Hello everyone
I want to build simple UI by Squareline Studio just two Buttons for LED "ON" & "OFF", i have done all tutorials from official youtube video and then export project...
does someone knows how to integrate exported code to project ?
(there are guide how to setup pins, but i can't figure out )
1. Open the .ino
file in Arduino
2. Go to File/Preferences and set Sketchbook location to the path of your UI project (where this README is located)
3. Go to libraries/TFT_eSPI
and open User_Setup.h
or User_Setup_Select.h
with a text editor to configure pins for your display.
4. Select your board (install if needed)
5. Build the project
Note that this project doesn't contain touch pad driver. You can use an other Arudino library for your touchpad controller.
Without changing these files i get error
In file included from /Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:31:0:
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c: In member function 'void TFT_eSPI::pushBlock(uint16_t, uint32_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:529:29: error: 'SPI_X' was not declared in this scope
while (!spi_is_writable(SPI_X)){};
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:529:29: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:529:13: error: 'spi_is_writable' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:529:13: note: suggested alternative: 'spiwrite'
spiwrite
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:530:16: error: 'SPI_X' was not declared in this scope
spi_get_hw(SPI_X)->dr = (uint32_t)color;
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:530:16: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:530:5: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:530:5: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c: In member function 'void TFT_eSPI::pushPixels(const void*, uint32_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:543:31: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:543:31: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:543:15: error: 'spi_is_writable' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:543:15: note: suggested alternative: 'spiwrite'
spiwrite
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:544:18: error: 'SPI_X' was not declared in this scope
spi_get_hw(SPI_X)->dr = (uint32_t)(*data++);
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:544:18: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:544:7: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:544:7: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:553:31: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:553:31: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:553:15: error: 'spi_is_writable' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:553:15: note: suggested alternative: 'spiwrite'
spiwrite
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:554:18: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:554:18: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:554:7: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/Processors/TFT_eSPI_RP2040.c:554:7: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::setWindow(int32_t, int32_t, int32_t, int32_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3417:25: error: 'SPI_X' was not declared in this scope
while (spi_get_hw(SPI_X)->sr & SPI_SSPSR_BSY_BITS) {};
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3417:25: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3417:14: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3417:14: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3417:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3417:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:39: error: 'SPI_X' was not declared in this scope
hw_write_masked(&spi_get_hw(SPI_X)->cr0, (8 - 1) << SPI_SSPCR0_DSS_LSB, SPI_SSPCR0_DSS_BITS);
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:39: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:28: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:28: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:63: error: 'SPI_SSPCR0_DSS_LSB' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:63: note: suggested alternative: 'SAI_xCR1_DS_0'
SAI_xCR1_DS_0
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:83: error: 'SPI_SSPCR0_DSS_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:83: note: suggested alternative: 'SPI_CR1_SSI'
SPI_CR1_SSI
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3423:11: error: 'hw_write_masked' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3428:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3428:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3435:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3435:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3439:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3439:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3446:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3446:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3450:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3450:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp: In member function 'void TFT_eSPI::readAddrWindow(int32_t, int32_t, int32_t, int32_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3520:21: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3520:21: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3520:10: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3520:10: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3520:34: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3520:34: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:31: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:31: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:20: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:20: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:55: error: 'SPI_SSPCR0_DSS_LSB' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:55: note: suggested alternative: 'SAI_xCR1_DS_0'
SAI_xCR1_DS_0
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:75: error: 'SPI_SSPCR0_DSS_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:75: note: suggested alternative: 'SPI_CR1_SSI'
SPI_CR1_SSI
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3522:3: error: 'hw_write_masked' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3525:34: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3525:34: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3532:34: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3532:34: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3536:34: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3536:34: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3543:34: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3543:34: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3547:34: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3547:34: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3551:10: error: 'spi_is_readable' was not declared in this scope
while (spi_is_readable(SPI_X)) (void)spi_get_hw(SPI_X)->dr;
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3551:10: note: suggested alternative: 'spi_end_read'
spi_end_read
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3552:28: error: 'SPI_SSPICR_RORIC_BITS' was not declared in this scope
spi_get_hw(SPI_X)->icr = SPI_SSPICR_RORIC_BITS;
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3552:28: note: suggested alternative: 'STM_PIN_OD_BITS'
STM_PIN_OD_BITS
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::drawPixel(int32_t, int32_t, uint32_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3639:23: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3639:23: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3639:12: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3639:12: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3639:36: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3639:36: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:35: error: 'SPI_X' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:35: note: suggested alternative: 'SPI_6'
SPI_6
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:24: error: 'spi_get_hw' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:24: note: suggested alternative: 'spi_begin'
spi_begin
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:59: error: 'SPI_SSPCR0_DSS_LSB' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:59: note: suggested alternative: 'SAI_xCR1_DS_0'
SAI_xCR1_DS_0
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:79: error: 'SPI_SSPCR0_DSS_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:79: note: suggested alternative: 'SPI_CR1_SSI'
SPI_CR1_SSI
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3644:7: error: 'hw_write_masked' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3650:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
while (spi_get_hw(SPI_X)->sr & SPI_SSPSR_BSY_BITS){};
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3650:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3657:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3657:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3663:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3663:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3670:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3670:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3684:38: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3684:38: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3693:36: error: 'SPI_SSPSR_BSY_BITS' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:3693:36: note: suggested alternative: 'SPI_NSS_SOFT'
SPI_NSS_SOFT
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp: In member function 'int16_t TFT_eSPI::drawNumber(long int, int32_t, int32_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:5773:3: error: 'ltoa' was not declared in this scope
ltoa(long_num, str, 10);
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:5773:3: note: suggested alternative: 'utoa'
utoa
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp: In member function 'int16_t TFT_eSPI::drawNumber(long int, int32_t, int32_t, uint8_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:5781:3: error: 'ltoa' was not declared in this scope
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:5781:3: note: suggested alternative: 'utoa'
utoa
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp: In member function 'int16_t TFT_eSPI::drawFloat(float, uint8_t, int32_t, int32_t, uint8_t)':
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:5837:3: error: 'ltoa' was not declared in this scope
ltoa(temp, str + ptr, 10);
/Users/macbook/Documents/Arduino/test/libraries/TFT_eSPI/TFT_eSPI.cpp:5837:3: note: suggested alternative: 'utoa'
utoa
exit status 1
Compilation error: exit status 1
User_Setup.h
// USER DEFINED SETTINGS
// Set driver type, fonts to be loaded, pins used and SPI control method etc
// See the User_Setup_Select.h file if you wish to be able to define multiple
// setups and then easily select which setup file is used by the compiler.
// If this file is edited correctly then all the library example sketches should
// run without the need to make any more changes for a particular hardware setup!
// Note that some sketches are designed for a particular TFT pixel width/height
// User defined information reported by "Read_User_Setup" test & diagnostics example
#define USER_SETUP_INFO "User_Setup"
// Define to disable all #warnings in library (can be put in User_Setup_Select.h)
//#define DISABLE_ALL_LIBRARY_WARNINGS
// Section 1. Call up the right driver file and any options for it
// Define STM32 to invoke optimised processor support (only for STM32)
//#define STM32
// Defining the STM32 board allows the library to optimise the performance
// for UNO compatible "MCUfriend" style shields
//#define NUCLEO_64_TFT
//#define NUCLEO_144_TFT
// STM32 8 bit parallel only:
// If STN32 Port A or B pins 0-7 are used for 8 bit parallel data bus bits 0-7
// then this will improve rendering performance by a factor of ~8x
//#define STM_PORTA_DATA_BUS
//#define STM_PORTB_DATA_BUS
// Tell the library to use parallel mode (otherwise SPI is assumed)
//#define TFT_PARALLEL_8_BIT
//#defined TFT_PARALLEL_16_BIT // **** 16 bit parallel ONLY for RP2040 processor ****
// Display type - only define if RPi display
//#define RPI_DISPLAY_TYPE // 20MHz maximum SPI
// Only define one driver, the other ones must be commented out
#define ILI9341_DRIVER // Generic driver for common displays
//#define ILI9341_2_DRIVER // Alternative ILI9341 driver, see https://github.com/Bodmer/TFT_eSPI/issues/1172
//#define ST7735_DRIVER // Define additional parameters below for this display
//#define ILI9163_DRIVER // Define additional parameters below for this display
//#define S6D02A1_DRIVER
//#define RPI_ILI9486_DRIVER // 20MHz maximum SPI
//#define HX8357D_DRIVER
//#define ILI9481_DRIVER
//#define ILI9486_DRIVER
//#define ILI9488_DRIVER // WARNING: Do not connect ILI9488 display SDO to MISO if other devices share the SPI bus (TFT SDO does NOT tristate when CS is high)
//#define ST7789_DRIVER // Full configuration option, define additional parameters below for this display
//#define ST7789_2_DRIVER // Minimal configuration option, define additional parameters below for this display
//#define R61581_DRIVER
//#define RM68140_DRIVER
//#define ST7796_DRIVER
//#define SSD1351_DRIVER
//#define SSD1963_480_DRIVER
//#define SSD1963_800_DRIVER
//#define SSD1963_800ALT_DRIVER
//#define ILI9225_DRIVER
//#define GC9A01_DRIVER
// Some displays support SPI reads via the MISO pin, other displays have a single
// bi-directional SDA pin and the library will try to read this via the MOSI line.
// To use the SDA line for reading data from the TFT uncomment the following line:
// #define TFT_SDA_READ // This option is for ESP32 ONLY, tested with ST7789 and GC9A01 display only
// For ST7735, ST7789 and ILI9341 ONLY, define the colour order IF the blue and red are swapped on your display
// Try ONE option at a time to find the correct colour order for your display
// #define TFT_RGB_ORDER TFT_RGB // Colour order Red-Green-Blue
// #define TFT_RGB_ORDER TFT_BGR // Colour order Blue-Green-Red
// For M5Stack ESP32 module with integrated ILI9341 display ONLY, remove // in line below
// #define M5STACK
// For ST7789, ST7735, ILI9163 and GC9A01 ONLY, define the pixel width and height in portrait orientation
// #define TFT_WIDTH 80
// #define TFT_WIDTH 128
// #define TFT_WIDTH 172 // ST7789 172 x 320
// #define TFT_WIDTH 170 // ST7789 170 x 320
// #define TFT_WIDTH 240 // ST7789 240 x 240 and 240 x 320
// #define TFT_HEIGHT 160
// #define TFT_HEIGHT 128
// #define TFT_HEIGHT 240 // ST7789 240 x 240
// #define TFT_HEIGHT 320 // ST7789 240 x 320
// #define TFT_HEIGHT 240 // GC9A01 240 x 240
// For ST7735 ONLY, define the type of display, originally this was based on the
// colour of the tab on the screen protector film but this is not always true, so try
// out the different options below if the screen does not display graphics correctly,
// e.g. colours wrong, mirror images, or stray pixels at the edges.
// Comment out ALL BUT ONE of these options for a ST7735 display driver, save this
// this User_Setup file, then rebuild and upload the sketch to the board again:
// #define ST7735_INITB
// #define ST7735_GREENTAB
// #define ST7735_GREENTAB2
// #define ST7735_GREENTAB3
// #define ST7735_GREENTAB128 // For 128 x 128 display
// #define ST7735_GREENTAB160x80 // For 160 x 80 display (BGR, inverted, 26 offset)
// #define ST7735_ROBOTLCD // For some RobotLCD arduino shields (128x160, BGR, https://docs.arduino.cc/retired/getting-started-guides/TFT)
// #define ST7735_REDTAB
// #define ST7735_BLACKTAB
// #define ST7735_REDTAB160x80 // For 160 x 80 display with 24 pixel offset
// If colours are inverted (white shows as black) then uncomment one of the next
// 2 lines try both options, one of the options should correct the inversion.
// #define TFT_INVERSION_ON
// #define TFT_INVERSION_OFF
// Section 2. Define the pins that are used to interface with the display here
// If a backlight control signal is available then define the TFT_BL pin in Section 2
// below. The backlight will be turned ON when tft.begin() is called, but the library
// needs to know if the LEDs are ON with the pin HIGH or LOW. If the LEDs are to be
// driven with a PWM signal or turned OFF/ON then this must be handled by the user
// sketch. e.g. with digitalWrite(TFT_BL, LOW);
// #define TFT_BL 32 // LED back-light control pin
// #define TFT_BACKLIGHT_ON HIGH // Level to turn ON back-light (HIGH or LOW)
// We must use hardware SPI, a minimum of 3 GPIO pins is needed.
// Typical setup for ESP8266 NodeMCU ESP-12 is :
// Display SDO/MISO to NodeMCU pin D6 (or leave disconnected if not reading TFT)
// Display LED to NodeMCU pin VIN (or 5V, see below)
// Display SCK to NodeMCU pin D5
// Display SDI/MOSI to NodeMCU pin D7
// Display DC (RS/AO)to NodeMCU pin D3
// Display RESET to NodeMCU pin D4 (or RST, see below)
// Display CS to NodeMCU pin D8 (or GND, see below)
// Display GND to NodeMCU pin GND (0V)
// Display VCC to NodeMCU 5V or 3.3V
// The TFT RESET pin can be connected to the NodeMCU RST pin or 3.3V to free up a control pin
// The DC (Data Command) pin may be labelled AO or RS (Register Select)
// With some displays such as the ILI9341 the TFT CS pin can be connected to GND if no more
// SPI devices (e.g. an SD Card) are connected, in this case comment out the #define TFT_CS
// line below so it is NOT defined. Other displays such at the ST7735 require the TFT CS pin
// to be toggled during setup, so in these cases the TFT_CS line must be defined and connected.
// The NodeMCU D0 pin can be used for RST
// Note: only some versions of the NodeMCU provide the USB 5V on the VIN pin
// If 5V is not available at a pin you can use 3.3V but backlight brightness
// will be lower.
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP8266 SETUP ######
// For NodeMCU - use pin numbers in the form PIN_Dx where Dx is the NodeMCU pin designation
#define TFT_MISO PIN_D6 // Automatically assigned with ESP8266 if not defined
#define TFT_MOSI PIN_D7 // Automatically assigned with ESP8266 if not defined
#define TFT_SCLK PIN_D5 // Automatically assigned with ESP8266 if not defined
#define TFT_CS PIN_D8 // Chip select control pin D8
#define TFT_DC PIN_D3 // Data Command control pin
#define TFT_RST PIN_D4 // Reset pin (could connect to NodeMCU RST, see next line)
//#define TFT_RST -1 // Set TFT_RST to -1 if the display RESET is connected to NodeMCU RST or 3.3V
//#define TFT_BL PIN_D1 // LED back-light (only for ST7789 with backlight control pin)
//#define TOUCH_CS PIN_D2 // Chip select pin (T_CS) of touch screen
//#define TFT_WR PIN_D2 // Write strobe for modified Raspberry Pi TFT only
// ###### FOR ESP8266 OVERLAP MODE EDIT THE PIN NUMBERS IN THE FOLLOWING LINES ######
// Overlap mode shares the ESP8266 FLASH SPI bus with the TFT so has a performance impact
// but saves pins for other functions. It is best not to connect MISO as some displays
// do not tristate that line when chip select is high!
// Note: Only one SPI device can share the FLASH SPI lines, so a SPI touch controller
// cannot be connected as well to the same SPI signals.
// On NodeMCU 1.0 SD0=MISO, SD1=MOSI, CLK=SCLK to connect to TFT in overlap mode
// On NodeMCU V3 S0 =MISO, S1 =MOSI, S2 =SCLK
// In ESP8266 overlap mode the following must be defined
//#define TFT_SPI_OVERLAP
// In ESP8266 overlap mode the TFT chip select MUST connect to pin D3
//#define TFT_CS PIN_D3
//#define TFT_DC PIN_D5 // Data Command control pin
//#define TFT_RST PIN_D4 // Reset pin (could connect to NodeMCU RST, see next line)
// ###### EDIT THE PIN NUMBERS IN THE LINES FOLLOWING TO SUIT YOUR ESP32 SETUP ######
// For ESP32 Dev board (only tested with ILI9341 display)
// The hardware SPI can be mapped to any pins
//#define TFT_MISO 19
//#define TFT_MOSI 23
//#define TFT_SCLK 18
//#define TFT_CS 15 // Chip select control pin
//#define TFT_DC 2 // Data Command control pin
//#define TFT_RST 4 // Reset pin (could connect to RST pin)
//#define TFT_RST -1 // Set TFT_RST to -1 if display RESET is connected to ESP32 board RST
// For ESP32 Dev board (only tested with GC9A01 display)
//#define TFT_MOSI 15 // In some display driver board, it might be written as "SDA" and so on.
//#define TFT_SCLK 14
//#define TFT_CS 5 // Chip select control pin
//#define TFT_DC 27 // Data Command control pin
//#define TFT_RST 33 // Reset pin (could connect to Arduino RESET pin)
//#define TFT_BL 22 // LED back-light
//#define TOUCH_CS 21 // Chip select pin (T_CS) of touch screen
//#define TFT_WR 22 // Write strobe for modified Raspberry Pi TFT only
// For the M5Stack module use these #define lines
//#define TFT_CS 14 // Chip select control pin
//#define TFT_BL 32 // LED back-light (required for M5Stack)
// ###### EDIT THE PINs BELOW TO SUIT YOUR ESP32 PARALLEL TFT SETUP ######
// The library supports 8 bit parallel TFTs with the ESP32, the pin
// selection below is compatible with ESP32 boards in UNO format.
// Wemos D32 boards need to be modified, see diagram in Tools folder.
// Only ILI9481 and ILI9341 based displays have been tested!
// Parallel bus is only supported for the STM32 and ESP32
// Example below is for ESP32 Parallel interface with UNO displays
// Tell the library to use 8 bit parallel mode (otherwise SPI is assumed)
// The ESP32 and TFT the pins used for testing are:
//#define TFT_CS 33 // Chip select control pin (library pulls permanently low
//#define TFT_DC 15 // Data Command control pin - must use a pin in the range 0-31
//#define TFT_RST 32 // Reset pin, toggles on startup
//#define TFT_WR 4 // Write strobe control pin - must use a pin in the range 0-31
//#define TFT_RD 2 // Read strobe control pin
//#define TFT_D0 12 // Must use pins in the range 0-31 for the data bus
//#define TFT_D1 13 // so a single register write sets/clears all bits.
//#define TFT_D2 26 // Pins can be randomly assigned, this does not affect
//#define TFT_D3 25 // TFT screen update performance.
//#define TFT_D4 17
//#define TFT_D5 16
//#define TFT_D6 27
//#define TFT_D7 14
// ###### EDIT THE PINs BELOW TO SUIT YOUR STM32 SPI TFT SETUP ######
// The TFT can be connected to SPI port 1 or 2
//#define TFT_SPI_PORT 1 // SPI port 1 maximum clock rate is 55MHz
//#define TFT_MOSI PA7
//#define TFT_MISO PA6
//#define TFT_SCLK PA5
//#define TFT_SPI_PORT 2 // SPI port 2 maximum clock rate is 27MHz
//#define TFT_MOSI PB15
//#define TFT_MISO PB14
//#define TFT_SCLK PB13
// Can use Ardiuno pin references, arbitrary allocation, TFT_eSPI controls chip select
//#define TFT_CS D5 // Chip select control pin to TFT CS
//#define TFT_DC D6 // Data Command control pin to TFT DC (may be labelled RS = Register Select)
//#define TFT_RST D7 // Reset pin to TFT RST (or RESET)
// OR alternatively, we can use STM32 port reference names PXnn
//#define TFT_CS PE11 // Nucleo-F767ZI equivalent of D5
//#define TFT_DC PE9 // Nucleo-F767ZI equivalent of D6
//#define TFT_RST PF13 // Nucleo-F767ZI equivalent of D7
//#define TFT_RST -1 // Set TFT_RST to -1 if the display RESET is connected to processor reset
// Use an Arduino pin for initial testing as connecting to processor reset
// may not work (pulse too short at power up?)
// Section 3. Define the fonts that are to be used here
// Comment out the #defines below with // to stop that font being loaded
// The ESP8366 and ESP32 have plenty of memory so commenting out fonts is not
// normally necessary. If all fonts are loaded the extra FLASH space required is
// about 17Kbytes. To save FLASH space only enable the fonts you need!
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:-.
//#define LOAD_FONT8N // Font 8. Alternative to Font 8 above, slightly narrower, so 3 digits fit a 160 pixel TFT
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
// Comment out the #define below to stop the SPIFFS filing system and smooth font code being loaded
// this will save ~20kbytes of FLASH
#define SMOOTH_FONT
// Section 4. Other options
// For RP2040 processor and SPI displays, uncomment the following line to use the PIO interface.
//#define RP2040_PIO_SPI // Leave commented out to use standard RP2040 SPI port interface
// For RP2040 processor and 8 or 16 bit parallel displays:
// The parallel interface write cycle period is derived from a division of the CPU clock
// speed so scales with the processor clock. This means that the divider ratio may need
// to be increased when overclocking. It may also need to be adjusted dependant on the
// display controller type (ILI94341, HX8357C etc). If RP2040_PIO_CLK_DIV is not defined
// the library will set default values which may not suit your display.
// The display controller data sheet will specify the minimum write cycle period. The
// controllers often work reliably for shorter periods, however if the period is too short
// the display may not initialise or graphics will become corrupted.
// PIO write cycle frequency = (CPU clock/(4 * RP2040_PIO_CLK_DIV))
//#define RP2040_PIO_CLK_DIV 1 // 32ns write cycle at 125MHz CPU clock
//#define RP2040_PIO_CLK_DIV 2 // 64ns write cycle at 125MHz CPU clock
//#define RP2040_PIO_CLK_DIV 3 // 96ns write cycle at 125MHz CPU clock
// For the RP2040 processor define the SPI port channel used (default 0 if undefined)
//#define TFT_SPI_PORT 1 // Set to 0 if SPI0 pins are used, or 1 if spi1 pins used
// For the STM32 processor define the SPI port channel used (default 1 if undefined)
//#define TFT_SPI_PORT 2 // Set to 1 for SPI port 1, or 2 for SPI port 2
// Define the SPI clock frequency, this affects the graphics rendering speed. Too
// fast and the TFT driver will not keep up and display corruption appears.
// With an ILI9341 display 40MHz works OK, 80MHz sometimes fails
// With a ST7735 display more than 27MHz may not work (spurious pixels and lines)
// With an ILI9163 display 27 MHz works OK.
// #define SPI_FREQUENCY 1000000
// #define SPI_FREQUENCY 5000000
// #define SPI_FREQUENCY 10000000
// #define SPI_FREQUENCY 20000000
#define SPI_FREQUENCY 27000000
// #define SPI_FREQUENCY 40000000
// #define SPI_FREQUENCY 55000000 // STM32 SPI1 only (SPI2 maximum is 27MHz)
// #define SPI_FREQUENCY 80000000
// Optional reduced SPI frequency for reading TFT
#define SPI_READ_FREQUENCY 20000000
// The XPT2046 requires a lower SPI clock rate of 2.5MHz so we define that here:
#define SPI_TOUCH_FREQUENCY 2500000
// The ESP32 has 2 free SPI ports i.e. VSPI and HSPI, the VSPI is the default.
// If the VSPI port is in use and pins are not accessible (e.g. TTGO T-Beam)
// then uncomment the following line:
//#define USE_HSPI_PORT
// Comment out the following #define if "SPI Transactions" do not need to be
// supported. When commented out the code size will be smaller and sketches will
// run slightly faster, so leave it commented out unless you need it!
// Transaction support is needed to work with SD library but not needed with TFT_SdFat
// Transaction support is required if other SPI devices are connected.
// Transactions are automatically enabled by the library for an ESP32 (to use HAL mutex)
// so changing it here has no effect
// #define SUPPORT_TRANSACTIONS
User_Setup_Select.h
// This header file contains a list of user setup files and defines which one the
// compiler uses when the IDE performs a Verify/Compile or Upload.
// Users can create configurations for different boards and TFT displays.
// This makes selecting between hardware setups easy by "uncommenting" one line.
// The advantage of this hardware configuration method is that the examples provided
// with the library should work with immediately without any other changes being
// needed. It also improves the portability of users sketches to other hardware
// configurations and compatible libraries.
// Create a shortcut to this file on your desktop to permit quick access for editing.
// Re-compile and upload after making and saving any changes to this file.
// Example User_Setup files are stored in the "User_Setups" folder. These can be used
// unmodified or adapted for a particular hardware configuration.
#ifndef USER_SETUP_LOADED // Lets PlatformIO users define settings in
// platformio.ini, see notes in "Tools" folder.
// User configuration selection lines are below //
// Only ONE line below should be uncommented to define your setup. Add extra lines and files as needed.
#include <User_Setup.h> // Default setup is root library folder
//#include <User_Setups/Setup1_ILI9341.h> // Setup file for ESP8266 configured for my ILI9341
//#include <User_Setups/Setup2_ST7735.h> // Setup file for ESP8266 configured for my ST7735
//#include <User_Setups/Setup3_ILI9163.h> // Setup file for ESP8266 configured for my ILI9163
//#include <User_Setups/Setup4_S6D02A1.h> // Setup file for ESP8266 configured for my S6D02A1
//#include <User_Setups/Setup5_RPi_ILI9486.h> // Setup file for ESP8266 configured for my stock RPi TFT
//#include <User_Setups/Setup6_RPi_Wr_ILI9486.h> // Setup file for ESP8266 configured for my modified RPi TFT
//#include <User_Setups/Setup7_ST7735_128x128.h> // Setup file for ESP8266 configured for my ST7735 128x128 display
//#include <User_Setups/Setup8_ILI9163_128x128.h> // Setup file for ESP8266 configured for my ILI9163 128x128 display
//#include <User_Setups/Setup9_ST7735_Overlap.h> // Setup file for ESP8266 configured for my ST7735
//#include <User_Setups/Setup10_RPi_touch_ILI9486.h> // Setup file for ESP8266 configured for ESP8266 and RPi TFT with touch
//#include <User_Setups/Setup11_RPi_touch_ILI9486.h> // Setup file configured for ESP32 and RPi TFT with touch
//#include <User_Setups/Setup12_M5Stack_Basic_Core.h>// Setup file for the ESP32 based M5Stack (Basic Core only)
//#include <User_Setups/Setup13_ILI9481_Parallel.h> // Setup file for the ESP32 with parallel bus TFT
//#include <User_Setups/Setup14_ILI9341_Parallel.h> // Setup file for the ESP32 with parallel bus TFT
//#include <User_Setups/Setup15_HX8357D.h> // Setup file for ESP8266 configured for HX8357D
//#include <User_Setups/Setup16_ILI9488_Parallel.h> // Setup file for the ESP32 with parallel bus TFT
//#include <User_Setups/Setup17_ePaper.h> // Setup file for ESP8266 and any Waveshare ePaper display
//#include <User_Setups/Setup18_ST7789.h> // Setup file for ESP8266 configured for ST7789
//#include <User_Setups/Setup19_RM68140_Parallel.h> // Setup file configured for RM68140 with parallel bus
//#include <User_Setups/Setup20_ILI9488.h> // Setup file for ESP8266 and ILI9488 SPI bus TFT
//#include <User_Setups/Setup21_ILI9488.h> // Setup file for ESP32 and ILI9488 SPI bus TFT
//#include <User_Setups/Setup22_TTGO_T4.h> // Setup file for ESP32 and TTGO T4 version 1.2
//#include <User_Setups/Setup22_TTGO_T4_v1.3.h> // Setup file for ESP32 and TTGO T4 version 1.3
//#include <User_Setups/Setup23_TTGO_TM.h> // Setup file for ESP32 and TTGO TM ST7789 SPI bus TFT
//#include <User_Setups/Setup24_ST7789.h> // Setup file for DSTIKE/ESP32/ESP8266 configured for ST7789 240 x 240
//#include <User_Setups/Setup25_TTGO_T_Display.h> // Setup file for ESP32 and TTGO T-Display ST7789V SPI bus TFT
//#include <User_Setups/Setup26_TTGO_T_Wristband.h> // Setup file for ESP32 and TTGO T-Wristband ST7735 SPI bus TFT
//#include <User_Setups/Setup27_RPi_ST7796_ESP32.h> // ESP32 RPi MHS-4.0 inch Display-B
//#include <User_Setups/Setup28_RPi_ST7796_ESP8266.h> // ESP8266 RPi MHS-4.0 inch Display-B
//#include <User_Setups/Setup29_ILI9341_STM32.h> // Setup for Nucleo board
//#include <User_Setups/Setup30_ILI9341_Parallel_STM32.h> // Setup for Nucleo board and parallel display
//#include <User_Setups/Setup31_ST7796_Parallel_STM32.h> // Setup for Nucleo board and parallel display
//#include <User_Setups/Setup32_ILI9341_STM32F103.h> // Setup for "Blue/Black Pill"
//#include <User_Setups/Setup33_RPi_ILI9486_STM32.h> // Setup for Nucleo board
//#include <User_Setups/Setup34_ILI9481_Parallel_STM32.h> // Setup for Nucleo board and parallel display
//#include <User_Setups/Setup35_ILI9341_STM32_Port_Bus.h> // Setup for STM32 port A parallel display
//#include <User_Setups/Setup36_RPi_touch_ST7796.h> // Setup file configured for ESP32 and RPi ST7796 TFT with touch
//#include <User_Setups/Setup42_ILI9341_ESP32.h> // Setup file for ESP32 and SPI ILI9341 240x320
//#include <User_Setups/Setup43_ST7735.h> // Setup file for ESP8266 & ESP32 configured for my ST7735S 80x160
//#include <User_Setups/Setup44_TTGO_CameraPlus.h> // Setup file for ESP32 and TTGO T-CameraPlus ST7789 SPI bus TFT 240x240
//#include <User_Setups/Setup45_TTGO_T_Watch.h> // Setup file for ESP32 and TTGO T-Watch ST7789 SPI bus TFT 240x240
//#include <User_Setups/Setup46_GC9A01_ESP32.h> // Setup file for ESP32 and GC9A01 SPI bus TFT 240x240
//#include <User_Setups/Setup47_ST7735.h> // Setup file for ESP32 configured for ST7735 128 x 128 animated eyes
//#include <User_Setups/Setup50_SSD1963_Parallel.h> // Setup file for ESP32 and SSD1963 TFT display
//#include <User_Setups/Setup51_LilyPi_ILI9481.h> // Setup file for LilyGo LilyPi with ILI9481 display
//#include <User_Setups/Setup52_LilyPi_ST7796.h> // Setup file for LilyGo LilyPi with ST7796 display
//#include <User_Setups/Setup60_RP2040_ILI9341.h> // Setup file for RP2040 with SPI ILI9341
//#include <User_Setups/Setup61_RP2040_ILI9341_PIO_SPI.h> // Setup file for RP2040 with PIO SPI ILI9341
//#include <User_Setups/Setup62_RP2040_Nano_Connect_ILI9341.h> // Setup file for RP2040 with SPI ILI9341
//#include <User_Setups/Setup66_Seeed_XIAO_Round.h> // Setup file for Seeed XIAO with GC9A01 240x240
//#include <User_Setups/Setup70_ESP32_S2_ILI9341.h> // Setup file for ESP32 S2 with SPI ILI9341
//#include <User_Setups/Setup70b_ESP32_S3_ILI9341.h> // Setup file for ESP32 S3 with SPI ILI9341
//#include <User_Setups/Setup70c_ESP32_C3_ILI9341.h> // Setup file for ESP32 C3 with SPI ILI9341
//#include <User_Setups/Setup70d_ILI9488_S3_Parallel.h> // Setup file for ESP32 S3 with SPI ILI9488
//#include <User_Setups/Setup71_ESP32_S2_ST7789.h> // Setup file for ESP32 S2 with ST7789
//#include <User_Setups/Setup72_ESP32_ST7789_172x320.h> // Setup file for ESP32 with ST7789 1.47" 172x320
//#include <User_Setups/Setup100_RP2040_ILI9488_parallel.h> // Setup file for Pico/RP2040 with 8 bit parallel ILI9488
//#include <User_Setups/Setup101_RP2040_ILI9481_parallel.h> // Setup file for Pico/RP2040 with 8 bit parallel ILI9481
//#include <User_Setups/Setup102_RP2040_ILI9341_parallel.h> // Setup file for Pico/RP2040 with 8 bit parallel ILI9341
//#include <User_Setups/Setup103_RP2040_ILI9486_parallel.h> // Setup file for Pico/RP2040 with 8 bit parallel ILI9486
//#include <User_Setups/Setup104_RP2040_ST7796_parallel.h> // Setup file for Pico/RP2040 with 8 bit parallel ST7796
//#include <User_Setups/Setup105_RP2040_ST7796_16bit_parallel.h> // Setup file for RP2040 16 bit parallel display
//#include <User_Setups/Setup106_RP2040_ILI9481_16bit_parallel.h> // Setup file for RP2040 16 bit parallel display
//#include <User_Setups/Setup107_RP2040_ILI9341_16bit_parallel.h> // Setup file for RP2040 16 bit parallel display
//#include <User_Setups/Setup108_RP2040_ST7735.h> // Setup file for Waveshare RP2040 board with onboard ST7735 0.96" 160x80 display
//#include <User_Setups/Setup135_ST7789.h> // Setup file for ESP8266 and ST7789 135 x 240 TFT
//#include <User_Setups/Setup136_LilyGo_TTV.h> // Setup file for ESP32 and Lilygo TTV ST7789 SPI bus TFT 135x240
//#include <User_Setups/Setup137_LilyGo_TDisplay_RP2040.h> // Setup file for Lilygo T-Display RP2040 (ST7789 on SPI bus with 135x240 TFT)
//#include <User_Setups/Setup138_Pico_Explorer_Base_RP2040_ST7789.h> // Setup file for Pico Explorer Base by Pimoroni for RP2040 (ST7789 on SPI bus with 240x240 TFT)
//#include <User_Setups/Setup200_GC9A01.h> // Setup file for ESP32 and GC9A01 240 x 240 TFT
//#include <User_Setups/Setup201_WT32_SC01.h> // Setup file for ESP32 based WT32_SC01 from Seeed
//#include <User_Setups/Setup202_SSD1351_128.h> // Setup file for ESP32/ESP8266 based SSD1351 128x128 1.5inch OLED display
//#include <User_Setups/Setup203_ST7789.h> // Setup file for ESP32/ESP8266 based ST7789 240X280 1.69inch TFT
//#include <User_Setups/Setup204_ESP32_TouchDown.h> // Setup file for the ESP32 TouchDown based on ILI9488 480 x 320 TFT
//#include <User_Setups/Setup205_ESP32_TouchDown_S3.h> // Setup file for the ESP32 TouchDown S3 based on ILI9488 480 x 320 TFT
//#include <User_Setups/Setup206_LilyGo_T_Display_S3.h> // For the LilyGo T-Display S3 based ESP32S3 with ST7789 170 x 320 TFT
//#include <User_Setups/Setup207_LilyGo_T_HMI.h> // For the LilyGo T-HMI S3 based ESP32S3 with ST7789 240 x 320 TFT
//#include <User_Setups/Setup209_LilyGo_T_Dongle_S3.h> // For the LilyGo T-Dongle S3 based ESP32 with ST7735 80 x 160 TFT
//#include <User_Setups/Setup210_LilyGo_T_Embed_S3.h> // For the LilyGo T-Embed S3 based ESP32S3 with ST7789 170 x 320 TFT
//#include <User_Setups/Setup211_LilyGo_T_QT_Pro_S3.h> // For the LilyGo T-QT Pro S3 based ESP32S3 with GC9A01 128 x 128 TFT
// #include <User_Setups/Setup212_LilyGo_T_PicoPro.h> // For the LilyGo T-PICO-Pro with ST7796 222 x 480 TFT
// #include <User_Setups/Setup213_LilyGo_T_Beam_Shield.h> // For the LilyGo T-BEAM V1.x with ST7796 222 x 480 TFT
//#include <User_Setups/Setup250_ESP32_S3_Box_Lite.h> // For the ESP32 S3 Box Lite
//#include <User_Setups/Setup251_ESP32_S3_Box.h> // For the ESP32 S3 Box
//#include <User_Setups/Setup301_BW16_ST7735.h> // Setup file for Bw16-based boards with ST7735 160 x 80 TFT
//#include <User_Setups/SetupX_Template.h> // Template file for a setup
//#include <User_Setups/Dustin_ILI9488.h> // Setup file for Dustin Watts PCB with ILI9488
//#include <User_Setups/Dustin_ST7796.h> // Setup file for Dustin Watts PCB with ST7796
//#include <User_Setups/Dustin_ILI9488_Pico.h> // Setup file for Dustin Watts Pico PCB with ST7796
//#include <User_Setups/Dustin_ST7789_Pico.h> // Setup file for Dustin Watts PCB with ST7789 240 x 240 on 3.3V adapter board
//#include <User_Setups/Dustin_GC9A01_Pico.h> // Setup file for Dustin Watts PCB with GC9A01 240 x 240 on 3.3V adapter board
//#include <User_Setups/Dustin_GC9A01_ESP32.h> // Setup file for Dustin Watts PCB with GC9A01 240 x 240 on 3.3V adapter board
//#include <User_Setups/Dustin_STT7789_ESP32.h> // Setup file for Dustin Watts PCB with ST7789 240 x 240 on 3.3V adapter board
//#include <User_Setups/Dustin_ILI9341_ESP32.h> // Setup file for Dustin Watts PCB with ILI9341
//#include <User_Setups/ILI9225.h>
#endif // USER_SETUP_LOADED
// DON'T TINKER WITH ANY OF THE FOLLOWING LINES, THESE ADD THE TFT DRIVERS //
// AND ESP8266 PIN DEFINITONS, THEY ARE HERE FOR BODMER'S CONVENIENCE! //
// Identical looking TFT displays may have a different colour ordering in the 16 bit colour
#define TFT_BGR 0 // Colour order Blue-Green-Red
#define TFT_RGB 1 // Colour order Red-Green-Blue
// Legacy setup support, RPI_DISPLAY_TYPE replaces RPI_DRIVER
#if defined (RPI_DRIVER)
#if !defined (RPI_DISPLAY_TYPE)
#endif
#endif
// Legacy setup support, RPI_ILI9486_DRIVER form is deprecated
// Instead define RPI_DISPLAY_TYPE and also define driver (e.g. ILI9486_DRIVER)
#if defined (RPI_ILI9486_DRIVER)
#if !defined (ILI9486_DRIVER)
#endif
#endif
#endif
// Invoke 18 bit colour for selected displays
#if !defined (RPI_DISPLAY_TYPE) && !defined (TFT_PARALLEL_8_BIT) && !defined (TFT_PARALLEL_16_BIT) && !defined (ESP32_PARALLEL)
#if defined (ILI9481_DRIVER) || defined (ILI9486_DRIVER) || defined (ILI9488_DRIVER)
#define SPI_18BIT_DRIVER
#endif
#endif
// Load the right driver definition - do not tinker here !
#if defined (ILI9341_DRIVER) || defined(ILI9341_2_DRIVER) || defined (ILI9342_DRIVER)
#include <TFT_Drivers/ILI9341_Defines.h>
#define TFT_DRIVER 0x9341
#elif defined (ST7735_DRIVER)
#include <TFT_Drivers/ST7735_Defines.h>
#define TFT_DRIVER 0x7735
#elif defined (ILI9163_DRIVER)
#include <TFT_Drivers/ILI9163_Defines.h>
#define TFT_DRIVER 0x9163
#elif defined (S6D02A1_DRIVER)
#include <TFT_Drivers/S6D02A1_Defines.h>
#define TFT_DRIVER 0x6D02
#elif defined (ST7796_DRIVER)
#include "TFT_Drivers/ST7796_Defines.h"
#define TFT_DRIVER 0x7796
#elif defined (ILI9486_DRIVER)
#include <TFT_Drivers/ILI9486_Defines.h>
#define TFT_DRIVER 0x9486
#elif defined (ILI9481_DRIVER)
#include <TFT_Drivers/ILI9481_Defines.h>
#define TFT_DRIVER 0x9481
#elif defined (ILI9488_DRIVER)
#include <TFT_Drivers/ILI9488_Defines.h>
#define TFT_DRIVER 0x9488
#elif defined (HX8357D_DRIVER)
#include "TFT_Drivers/HX8357D_Defines.h"
#define TFT_DRIVER 0x8357
#elif defined (EPD_DRIVER)
#include "TFT_Drivers/EPD_Defines.h"
#define TFT_DRIVER 0xE9D
#elif defined (ST7789_DRIVER)
#include "TFT_Drivers/ST7789_Defines.h"
#define TFT_DRIVER 0x7789
#elif defined (R61581_DRIVER)
#include "TFT_Drivers/R61581_Defines.h"
#define TFT_DRIVER 0x6158
#elif defined (ST7789_2_DRIVER)
#include "TFT_Drivers/ST7789_2_Defines.h"
#define TFT_DRIVER 0x778B
#elif defined (RM68140_DRIVER)
#include "TFT_Drivers/RM68140_Defines.h"
#define TFT_DRIVER 0x6814
#elif defined (SSD1351_DRIVER)
#include "TFT_Drivers/SSD1351_Defines.h"
#define TFT_DRIVER 0x1351
#elif defined (SSD1963_480_DRIVER)
#include "TFT_Drivers/SSD1963_Defines.h"
#define TFT_DRIVER 0x1963
#elif defined (SSD1963_800_DRIVER)
#elif defined (SSD1963_800ALT_DRIVER)
#elif defined (SSD1963_800BD_DRIVER)
#elif defined (GC9A01_DRIVER)
#include "TFT_Drivers/GC9A01_Defines.h"
#define TFT_DRIVER 0x9A01
#elif defined (ILI9225_DRIVER)
#include "TFT_Drivers/ILI9225_Defines.h"
#define TFT_DRIVER 0x9225
#elif defined (RM68120_DRIVER)
#include "TFT_Drivers/RM68120_Defines.h"
#define TFT_DRIVER 0x6812
#elif defined (HX8357B_DRIVER)
#include "TFT_Drivers/HX8357B_Defines.h"
#define TFT_DRIVER 0x835B
#elif defined (HX8357C_DRIVER)
#include "TFT_Drivers/HX8357C_Defines.h"
#define TFT_DRIVER 0x835C
// <<<<<<<<<<<<<<<<<<<<<<<< ADD NEW DRIVER HERE
// XYZZY_init.h and XYZZY_rotation.h must also be added in TFT_eSPI.cpp
#elif defined (XYZZY_DRIVER)
#include "TFT_Drivers/XYZZY_Defines.h"
#define TFT_DRIVER 0x0000
#else
#endif
// These are the pins for ESP8266 boards
// Name GPIO NodeMCU Function
#define PIN_D0 16 // GPIO16 WAKE
#define PIN_D1 5 // GPIO5 User purpose
#define PIN_D2 4 // GPIO4 User purpose
#define PIN_D3 0 // GPIO0 Low on boot means enter FLASH mode
#define PIN_D4 2 // GPIO2 TXD1 (must be high on boot to go to UART0 FLASH mode)
#define PIN_D5 14 // GPIO14 HSCLK
#define PIN_D6 12 // GPIO12 HMISO
#define PIN_D7 13 // GPIO13 HMOSI RXD2
#define PIN_D8 15 // GPIO15 HCS TXD0 (must be low on boot to enter UART0 FLASH mode)
#define PIN_D9 3 // RXD0
#define PIN_D10 1 // TXD0
#define PIN_MOSI 8 // SD1 FLASH and overlap mode
#define PIN_MISO 7 // SD0
#define PIN_SCLK 6 // CLK
#define PIN_HWCS 0 // D3
#define PIN_D11 9 // SD2
#define PIN_D12 10 // SD4
Thanks
