";
The un-commented statement fails
The commented works just fine but is not very flexible.
The error message is:
Opened database successfully
SQL error: NOT NULL constraint failed: stations.sHost
Program ended with exit code: 0
While it's clear that sHost in NOT NULL.
**Any suggestion would be most **helpful
Look up bind variables for sqlite3.
Alternatively, use sprintf to populate the values from your variables into the sql string.
what's sql variable type ??
This does not sound like proper C++
it just assigns sName to sql given the way the comma works in statements.
@wildbill
Thanks for the reply, but I don't understand what you mean by formatting the string I wish to put in the db.
"The C library function int sprintf(char *str, const char *format, ...) sends formatted output to a string pointed to, by str."
Can, will, you provide an example please?
if sql is a char buffer large enough
char sql[200];
sprintf(sql, "INSERT INTO stations(sHost,sPath,sPort,sName) VALUES ('%s','%s','%s','%s')", sHost,sPath,sPort,sName);
your issue with your previous code is that when you do x = (a, b, c); in c++, the compiler evaluates a, b and then c and stores the result of evaluating c into x.
@J-M-L
The sprintf did the trick!
I've to change this:
char sSql[200];
char *sql = sSql;
but it works.
Thank you.
@ wildbill
Can, will, you please point me to an explanation/tutorial on how this "Look up bind variables for sqlite3. " thing works?
if you already had a buffer you could have used that directly, you don't need to have the extra pointer
 sprintf([color=red]sSql[/color], "INSERT ...
Your right, but when I try to list the db records, my compiler complains with: "Array type 'char [200]' is not assignable". So I leave it as is.
very weird... would need to see some real code
Just to help other people making their search for that "bindings" thing a little easier, I've found this: "https://www.whoishostingthis.com/compare/sqlite/optimize/".
Its a good explanation of What, How and Why. To find information on the working of statements, as usual, mr. G. is your friend.
Even better! https://zetcode.com/db/sqlitec/
