I’m about to build a circuit that has two stepper motors that each run at 3v and 1.7a.
They will run off of two TB660’s connected to 1 uno board. I have attached the data sheet for the driver. Each TB660 will be powered by a 12v mains supply.
I have also attached a schematic from the manufactures website.
The drivers will both run when activated by a motion sensor.
Due to the nature of the project I need to place the stepper motors about 2 metres away from the arduino and stepper motor drivers. The motors will not be together, but both 2 metres away from the arduino and driver in opposite directions.
I have read up a bit on using shielded cat 5 wires, but wondered if anyone had any experience. Running stepper motors at distance from the drivers and arduino? And the best ways to go about this?
I have some of these motors and they came with about 1.2m of unshielded cable which seems to work fine. My guess is that you won't have a problem.
As your motors need 1.7 amps I would use heavier cable than what is in CAT5 or CAT6. The more copper the less resistance in the cable. However I am not by any stretch of the imagination an expert in these matters.
Driving the motors with a higher voltage might also be a good idea (subject to the limits of the TB6600 driver). Just make sure to set the current limit on the drivers to match your motors.
I would buy the heavier cable just to be sure. You should be able to find a formula online that allows you work out the difference in resistance between the two sizes of wire.
I would just isolate the unwanted strand so it can accidentally connect to anything. I don't think there is any value in grounding it.
