Stepper motor, LED, Light sensor
Hello everyone,
I tried to make a LED blinking and at the same time a Stepper motor turning. I got both in one loop, but the program goes in the loop only 1 time. So it blinks once and then the motor turns one.
Can you help plz with a solution.
This is my code... and thanks in advance
#include <Stepper.h>
Stepper Motor(1024,2,3,4,5);
int Lightsensor = A0; // Analogen Eingang 0 als Analog0 definieren
int Brightness = 0; // Variabel helligkeit auf 0 setzen
int Limit = 10; // Grenzwert hell-dunkel
Serial.begin(300); //Serial-Übertragung auf 300Baud-reicht völlig
pinMode(10, OUTPUT); //Digitaler-Ausgang 10 für LED-Ansteuerung
Motor.setSpeed(10);
Brightness = analogRead(Lightsensor);
if (Brightness < Limit)
digitalWrite(10, HIGH);
delay(50);
digitalWrite(10,LOW);
delay(50);
Motor.step(100);
delay(100);
Motor.step(50);
delay(100);
Motor.step(100);
digitalWrite(10, LOW);
(I have asked a moderator to move this to Programming where it belongs. It is not about education is it?)
I see nothing obviously wrong with the program, which leaves the possibility that your wiring for the motor is wrong - and it takes so much current that the Arduino goes in a bad state. Do you power the motor through some transistor/mosfet/driverchip or directly of the Arduino pins?
Except for all the delay()s.
Why is this in your code, when there are no Serial.print() statements? Conversely, why are there no Serial.print() statements, to see what the code IS doing?
