Standard deviation calculation generating massive -incorrect- numbers
Hello!
Long time seeker of knowledge from the forums, the first time I have had to reach out for help. I am trying to work out the standard deviation of an array s_val and I am following this blog post as upon finding it, I thought I could follow the code, but I am having strange results.
I know I should be posting my whole code, and I will at the bottom of the post but im fairly confident im just not declaring my values as the correct type of numbers, here's the bit im falling over on:
//variables:
float s_val[4] = {1100,1100,1100,1100};
float meanSample;
float sqDevSum = 0.0;
int SAMPLES = 4;
//there is some more code here//
 for(int i = 0; i < SAMPLES; i++) {
    // pow(x, 2) is x squared.
    sqDevSum += pow((meanSample - float(s_val[i])), 2);
    Serial.print("s_val - mean squared - ");
    Serial.println(sqDevSum);
you see I have been printing out the values for sqDevSum as that's where the system loses the plot, I am expecting very low values for sqDevSum, the data set is very condensed and the values all very similar while I write the programme, (I plan to ultimately sample data once an hour) so lets say s_val[0] is 1015.23 and the meanSample is 1017.76 (I have verified meansample is correct from an earlier point of the code) that's 1017.76 - 1015.23 = 2.53 and 2.532is 6.4009 so on the first go through the for loop, I would expect to see 6.4009 and three returns of 0 as the s_val array only has info in s_val[0] right at the start, however, this is the Serial readout i get:
13:16:52.334 -> 1028.21
13:16:52.709 -> END OF LOOP
13:16:52.709 -> s_val - mean squared - 594684.68
13:16:52.746 -> s_val - mean squared - 660760.75
13:16:52.746 -> s_val - mean squared - 726836.81
13:16:52.783 -> s_val - mean squared - 792912.87
that figure of 1028.21 is the data point that gets shifted into s_val[0]
Im in well over my head, but im pretty sure im just not handling the numbers as they go through the maths as the correct "type" float, int, etc . . . can anyone see why I get such high values in my readout? here's the whole code, it's in a state of being written, and there's a whole bunch of superfluous i2c stuff going on, but my hunch could well be wrong:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <ds3231.h>
Adafruit_BME280 bme;
ts t; //ts is a struct findable in ds3231.h
float pressureVals[33];
float var;
float meanSample;
float stDev;
float multiplierCheck;
float pressureSum;
float avgPressure;
float sampleSum = 0;
int multiplier;
int SAMPLES = 4;
// -------RTC-------
  Wire.begin(); //start i2c (required for connection)
  DS3231_init(DS3231_INTCN); //register the ds3231 (DS3231_INTCN is the default address of ds3231, this is set by macro for no performance loss)
// --------BME--------
  bme.begin(0x76);
// -------Other-------
  pressureVals[0] = (bme.readPressure() / 100.0F);
  for (int i = 32; i >= 0; i--) {
  pressureVals[i+1] = pressureVals[i];
  Serial.print(pressureVals[i]);
  delay(350);
Serial.print("END OF LOOP");
  s_val[0] = pressureVals[1];
  s_val[1] = pressureVals[3];
  s_val[2] = pressureVals[5];
  s_val[3] = pressureVals[9];
    sampleSum += s_val[i];
  meanSample = sampleSum/float(SAMPLES);
    sqDevSum += pow((float(s_val[i]) - meanSample), 2);
  stDev = sqrt(sqDevSum/float(SAMPLES));
Serial.print("sample sum - ");
Serial.println(sampleSum);
Serial.print("Mean of the Samples - ");
Serial.println(meanSample);
Serial.print("sum the squares of the differences from the mean - ");
Serial.print("hopefully, a standard deviation? - ");
Serial.println(stDev);
Always post ALL your code. In the useless snippet, the value of meanSample is undefined.
Don't use pow() for squares, it is slow and inaccurate. Use multiply instead.
    sqDevSum += (meanSample - s_val[i])*(meanSample - s_val[i]);
What is this line supposed to do? Does the posted code actually compile?
Serial.println(sampleSum);s_val
Otherwise, I don't see a problem. If you do think there is a problem with a given calculation, print out all the starting values, the intermediate values, the final values, and use your calculator to check the results.
@jameath
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Try debug prints on more than just one variable.
@ballscrewbob
I didn't post this anywhere else? I tried to edit a few spelling mistakes and got an angry "your posting too quickly message" that might have re-posted the whole thing? either way, sorry, but I didn't do that.
@jremington
Thanks for the pointer on squares! as that is the line where it all falls over, ill simplify it straight away. it didn't compile any more! looks like I typed into the IDE by mistake, I have amended the post and my code . . . the downsides of having several screens I guess :stuck_out_tongue:
@aarg
that's what I have been doing to find where it all fell over, will post some more returns after making some tweaks, thanks!
jameath:
No, it is not the line where it falls over. He just wanted to clean it up.
aarg:
Cheers, that really helps! thank you so much
You were missing a few steps. Calculating the mean. Taking the mean of the squares. Taking the square-root.
const int SAMPLES = 4;
//variables:
float s_val[SAMPLES] = {1100.0, 1100.0, 1100.0, 1100.0};
float meanSample;
  s_val[0] = 1028.21;
  Serial.print("New sample: ");
  Serial.println(s_val[0]);
  // Calculate meanSample
  float sum = 0.0;
  for (int i = 0; i < SAMPLES; i++)
    sum += s_val[i];
  meanSample = sum / SAMPLES;
  Serial.print("meanSample: ");
  // Calculate standzrd deviation?
    sqDevSum += (meanSample - s_val[i]) * (meanSample - s_val[i]);
  Serial.print("Sum of the squares: ");
  Serial.print("Standrd Deviation: ");
  Serial.println(pow(sqDevSum / SAMPLES, 0.5));  // Square-root of the mean of the squared deviations
void loop() {}
Results:
New sample: 1028.21
meanSample: 1082.05
Sum of the squares: 3865.36
Standard Deviation: 31.09
Hint: there is a mathematical trick for calculating the standard deviation that reduces code and computation:
//variables:
float s_val[SAMPLES] = {1028.21, 1100.0, 1100.0, 1100.0};
float meanSample;
float sdDev = 0.0;
  while(!Serial);
  float sum = 0.0, s2sum=0;
    sum += s_val[i];
    s2sum += s_val[i]*s_val[i];  //sum of squared input values
  sdDev = sqrt(s2sum/SAMPLES-meanSample*meanSample);
  Serial.print("Standard Deviation: ");
  Serial.println(sdDev);  // Square-root of the mean of the squared deviations
void loop() {}
Results:
meanSample: 1082.05
