Ok, So i have this new project idea where i had a dial that would be controlled by a stepper motor. basically to reset the dial to position zero programatically. Once this has been reset i want to know if the dial has moved, in what direction and how many step (hopefully the stepper motor can detect 100+ steps per rotation.)
Using the stepper motor through a driver is simple enough, i've done that a half dozen times. the kicker however is to sense when the dial has turned based on feedback from the stepper motor.
It is my understanding that a stepper motor can have current applied to move the motor, but the reverse should be true (albeit to a much smaller degree). I'd like to avoid a hall effect sensor, optical encode or other sensor, to simplify the components.
Has anyone tried something like this? can i even get feedback from the stepper motor? I should, but i haven't tried to scope a stepper motor, but i'm trying to avoid buying a stepper before i know this will work. Also i'd like it if this motor could run rather quickly(1+rps). any suggestions on a good inexpensive motor that would fit these requirements? just to be clear it does need to rotate continuously in either direction.
