Starting first project, want someone to double check my code
Hey all.
I just recently started up with Arduino and went through the tutorial for this and I wanted to finally make a project with it, but I'm not sure if I got the code right.
The idea is to have two 3" fans for next to my bed, for the nights when it's too hot to not have a fan on, but too cool to have the overhead fan on.
Even if I pull it apart later, I just wanna start small, you know?
The code I have goes as this (I'm only trying to turn both of them on or off, no changing of speeds yet; baby steps...)
const int fan_1 = 11;
const int fan_2 = 9;
const int button = 2;
int state = 0;
int val = 0;
int old_val = 0;
void setup(){
  pinMode(fan_1, OUTPUT);
  pinMode(fan_2, OUTPUT);
  pinMode(button, INPUT);
void loop (){
  val = digitalRead(button);
  if((val == HIGH) && (old_val == LOW)){
    state = 1 - state;
  delay(10);
    old_val = val;
  if(val == HIGH){
   digitalWrite(fan_1, HIGH)}
   else{
   digitalWrite(fan_1, LOW)}
if(val == HIGH){
  digitalWrite(fan_2, HIGH)
}else{
  digitalWrite(fan_2, LOW)}
Will that work?
Will that work?
You need to learn about the Tools + Auto Format option. You should put all the { on new lines, first.
Why are there two if(val == HIGH) statements?
What is actually connected to pins 9 and 11? Not the fans themselves, I hope. Electric motors draw way too much current to be powered by an Arduino pin.
if(val == HIGH){
   else{
aka
digital write (fan_1, val);
consider changing it slightly like this, which uses your state change (good work there) but is only changing the state of the 'fans' when the button is pressed)
int old_val = 0;
int state = 0;
void loop ()
  int val = digitalRead(button);
  delay(50);//debounce
  if(val == HIGH && old_val == LOW)
    state = !state;
    digitalWrite(fan_1, state);
    digitalWrite(fan_2, state);
  old_val = val;
    state == !state;
Will always be false. But, so what? It's a rather useless test. Nothing happens either way.
PaulS:
Will that work?
Was gonna connect them via breadboard and resistors, is that too much current? (I haven't yet figured out which resistors I need, but will do that tomorrow before I buy the fans).
@AWOL: thanks :smiley: the tutorials didn't include shortcuts like that.
PaulS:
    state == !state;
ok, bully for you... you found a typo
corrected above
