Stop the loop
Hi guys, can I know anyone have specific idea that how to stop the loop, wait for another execution to take the process? I need to stop the Calc() part then run the checking() part. I've tried sleep method, while(1){}, seem like cannot work, can switch case be used?
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
#include <avr/sleep.h>
#include "EmonLib.h"
#define relay 12
SoftwareSerial SIM900A(7, 8);
LiquidCrystal lcd(11, 10, 5, 4, 6, 2);
EnergyMonitor emon1;
int pulse;
long pulseCount = 0;                              //Number of pulses, used to measure energy.
unsigned long pulseTime,lastTime;                 //Used to measure power.
double power, elapsedkWh;                         //power and energy
char inchar;                                      //Will hold the incoming character from the Serial Port.
char incoming_char=0;
char temp[60];
boolean flag1=0;
int m=0;
float TBill = 0.0;
float realPower= 0.0;
float IBill = 0.00;
int ppwh = 1;                                     //Number of pulses per wh - found or set on the meter.
                                                  //1000 pulses/kwh = 1 pulse per wh
  SIM900A.begin(19200);
  Serial.begin(19200);                             // Setting the baud rate of Serial Monitor (Arduino)
  delay(10000);                                    // give time to log on to network.
  SIM900A.print("AT+CMGF=1\r");                    // set SMS mode to text
  delay(100);
  SIM900A.print("AT+CNMI=2,2,0,0,0\r");            // blurt out contents of new SMS upon receipt to the GSM shield's serial out
  delay(100);
  attachInterrupt(1, onPulse, FALLING);             // KWH interrupt attached to IRQ 1 = pin3
  emon1.current(1, 20);
  pinMode(pulse, INPUT);
  pinMode(relay, OUTPUT);
  delay(100);
  digitalWrite(relay, LOW);
  delay(100);
  Output Results - The result of its calculations are to
  be output to the screen (via Serial port).
  Serial.print(" | Power (W): ");
  Serial.print(power, 2);
  Serial.print(" | Energy (kWh): ");
  Serial.print(elapsedkWh, 3);
  Serial.print(" | Pulse Count: ");
  Serial.print(pulseCount);
  Serial.print(" | Millis: ");
  Serial.print(pulseTime);
  Serial.println(" | ");
  delay(3000);
void checking()
   m=0;
  for (int m=0;m<60;m++)
  if(SIM900A.available() >0)
    incoming_char=SIM900A.read();                   //Get the character from the cellular serial port.
    Serial.print(incoming_char);                   //Print the incoming character to the terminal.
    if(inchar=='0')
        delay(10);
        inchar=SIM900A.read();
        if(inchar=='1')
          delay(10);
            if(inchar=='2')
                    temp[m]=0;
    temp[m]=incoming_char;
 if(temp[50]=='O' && temp[51]=='F' && temp[52]=='F')
          digitalWrite(relay, HIGH);
          SIM900A.println("AT+CMGF=1");                           //Sets the GSM Module in Text Mode
          delay(1000);                                            // Delay of 1000 milli seconds or 1 second
          SIM900A.println("AT+CMGS=\"+60124920726\"\r");          // Mobile number of user
          SIM900A.println("The Switch is OFF");
          SIM900A.println((char)26);                              // ASCII code of CTRL+Z
// The interrupt routine
void onPulse()
//used to measure time between pulses.
lastTime = pulseTime;
pulseTime = micros();
//pulseCounter
pulseCount++;
//Calculate power
power = (3600000000.0 / (pulseTime - lastTime))/ppwh;
//Find kwh elapsed
elapsedkWh = (1.0*pulseCount/(ppwh*1000));                 //multiply by 1000 to convert pulses per wh to kwh
void Calc()
   float IBill = 0.00;
   float Irms = emon1.calcIrms(1480);
   float realPower = (Irms*240*4.86*0.85);
   float Bill = (realPower * 21.80 * 1/3600 * 1/1000);
   float TBill = Bill + IBill;
if (Irms <= 0.0500)
 realPower = 0.00;
 Bill = 0.00;
 TBill = Bill + IBill ;
 else (Irms > 0.0500);
 { realPower = realPower;
 Bill = Bill;
 lcd.setCursor(0, 0);
 lcd.print("Power(W):");
 lcd.print(realPower);
 lcd.setCursor(0, 1);
 lcd.print("Price(C):");
 lcd.print(TBill);
 Serial.print(realPower);
 Serial.print(" ");
 Serial.println(TBill);
    if(TBill<0.25)
        flag1=0;
    if(TBill>0.25 && flag1==0)
          SIM900A.println("Unit: ");                              // Power consumption by user
          SIM900A.println(elapsedkWh);
          SIM900A.println("RM: ");                                // Total cost by user
          SIM900A.println(TBill);
          flag1=1;
You are thinking about the process all wrong. loop() needs to continue to run at all times. Whether it accomplishes anything on a given iteration, or not, is a different story.
Another execution of what? To take what process? Take it where?
You need to understand the event-driven model used in the Arduino - in loop you detect the conditions for
any events you want to handle, then go handle them and resume loop ASAP for handling other events.
Events can be button presses, serial coming in, certain time period passing (see BlinkWithoutDelay example
for that). Everything shares loop(), so has to play fair and not prevent it running.
Have a look at Planning and Implementing a Program
...R
