I am trying to run a motor for X seconds if the HC-SR04 sensor gives a distance reading which is less than Y cm. For getting the distance from HC-SR04 following is my code.
class Sonar{
int TrigPin;
int EchoPin;
int MaxDistance; // Maximum range allowed in mm
float TrustFactor;
int PreviousDistance;
//These will change
int CurrentDistance;
public:
Sonar(int trigpin, int echopin, int maxdistance, float trustfactor){
TrigPin = trigpin;
EchoPin = echopin;
MaxDistance = maxdistance;
TrustFactor = trustfactor;
pinMode(TrigPin,OUTPUT);
pinMode(EchoPin,INPUT);
digitalWrite(TrigPin,LOW);
int Measure(){
digitalWrite(TrigPin,HIGH);
delayMicroseconds(10);
int Time = pulseIn(EchoPin,HIGH,5000);
CurrentDistance = Time*0.1715;
if (CurrentDistance == 0 || CurrentDistance > 100){
CurrentDistance = MaxDistance;
return CurrentDistance;
int Filtered(){
CurrentDistance = constrain(PreviousDistance*(1-TrustFactor) + Measure()*TrustFactor,0,MaxDistance);
PreviousDistance = CurrentDistance;
I am using Sonar.Measure() function to get my measurements. I am not using the Filtered() function.
Now I can just use delays to do this job but I also want to monitor the sensor data so if the distance for some reason is greater than Y cm before the end of X seconds then motor needs to turn of. For sake of simplicity we will assume LED pin 13 is the motor and let Y be 6cm and X be 3 seconds.
Here is a state machine I drew, I am not an expert so please bear with me. I might learn something new.
Here is what I want to accomplish.
- In the first step I want to read the distance from sensor using Measure() function.
- If distance<6, then I want to wait for 300ms and read the distance again to confirm if the distance is really <6.
- If within in 300 ms the distance > 6 then I want to go to step one treat it as a bounce.
- If after 300ms the distance is still <6 I finally want to turn on the motor and start a timer for 3 seconds.
- While the motor is running check if distance is still <6 and if not turn off the motor and go to step one.
- After the motor has finished running check if distance > 6 and if not keep checking until it is.
- If the distance > 6 then got to step one which will arm the trigger again.
While doing all this i thought I also need to have enough delay between the ultrasonic measurements so that I do not get garbage data. So i am running state machine code at 100ms delay.
I have given it a try but no success. I am not really good at programming. Here is the code,
Sonar sonar1(12,11,100,0.120); //The last argument is the "Trust Factor" it is a value between 0 and 1
pinMode(13, OUTPUT);
unsigned long previousMillis = 0;
if (currentMillis - previousMillis >= 100){
sm_s1();
if(state_s1 == 4){
digitalWrite(13, HIGH);
if (state_s1 != state_prev_s1){
Serial.print("state = ");
Serial.println(state_s1);
//statemachine
void sm_s1(){
state_prev_s1 = state_s1;
switch(state_s1){
case 0: //RESET
state_s1 =1;
case 1: //START
distance = sonar1.Measure();
if(distance < 60){state_s1 = 2;}
case 2: //GO
t_0_s1 = millis();
state_s1 = 3;
case 3: //WAIT
t_s1 = millis();
if(distance > 60) {state_s1 = 0;}
if(t_s1 - t_0_s1 > 200){
state_s1 = 4;
case 4: //TRIGGRED
state_s1 = 5;
case 5: //WAIT
state_s1 = 5;
What do I need to learn to get this working? What is the best way to accomplish this? Please guide me.
Thank You
