Stopping a pin from blinking between functions
This section of my project isn't working as intended.
The code is meant to have 2 LED's light separately depending on the state of a button (LED1 HIGH on button push and LED2 HIGH on button lift) and when the button is held down for 2+ seconds the LEDs will change places, or "reverse" their positions.
However, the transition isn't smooth. I'd have hoped that LED1 is HIGH when the button is pushed, mode change is made on the release of the button, then remains HIGH as it now represents the button not being pushed. Somehow LED2 blinks once quicky during this transition.
const int button1 = 2;
const int led1 = 8;
const int led2 = 9;
int buttonStatePrevious = HIGH;
unsigned long minButtonLongPressDuration = 2000;
unsigned long buttonLongPressMillis;
bool buttonStateLongPress = false;
const int intervalButton = 50;
unsigned long previousButtonMillis;
unsigned long buttonPressDuration;
unsigned long currentMillis;
bool reverse = false;
  pinMode(button1, INPUT_PULLUP);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
void readButtonState() {
  if(currentMillis - previousButtonMillis > intervalButton) {
   int buttonState = digitalRead(button1);
//PRESSED
    if (buttonState == LOW && buttonStatePrevious == HIGH && !buttonStateLongPress) {
      buttonLongPressMillis = currentMillis;
      buttonStatePrevious = LOW;}
    buttonPressDuration = currentMillis - buttonLongPressMillis;
//LONG PRESS
    if (buttonState == LOW && !buttonStateLongPress && buttonPressDuration >= minButtonLongPressDuration) {
      buttonStateLongPress = true;}
//RELEASED
    if (buttonState == HIGH && buttonStatePrevious == LOW && buttonStateLongPress == false) {
      buttonStateLongPress = false;}
//RELEASED LONG
    if (buttonState == HIGH && buttonStatePrevious == LOW && buttonStateLongPress == true) {
      reverse = !reverse;}
    previousButtonMillis = currentMillis;}
  currentMillis = millis();
  readButtonState();
  if (reverse == false){
    if (buttonState == LOW){
    digitalWrite(led1, HIGH);
    digitalWrite(led2, LOW);}
   if (buttonState == HIGH){
    digitalWrite(led1, LOW);
    digitalWrite(led2, HIGH);}
  if (reverse == true){
  • Please format your sketch with
  • Please place { and } on separate lines by themselves.
Always show us a good schematic of your proposed circuit.
Show us good images of your ‘actual’ wiring.
Give links to components.
  • When the switch is pressed, enable a boolean enableTimer.
    Restart the 2 second TIMER.
  • When enableTimer is enabled, check to see if the TIMER has expired.
    If it has, reverse . . .
    Disable enableTimer
  • Disable enableTimer when switch is released.
You are using an additional reading of the button, that is confusing or subverting your button handling code.
One simple change
  readButtonState();
  //  int buttonState = digitalRead(button1);
  int buttonState = buttonStatePrevious;
to set your local buttonState to that which the readButtonState() develops will fix you up.
There are other ways to handle the issue.
I recommend using the IDE Auto Format tool on your code. If you are planning to share sketches with others, like here for help, it is polite to put the code in one of a few common styles. Auto Format will put it in an unoffensive and readable format.
a7
