Starting and stopping a blinking light with IR remote?
To start off, I am a beginner programmer, and have only been working on learning Arduino code for a few weeks now. So I apologize for any lack of knowledge I have in 'the basics.'
Now, on to my question... I am working on a project where I control various things (such as LEDs, for example) with an IR remote. I have been able to do basic things like turn an LED off and on, but I am running into trouble with writing loops that continue (such as a blinking light) that starts and stops by using an IR remote.
Here is my code. When I run it, the blinking light starts and does not respond to the IR input. Please let me know if you have any suggestions, I would really appreciate it!
#include <IRremote.h>
int RECV_PIN = 7;
int led = 6;
#define power 0xFD00FF
IRrecv irrecv(RECV_PIN);
decode_results results;
bool blinking = false;
void setup ()
  irrecv.enableIRIn();
  pinMode(led, OUTPUT);
  if (blinking = true) {
    digitalWrite(led, HIGH);
    delay (1000);
    digitalWrite(led, LOW);
    delay (1000);
    digitalWrite(led,LOW);
  if (irrecv.decode(&results)){
    unsigned int value = results.value;
    switch (value) {
      case power:
      if (blinking == false){
        blinking = true;
        blinking = false;
    Serial.println(value);
    irrecv.resume();
(deleted)
Thank you very much for your response! I had to add a couple lines of code in order to make that work, but I was able to get it to work!!
Here is the code for someone in a similar boat.
int RECV_PIN = 7;
int led = 6;
int ledState = LOW;
unsigned long previousMillis = 0;
const long interval = 1000;
void setup ()
  if (blinking == true & (currentMillis - previousMillis >= interval)) {
    digitalWrite(led, !digitalRead(led));
  if (irrecv.decode(&results)) {
    switch (value) {
      case power:
      if (blinking != true){
        blinking = true;
        blinking = false;
    irrecv.resume();
