Stepper motor with button press
This is my first time owning an Arduino, I have a stepper motor 28BYJ-48 with ULN2003 driver. I am trying to hook up a button press that will rotate it one full rotation clockwise and stop, and repeat one rotation every button press, but I am having difficulty writing this code as this is the first time I’ve done anything like this before. I’ve spent days watching tutorials and reading websites but can’t figure it out. I am stumped. Can anyone tell me what I am doing wrong? This is the current code I have written but it still does nothing when I upload it to the Arduino.
#include <Stepper.h>
// Define constants for the stepper motor
const int stepsPerRevolution = 2048;
const int stepsPerDegree = stepsPerRevolution / 360;
// Define pins for the ULN2003 driver
const int in1Pin = 8;
const int in2Pin = 9;
const int in3Pin = 10;
const int in4Pin = 11;
// Define pin for the button
const int buttonPin = 2;
// Create a new instance of the Stepper class
Stepper motor(stepsPerRevolution, in1Pin, in2Pin, in3Pin, in4Pin);
  // Set the motor speed (RPM)
  motor.setSpeed(10);
  // Set the button pin as input
  pinMode(buttonPin, INPUT_PULLUP);
  // Wait for the button to be pressed
  while (digitalRead(buttonPin) == HIGH) {
    // Do nothing
  // Rotate the motor 360 degrees (one revolution)
  motor.step(stepsPerRevolution);
  // Wait for the button to be released
  while (digitalRead(buttonPin) == LOW) {
    // Do nothing
give the duck a go
I have, as well as maker guides, I can find all kinds of code where you have to hold the button to have it rotate but nothing that triggers a full rotation and stop. I’ve tried pasting several strips of code together with no success
Hi @shrunkenned,
although the way you handle the button is not advisable (there is no "debouncing") you are lucky:
Your sketch works ... I assume that you might not have the correct value here
What kind of stepper motor do you have? You may try this instead
const int stepsPerRevolution = 200;
Even if you leave away the second while() in loop() it should work, because the function
blocks loop() until all steps have been performed. That is the reason why in your sketch debouncing is not necessary ...
This is your sketch but with a few changes and it works in Wokwi simulation:
(see here https://wokwi.com/projects/360659738759204865
Your modified sketch:
// const int stepsPerRevolution = 2048;
//const int stepsPerDegree = stepsPerRevolution / 360;
  motor.setSpeed(50);
    // Do nothing
  Serial.println("Start Rotation");
  Serial.println("Stop Rotation");
ec2021
P.S.: If your sketch does nothing after upload you should probably carefully check your wiring ...!!!
Thank you so much for the reply, very helpful! Will try this when I get home! :slightly_smiling_face:
Try:
Stepper motor(stepsPerRevolution, in1Pin, in3Pin, in2Pin, in4Pin);
If you have not used Wokwi simulation you might find it quite useful to learn coding ...
There are plenty of examples with a lot of different actuators and sensors.
Good luck!
ec2021
Your initial steps per revolution was correct. A BYJ stepper has 2048 steps per revolution not 200.
That was it!!! For whatever reason that fixed it!! Thank you so much!
