Stepper driver to this stepper motor
Hi.
i am struggelig to find the right stepper drive to power this stepper motor:
2 phase NEMA17 42mm 4-wire stepper motor 1.8deg 1.7A 4.2kg.cm 40(L)mm
Feature:
Brand new and high quality.
2 phase NEMA17 42mm 4-wire stepper motor 1.8deg 12V 1.7A 4.2kg.cm 40(L)mm
For: 3D printers, monitor equipment, medical machinery, textile machinery, packaging machinery, stage lighting and so on .
Wiring: Black Green A +, A- red and Blue B +, B-,.
Adapter Drive JK0220 (drive voltage DC12V ~ 36V, AC12V ~ 24V, current range 0.3A ~ 2.0A).
Electrical Specifications:
Model No. Step Angle Motor Length
Current
/Phase
Resistance
/Phase
Inductance
/Phase
Holding Torque # of leads Detent Torque Rotor Inertia Mass
(°) (L)mm A Ω mH kg.cm No. g.cm g.cm Kg
JK42HS40-1704 1.8 40 1.68 1.5 2.3 4.2 4 150 54 0.40
Specifications:
Model: JK42HS40-1704
phase : 2
Step Angle : 1.8°
Motor length: 40mm
voltage : 12 V
Rated Current : 1.7 A
Rated Power:5 W
Holding torque : 4.2kg.cm
Temperature Rise:80℃max
Ambient Temperature:-20℃~+50℃
Insulation Resistance: 100 MΩMin. ,500VDC
Dielectric Strength: 500VAC for 1minute
Shaft Radial Play: 0.02Max. (450g-load)
Shaft Axial Play: 0.08Max. (450g-load)
Max. radial force: 28N (20mm from the flange)
Max. axial force: 10N
Size: 4.2 x 4.2 x 4 cm/1.65 x 1.65 x 1.57 inch(L x W x H)
Package included:
1pc x 2 Phase 4-Wire Stepper Motor ( JK42HS40-1704 )
Sounds like you need a stepper driver that can handle over 1.7A at 12-36V.
The Pololu A4988 stepper motor driver is popular:
"It operates from 8 V to 35 V and can deliver up to approximately 1 A per phase without a heat sink or forced air flow (it is rated for 2 A per coil with sufficient additional cooling)."
Sounds like those will need heat sinks and a cooling fan.
To get slightly higher power handling you can use the Pololu DRV8825 stepper motor driver:
"It operates from 8.2 V to 45 V and can deliver up to approximately 1.5 A per phase without a heat sink or forced air flow (rated for up to 2.2 A per coil with sufficient additional cooling)."
Sounds like those will still need heat sinks and/or a cooling fan.
You may also be interested in stepper motor basics
...R
Thanks
