Hi there,
as far as I read, there is nothing published about any potential incompatibilities between Starter kit Grove Plus V3 (the shield, especially) and Arduino R4 Wifi.
Does some get some experiences with these both ?
Thanks a lot.
Hi there,
Thanks a lot.
I don't own a Grove Starter Kit Plus V3, but I use a product that predates the Grove modules: the CodeShield.
Here are its capabilities:
Inputs: switch, button, potentiometer, rotary encoder, thermistor, photocell, and hall effect sensor.
Outputs: Piezo buzzer, servo motor, RGB LED, LED, and a relay with screw terminals.
I have tested all but the rotary encoder and buzzer on the UNO R4 WiFi.
I used Telemetrix For Arduino Uno R4 for my testing.
So, most likely, the Grove kit will not be a problem.
Hi @MrY , and thnaks for your experience here.
We started a new course and we just wanted to know if we go to R4, from mkr & R3, or if it was too early. I read here & there, and in your words, that it is not too early
Not all Uno R3 libraries are compatible with the R4. This link shows some compatibility problems with the R4.
Good luck with the new course.
Sure. But Core (libraries) are ok. Fortunately, and apparently
