I am using stepper motors for a school project, but right now the motors are locking up when I give them power. If I turn down the external power to 3V it is not locked, but it’s also not enough to power the motors. When I give the motors the necessary 12V it locks up and can’t move. Are there any things I can do or test to try and fix this?
tserpico81515:
Then they are working properly. You need a stepper motor controller attached to the stepper motor wires and the controller attached to your Arduino and a test program running in the Arduino to make the stepper move.
Do you have all this and properly powered?
Paul
Yes, I have a easydriver connected to both the motor and arduino and I have a test code
Please read and follow the directions in the "How to use this forum" post.
These links may help
Stepper Motor Basics
Simple Stepper Code
...R
Stepper motors hold position. That's their function.
By changing the position by 1 step (or a fraction of a step), they hold a new position. Repeat rapidly to
produce movement. Give no stepping commands and the motor holds firmly until the power is removed.
