I am building a project whereby access control is implemented using RFID. When a correct tag is read, the door should open automatically, and close after a delay of a few seconds. I have the code working, but I have been simulating the door with an LED.
I am a student, so I do not have much money, and the project is also urgent. So I was wondering which would be better to use to open and the door; a stepper motor, or servo motor. the constraints being one that will be easier to program as a first priority, and then cost being the second priority.
What do oyu want to do?
- Unlock/lock the door? In this case you can modify the lock with a servo or a solenoid. There are also ready made motor or solenoid locks available
- Opening/closing the door is much harder because of the power needed. And you still have to take care of the locking/unlocking problem. A motor of maybe 100W with a wormgear can do the job of moving the door, but it will not be able to withstand someone trying to force it open. Alinear actuator can be an alternative
I had planned to use a solenoid lock but being from Kenya, a third world country, some parts are hard to come by. Even the lock you are suggesting will be impossible to find.
I have an idea about the working of a servo motor. I just want to demonstrate the pulling and pushing action of the motor attached to the door.
I have a 12 volt dc supply by the way which I am using for other parts of the project
wambui:
It's not clear from your post whether you intend the servo just to release the lock/latch or whether you want it to move the door? Or both, which would need two devices.
...R
Can you get some automotive parts? Maybe from a scrapyard? Windshield wiper motors and electrical door locks might help you
Yes, automotive drives are a good source. Powerful, inexpensive, and readily available and most times, easy to mount. For your application, I don't see the need for a servo or stepper. Seems you can accomplish the project using a dc motor and limit switches. If you chose a worm gear drive, perhaps there would not be need for a lock since you would not be able to force the door manually. - Scotty
Thanks guys. I found a micro servo which is quite cheap and I'll use for cintrolling the latch.
