Hi Folks ,
First question on the forum and seems to have been asked a million times before .
The sketch just counts passing objects by using an ESP32-cam .
The sketch works perctly as it is except for one thing .
I'm trying to output the results to Excel ,Again that pasrt I can get to work fine then problem is that the numbers just keep scrolling in serial monitor .
I've searched and tried various solutions on the forus over the past week .
The problem is in the loop between lins 80 and 120 when is gets the results of the three Switch cases and then the final result it determins if both directions occur simultaneously .
It hen prints the tresults of "Counter"
I want it to do exactly what it does now but print each result on one line for each and not kepp scrollong untill the state changes .
I just can figure it out .
I've tried adding an int to store the old count and no matter what I do It either won't compile or won't print ant thing .
Can anyone sugest a solution please before I go compleatly mad
Brendan
#define CAMERA_MODEL_AI_THINKER // define the type of the ESP camera
// include the libraries
#include "esp_camera.h"
#include "camera_pins.h"
#include <WiFi.h>
#define FRAME_SIZE FRAMESIZE_QVGA // define the type of the frame size
#define WIDTH 320 //in pixels
#define HEIGHT 240 //in pixels
#define BLOCK_SIZE 10
#define W (WIDTH / BLOCK_SIZE) // in blocks
#define H (HEIGHT / BLOCK_SIZE) //in blocks
// define the scaling factor which means the percent threshold above which we say that the block is actually changed
#define BLOCK_DIFF_THRESHOLD 0.2
//define the number of blocks above which an image is changed
#define IMAGE_DIFF_THRESHOLD 0.2
#define DEBUG 1
/* Start Camera web server
const char* ssid = "nununet 24";
const char* password = "Babyadam!";
void startCameraServer();
/*initialize the variables needed in the program
uint16_t prev_frame[H][W] = { 0 }; // the previous frame
uint16_t current_frame[H][W] = { 0 };
int list[2]={0,0} ; // this list allows us to select only one direction when sereval directions are detected for just one person entering or getting out of the building
int counter = -1 ;
/* define the used funtions
bool setup_camera(framesize_t);
bool capture_still();
int motion_detect();
void update_frame();
void print_frame(uint16_t frame[H][W]);
bool direction_detection ();
int freq(uint16_t frame[H][W],uint16_t a);
Serial.setDebugOutput(true);
Serial.println(setup_camera(FRAME_SIZE) ? "OK" : "ERR INIT");
pinMode(12, OUTPUT); // initialize the GPIO12 pin as an output
pinMode(4, OUTPUT); // initialize the GPIO4 pin as an output
WiFi.begin(ssid, password);
delay(5000);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
delay(5000);
This is the main program where all the functions are called
/* verify that there is no error in detecting the image from the camera */
if (!capture_still()) {
Serial.println("Failed capture");
return;
// the following allows to count the number of people according to the direction of their movement
switch (motion_detect()){
case 0 :
Serial.println("no motion");
list[1]=0;
digitalWrite(12, LOW);
digitalWrite(4, LOW);
case 1 :
Serial.println("get in "); // when a person gets in that means that he is coming from the left side( the motion is detected from the left side of the photo)
list[1]= 1;
digitalWrite(12, HIGH);
case -1 :
Serial.println("get out"); // when a person gets out that means that he is coming from the right side( the motion is detected from the right side of the photo)
list[1]= -1 ;
digitalWrite(4, HIGH);
// if two directions or more are detected simultaneously (within milliseconds) only the first one will be selected
if ((list[0]==0) && (list[1]==1)){
counter= counter+1 ; // if the person is getting in the building +1 is added
}else if ((list[0]==0) && (list[1]==-1)){
counter=counter-1 ; //if the person is getting out the building 1 is substracted
Serial.print(counter) ;
list[0]= list[1]; //the current value will be the preview value
Serial.println("=================");
update_frame();
* Camera setup
bool setup_camera(framesize_t frameSize) {
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_GRAYSCALE;
config.frame_size = frameSize;
config.jpeg_quality = 12;
config.fb_count = 1;
bool ok = esp_camera_init(&config) == ESP_OK;
sensor_t *sensor = esp_camera_sensor_get();
sensor->set_framesize(sensor, frameSize);
return ok;
* Capture image and do down-sampling, this means that the image is divided into blocks instead of pixels in order to reduce noise
* A block is a 10x10 pixels
bool capture_still() {
camera_fb_t *frame_buffer = esp_camera_fb_get();
if (!frame_buffer)
return false;
// set all 0s in current frame
for (int y = 0; y < H; y++)
for (int x = 0; x < W; x++)
current_frame[y][x] = 0;
// down-sample image in blocks
for (uint32_t i = 0; i < WIDTH * HEIGHT; i++) {
const uint16_t x = i % WIDTH;
const uint16_t y = floor(i / WIDTH);
const uint8_t block_x = floor(x / BLOCK_SIZE);
const uint8_t block_y = floor(y / BLOCK_SIZE);
const uint8_t pixel = frame_buffer->buf[i];
const uint16_t current = current_frame[block_y][block_x];
// average pixels in block (accumulate)
current_frame[block_y][block_x] += pixel;
// average pixels in block (rescale)
current_frame[y][x] /= BLOCK_SIZE * BLOCK_SIZE;
#if DEBUG
//Serial.println("Current frame:");
//print_frame(current_frame);
//Serial.println("Preview frame:");
//print_frame(prev_frame);
//Serial.println("---------------");
#endif
return true;
/* this function is used to determin the direction of the movement by dividing the direction matrix
* calculated in motion_detect() function into one right side matrix and one left side matrix,
* the matrix with the higher frequency in "99" shows the direction from which the movement is coming
bool direction_detection(uint16_t frame[H][W]){
// initialize the two direction matrices
uint16_t direc_left[H][W] = { 0 };
uint16_t direc_right[H][W] = { 0 };
for (int y = 0; y < H ; y++) {
for (int x = 0; x < W; x++){
if(x < W/2 ) {
direc_left[y][x] = frame[y][x];
direc_right[y][x] = { 0 };
else {
direc_right[y][x] = frame[y][x];
direc_left[y][x] = { 0 };
//print_frame(direc_left);
//print_frame(direc_right);
Serial.println("....................");
if (freq(direc_right,{99}) > freq(direc_left,{99})) {
//Serial.println("Rechts Richtung");
return false;
} else if (freq(direc_right,{99}) < freq(direc_left,{99})) {
//Serial.println("Links Richtung");
return true;
//else {
//Serial.println("error keine Richtung detektiert ");
* Compute the number of different blocks
* If there are enough, then motion happened
int motion_detect(){
uint16_t changes = {0}; //initialize the number of changed blocks
const uint16_t blocks = (WIDTH * HEIGHT) / (BLOCK_SIZE * BLOCK_SIZE); // set the number of blocks in the picture
uint16_t direc[H][W] = { 0 };
// set the direction matrix to all 0s
{ for (int x = 0; x < W; x++)
{direc[y][x] = {0};}}
// compare the blocks of the current frame with the blocks of the previous frame and calculate the delta factor
for (int y = 0; y < H; y++) {
for (int x = 0; x < W; x++) {
float current = current_frame[y][x];
float prev = prev_frame[y][x];
float delta = abs(current - prev) / prev;
if (delta >= BLOCK_DIFF_THRESHOLD) {
#if DEBUG
//Serial.print("diff\t");
//Serial.print(y);
//Serial.print('\t');
//Serial.println(x);
//delay(100);
changes += 1; //if the block has changed considerably then add one to the number of changed blocks
direc[y][x] = {99} ; // write 99 in the direction matrix refering to the changed block
#endif
//Serial.print("Changed ");
//Serial.print(changes);
if ((1.0 * changes / blocks) > IMAGE_DIFF_THRESHOLD){
if (direction_detection(direc)) {
return 1; // 1 means there is motion from the leftside ==> someone is getting in
return -1 ; //-1 means there is motion from the rightside ==> someone is getting out
return 0; // there is no motion
* Copy current frame to previous
void update_frame() {
prev_frame[y][x] = current_frame[y][x];
* calculate the frequency of a number in a HxW matrix
int freq(uint16_t matrix[H][W],uint16_t a) {
int freq = 0 ;
if (matrix[y][x] == a) {
freq = freq +1 ;
return freq ;
* For serial debugging ürint the frame
void print_frame(uint16_t frame[H][W]) {
Serial.print(frame[y][x]);
Serial.print('\t');
