Stepper Controls - Back To Zero Problem
The following code should read the position of steppers from EEPROM, move them to the zero position, make a half turn then stop the motors. In case of an AC fail (opto coupler), it saves the "nowPos" of the steppers on EEPROM for the next boot up.
But if I set a target position of let's say 1024, simulate an AC fail at let's say at 500 and restart the motors go to zero, back to 500 then to 1024 position instead of going to zero and then to 1024.
Where is my mistake ?
  Nano | TPIC6B595
    5V | 2 (VCC)
   GND | GND
    D8 | 8 (SRCLR) - blue
   D10 | 12 (RCK) - green
   D11 | 3 (SER IN) of the first chip - yellow
   D13 | 13 (SRCK) - orange
       | 9 to GND
       | 10, 11,19 to GND
       | 18 (SER OUT) to 3 of the next chip
#include <SPI.h>
#include <EEPROM.h>
const byte motors = 96; // sets of four motors
const byte optoPin = 2; // interrupt pin
const byte clrPin = 8; // TPIC6B595 SRCLR pin8
const byte latchPin = 10; // TPIC6B595 RCK pin12
byte rampSteps = 7; // accel/decel steps
byte rampDelay[motors]; // accel/decel delay between steps
byte lag[motors]; // speed reduction
int velocity[motors]; // signed, for direction
int nowPos[motors], newPos[motors]; // int is 16 rotations max
unsigned long prevMillis, prevMicros, interval, startMicros; // timing
byte val[4]; // TPIC write bytes
bool torque = true; // true is full power, false is half power
bool brownOut; // mains failure detected flag
byte sequence, index; // patterns, motor index
const unsigned int startAddress = 0; // option to change for wear leveling
int targetPos = 1024;
const byte Start = 0;
const byte Go_To_Zero = 1;
const byte Go_To_Target = 2;
const byte Idle = 3;
const byte Write_EEPROM = 255;
  Serial.println("Testing");
  SPI.begin();
  pinMode (optoPin, INPUT_PULLUP);
  pinMode(clrPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  digitalWrite(clrPin, HIGH); // clear all shift register data
  attachInterrupt(digitalPinToInterrupt(optoPin), trigger, RISING);
  EEPROM.get(startAddress, nowPos); // load the saved positions
switch (sequence) {
    case Start:
      for (byte i = 0; i < motors; i++) {
        if (nowPos[i] != newPos[i]) break;}
      sequence = Go_To_Zero; // case 0 is not called anymore
      prevMillis = millis(); // mark start of sequence 1
    case Go_To_Zero:
      if (millis() - prevMillis > 5000) {
        for (byte i = 0; i < motors; i++) newPos[i] = nowPos[i]* -1;
        sequence = Go_To_Target;
    case Go_To_Target:
    for (byte n = 0; n < motors; n++){
      nowPos[n] = 0;}
        for (byte i = 0; i < motors; i++) newPos[i] = targetPos;
        sequence = Idle;
    case Idle:
    sequence = 22; // no such sequence
    case Write_EEPROM: // eeprom write
    Serial.println("AC_FAIL");
          EEPROM.put(startAddress, nowPos);
          while (1); // wait for a reset
  goPos();
void trigger() { // ISR
  startMicros = micros(); // mark the start of a zero crossing
void goPos() {
  while (micros() - prevMicros < 1953); // step interval, motor RPM limitation, 1/(15rpm/60sec*2048steps)= ~1953ms, wait if arrived here too early
  prevMicros = micros(); // update, for next interval
  if (!brownOut && digitalRead(optoPin) && micros() - startMicros > 1200) { // no AC outside the zero crossing
      newPos[i] = nowPos[i]; // stay were you are, or get there after overshoot
      lag[i] = 0; // at full speed
    torque = false; // low power deceleration, to maximise hold-up time
    // rampSteps = 3; // shorten deceleration time
    sequence = 255; // goto an unused case that manages the eeprom writes
    brownOut = true; // no way back, but keep on decelerating
  for (int i = 0; i < motors; i++) {
    if (rampDelay[i]) rampDelay[i]--; // subtract one, do nothing
    else { // step
      if (newPos[i] > nowPos[i]) { // request forwards
        if (velocity[i] >= 0) { // if standing still, or going forwards
          nowPos[i]++; // one step forward
          if (newPos[i] - nowPos[i] < rampSteps) velocity[i]--; // reduce speed if almost there
          else if (velocity[i] < min(rampSteps, rampSteps - lag[i])) velocity[i]++; // increase speed if not there yet
          rampDelay[i] = max(lag[i], rampSteps - velocity[i]); // insert ramp delay
        } else { // if wrong direction
          velocity[i]++; // reduce reverse speed
          if (velocity[i] < 0) nowPos[i]--; // if still reverse, keep on going the wrong way
          rampDelay[i] = rampSteps - abs(velocity[i]); // insert ramp delay
      if (newPos[i] < nowPos[i]) { // request reverse
        if (velocity[i] <= 0) { // if standing still, or going reverse
          nowPos[i]--; // one step reverse
          if (nowPos[i] - newPos[i] < rampSteps) velocity[i]++; // reduce speed if almost there
          else if (abs(velocity[i]) < min(rampSteps, rampSteps - lag[i])) velocity[i]--; // increase speed if not there yet
          rampDelay[i] = max(lag[i], rampSteps + velocity[i]); // insert ramp delay
        } else { // wrong direction
          velocity[i]--; // reduce forward speed
          if (velocity[i] > 0) nowPos[i]++; // if still reverse, keep on going the wrong way
          rampDelay[i] = rampSteps - velocity[i]; // insert ramp delay
    if (newPos[i] == nowPos[i])val[i & 3] = 0; // cut coil power when there
    else {
      if (torque) { // this block for full torque
        switch (nowPos[i] & 3) { // the two LSB translated to motor coils (full step)
          case 0: val[i & 3] = B00000011; break; // two coils at the time
          case 1: val[i & 3] = B00000110; break;
          case 2: val[i & 3] = B00001100; break;
          case 3: val[i & 3] = B00001001; break;
      } else { // this block for low power
          case 0: val[i & 3] = B00000001; break; // one coil at the time
          case 1: val[i & 3] = B00000010; break;
          case 2: val[i & 3] = B00000100; break;
          case 3: val[i & 3] = B00001000; break;
    if ((i & 3) == 3) { // process set of four motors (faster)
      unsigned int chain = val[0] << 12 | val[1] << 8 | val[2] << 4 | val[3]; // concat
      SPI.transfer16(chain); // transfer 4-motor int
  digitalWrite(latchPin, HIGH); // transfer to TPIC driver outputs
  digitalWrite(latchPin, LOW); // latch time ~8us
It looks like you are losing bits 2 and 3 (MSB first). Should you & with F? (edit: 0xf)
Sorry, I don't understand you. The "goPos" function was kindly given to me by WAWA in this forum. I don't have enough programming knowledge to change it. While testing, I noticed loosing 1 step but my question is why I can't zero position the steppers correctly.
This is never going to work.
Pls explain why ?
What guarantees your motors are not moved when powered off?
What guarantees that the starting position is known?
Motors are set with the shaft upwards, they don't move when powered off.
The starting position is the last position read from EEPROM when AC failed.
That's an assumption that may or may not work for N amount of retries, not a guarantee.
I see some trouble here:
Maybe @Wawa can make clear the code chunk in post #2?
The goPos() function has been tested extensively, and contains no errors.
It all started in this thread, where we did establish that fast mains fail detection and the hold-up time of the supply would give us enough time to write stopped and powered down motor positions to EEPROM.
Serial.println("AC_FAIL"); is wasting time, which you don't have.
If you have to use a serial.print, then do it after you have written to EEPROM.
I think the main problem lies here.
EEPROM.get(startAddress, newPos); // newPos[] also has to be loaded
The for loop in case Start: becomes now obsolete.
Leo..
The code I posted is a very short version of my original code.
Here, I'm testing with only 4 motors and not 96. The Serial.print was just to test when I hit that sequence, forgot to erase it.
I tested as your suggestion, i.e. reading newPos from EEPROM and no loop in case Start, but steppers won't home to zero. They do a half a turn from where they stopped at AC fail.
With those two EEPROM lines in setup there should be no movement on startup.
Because the same motor position that has been saved is loaded again (could be any position).
Remaining problems could be in your "Go_To_Zero" code.
Don't know what "zero" is, but can't you just use
for (byte i = 0; i < motors; i++) newPos[i] = 0; // go to zero
instead of
Leo..
Motor positions are held in an int array, nowPos[].
Which one of the four motor coils of the 28BYJ-48 is powered is extracted from that motorPos[] array with bit masking (the two LSBits, & 3 or 0B11).
So if the nowPos value increases/decreases, so does the switch/case coil selector.
This simple bitwise code replaces the otherwise long code you see for these motors.
Leo..
Your plan will ONLY work if you ONLY do full steps for each movement. Your motor will ALWAYS start on a full step position when power is first applied!
Correct. And the code is written for that (4-sequence, fullstep).
Escape (break) until the motors have reached their destination.
Then write to EEPROM.
Leo..
@Wawa, "There should be no movement on startup", but there is ! Given equal positions there should be no movement.
Here, in setup() I put 512 as newPos and nowPos to test.
Motors move 1/4 of a turn with or without the for loop in Start.
  Nano | TPIC6B595
    5V | 2 (VCC)
   GND | GND
       | 9 to GND
       | 10, 11,19 to GND
#include <SPI.h>
#include <EEPROM.h>
const byte motors = 6; // sets of four motors
const byte Zero_At_Start = 1;
  SPI.begin();
for (byte i = 0; i < motors; i++) { // Just for testing
  nowPos[i] = 512;
  newPos[i] = 512;}
 switch (sequence) {
    case Start:
      sequence = Zero_At_Start; // case 0 is not called anymore
    case Zero_At_Start:
        newPos[i] = 0; //stopPos[i] * -1;
        sequence = Idle; //Go_To_Target;
    case Go_To_Target:
      nowPos[n] = 0;}
        sequence = Idle;
    case Idle:
  goPos();
Go 10 steps backwards, and see if this cut-down loop moves the motors.
Run for 10 seconds, then push the reset button.
The motors shouldn't move...
Changed nb_motors from 6 to 4, because that's what the code expects. Sets of 4.
Do you still have that mains opto in circuit. Otherwise connect pin2 to ground during the test.
Leo..
  Nano | TPIC6B595
    5V | 2 (VCC)
   GND | GND
       | 9 to GND
       | 10, 11,19 to GND
#include <SPI.h>
#include <EEPROM.h>
const byte motors = 4; // sets of four motors
  SPI.begin();
  switch (sequence) {
    case 0:
      if (millis() - prevMillis > 5000) sequence = 255; // test 5 seconds for movement
    case 255: // eeprom write
      for (byte i = 0; i < motors; i++) if (nowPos[i] != newPos[i]) break;
  goPos();
void goPos() {
    else { // step
    else {
@Wawa,
I ran your code, I don't understand ..
no movements.
For this test, I'm not using the opto. Just a jumper wire from pin 2 to GND which I disconnect to simulate AC out.
In my full project, I had came up with the following code where instead of reading the nowPos from EEPROM I read a new array called the stopPos. The following code wrks. i.e. moves the steppers back to "zero" position. But only if after that I go to "idle". If after "zeroing" I try to move to a new position "TargetPos", It won't "zero" just goes to targetPos.
Please take a look, it's driving me nuts !
  Nano | TPIC6B595
    5V | 2 (VCC)
   GND | GND
       | 9 to GND
       | 10, 11,19 to GND
#include <SPI.h>
#include <EEPROM.h>
int stopPos[motors];
byte m = 0;
const byte Idle = 6;
  SPI.begin();
  //EEPROM.get(startAddress, nowPos); // load the saved positions
 //EEPROM.get(startAddress, newPos);
  EEPROM.get(startAddress, stopPos);
 //Write_Read_EEPROM();
  stopPos[i] = 512;
  nowPos[i] = 0;
 // newPos[i] = 512;
switch (sequence) {
    case Start:
    case Zero_At_Start:
    if (millis() - prevMillis > 3000) {
        newPos[i] = stopPos[i]* -1;
        sequence = Idle; // Go_To_Target;  <<<<<< !
    case Go_To_Target:
    for (byte i = 0; i < motors; i++){
      nowPos[i] = 0;}
        sequence = Idle;
    case Idle:
  goPos();
Good.
With 10 steps back I meant, forget your sequence for now, and don't add any other band-aids.
Now replace loop() with this loop(). (with the sketch from post#18).
It should sweep between position 0 and 512, and restart exactly the same after a simulated power cut. Assuming the motors have the ability to move freely between those positions.
Leo..
  switch (sequence) {
    case 0:
      if (millis() - prevMillis > 5000) { // test 5 seconds for movement (should be none)
        sequence = 1;
    case 1:
      if (millis() - prevMillis > 5000) { // wait for previous motor movement to complete
        for (byte i = 0; i < motors; i++) newPos[i] = 512; // then go to 512
        sequence = 0; // repeat
  goPos();
