stepper motor cycle time
With the attached hardware configuration and code as an example, what would be a reasonable estimate of the time to make a 50 step move?
code.txt (680 Bytes)
For short programs it is much easier for us if you include the code in your post using the code button </> so it is like this
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 200
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepper(STEPS, 8, 9, 10, 11);
// the previous reading from the analog input
int previous = 0;
  // set the speed of the motor to 500 RPMs
  stepper.setSpeed(500);
  // get the sensor value
  int val = analogRead(0);
  // move a number of steps equal to the change in the
  // sensor reading
  stepper.step(val - previous);
  // remember the previous value of the sensor
  previous = val;
With a speed of 500 RPM or 8.333 revs per second the interval between steps will be 120 millisecs (if my maths is correct).
I will leave it to you to calculate the time for 50 steps.
...R
