STM32 timer 2 interrupt handler does not work
Hello,
I try to initialize an interrupt vector for timer 2 that TIM2_IRQHandler is executed. I use a STM32F401CE controller. With the code below the handler TIM2_IRQHandler is never triggered.
Does anybody have an idea which functions I have to execute further to actived a trigger for timer 2?
#include <Arduino.h>
#include "IWatchdog.h"
  /* Set TIMx instance */
  TIM_HandleTypeDef Tim2Handle;
 * Blaue LED initialisieren
void InitBlueLed()
   __HAL_RCC_GPIOC_CLK_ENABLE();
  GPIO_InitTypeDef BoardLEDs;
  BoardLEDs.Mode = GPIO_MODE_OUTPUT_PP;
  BoardLEDs.Pin = GPIO_PIN_13;
  HAL_GPIO_Init(GPIOC, &BoardLEDs);
static void InitTimer2(void)
  Tim2Handle.Instance = TIM2;
Tim2Handle.Init.Period = 32;
Tim2Handle.Init.Prescaler = 2500;
Tim2Handle.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
Tim2Handle.Init.CounterMode = TIM_COUNTERMODE_UP;
Tim2Handle.Init.RepetitionCounter = 0;
Tim2Handle.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
// Timer & Interrupt initialisieren
HAL_TIM_Base_Init(&Tim2Handle);
HAL_TIM_Base_MspInit(&Tim2Handle);
HAL_TIM_Base_Start(&Tim2Handle);
HAL_TIM_Base_Start_IT(&Tim2Handle);
__HAL_RCC_SYSCFG_CLK_ENABLE();
  __HAL_RCC_PWR_CLK_ENABLE();
HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM2_IRQn);
 * Interrupt an Timer 2
void TIM2_IRQHandler(void)
    // Interrupt triggered
    if (TIM2->SR & TIM_SR_UIF)
        HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_13);
     HAL_TIM_IRQHandler(&Tim2Handle);
int main()
  HAL_Init();
  SystemClock_Config();
  InitBlueLed();
  InitTimer2();
int state = 0;
  while (1)
    // LED toggeln
    HAL_Delay(1000);
  return 0;
This isn't an arduino question but I think the order of operations in your timer setup is significant
That's how I would order it, but don't take that as gospel.
You also need to set the clock source. Maybe you should find a good timer example online and follow that. ST Micro has lots of timer application notes.
