Hello,
Thanks for the help in advance.
I am working on modifying these two projects to suit my own needs.
http://www.bethnchris.com/2014/01/01/diy-gopro-arduino-camera-panning-rig/
To be completely honest I am very new to both programming and electronics so it may be that the answer to my problem is very simple.
I want to be able to spin my camera with the motor at pause at a precise position and continue to do so, pausing in the exact same positions every time. Following the tutorials I posted above I have two gears, one small 12 tooth gear and one larger 84 tooth gear which the camera rests on. The problem I have is that to turn the camera 90 degrees, the stepper motor must make 1.75 rotations currently this takes about 12 seconds and is about 8 or so RPM. I want to to be able to make the full 360 degree rotation on the 84 tooth gear in under 5 seconds ideally, that would be 7 full rotations of the 12 tooth gear and about 85 RPM.
I am using the 28 BYJ - 48 stepper motor. This exact one: http://robocraft.ru/files/datasheet/28BYJ-48.pdf
Is it possible with this motor? Do I need to supply more power? Can I power the motor of a separate power supply than the arduino? Is it a simple code fix?
The Camera I am rotating is the Ricoh Theta S, its fairly light.
Anyway, any help would be appreciated. I wanted to ask for help here before I go out looking for another stepper motor.
Thanks!
Code: Dropbox - Error
