Stepper motors getting too hot
Hi
I am using three 5V 28byj-48 Stepper motors with ULN2003 drivers and
the power supply is 12 V 30A.
I did the soldering and wiring to the divers myself and after 20 munits of working or idling the motors got too hot that it hurts when touched.
The wires and drivers were at normal temerture.
Is the problem from the power supply voltoge if so ,should not the drivers take care of it ?
or is the problem from the wiring and soldering ?
Hi, have you checked this old thread? 28BYJ-48 motor running a bit hot on one power supply but not another - #3 by Psychobob
You're running 5v motors off 12v and you don't know why they're getting hot? 2.5x the voltage will certainly get hot! Burn out quickly too it will!
Not a ULN2003. That is not really a motor driver. Those chips were originally used to drive solenoids in old teletype machines. If you were using a modern bipolar stepper with a driver like A4988 or DRV8825 then those drivers do control the current (once correctly set) and the supply voltage is less relevant.
Check the motor winding resistance between the RED wire and any one of the others, if it's around 23 ~ 27 Ohms, it's a 5 volt motor. If around 140 ~ 150, it's a 12 volt.
5V steppers are not designed to be used with 12V power.
There is a 12V variant of the 28BYJ-48, same part number.
Wrong! Power is the square of the voltage, 2.5 * 2.5.... More than 6 times!
A stepper motor's voltage rating is a calculated figure, based off the coil's rated current and its resistance!
The power dissipated by the coil is proportional to the square of the current. Modern stepper drivers are current limiting devices. As long as you hold the current to the motor's heat dissipation capabilities, you will be fine.
Motor coils also present an inductive reactance to rising current. A higher voltage allows the coil current to rise to the desired value more quickly (di/dt is proportional to the current). Higher voltages can be used as long as the current is not exceeded.
Look at this example stepper:
https://www.omc-stepperonline.com/nema-17-bipolar-1-8deg-13ncm-18-4oz-in-0-7a-2-9v-42x42x25mm-4-wires-17hs10-0704s
It is a "2.9V" stepper, there is no mention of voltage in the data sheet.
Steppers run hot. The above data sheet shows the max temp rise is 80 deg C, at a standstill. Steppers draw current to provide holding torque even when not rotating. Unless the controller has a motor disable input.
Here is another reference explaining current and voltage, that may be helpful:
As others have mentioned, you need a good stepper driver that controls current.
https://lastminuteengineers.com/28byj48-stepper-motor-arduino-tutorial/
