wenn du einen Sketch postest, könnte man sich das sogar ansehen, was da falsch ist.
Hier mit meiner LCD Library.
Wenn du aber die #define änderst auf deine alte Liquid Crystal dann sollte es auch klappen.
LCD KeyPad Shield
This is an example sketch a LCD KeyPad Shield
with 4 buttons connected to ADC 0.
My shield comes with following print on the PCB:
DFROBOT
Drive the Future
credits:
There can be found various variants of this sketch in the web, I don't remember the "real" owner.
However, this sketch has some adoptions for the new Noiasca LCD Library.
Version 2020-10-24
const byte cols = 16; // columns/characters per row
const byte rows = 2; // how many rows
const byte rs = 8;
//const byte rw = 255; // set to 255 if not used - for future use
const byte en = 9;
const byte d4 = 4;
const byte d5 = 5;
const byte d6 = 6;
const byte d7 = 7;
const byte bl = 10; // set to 255 if not used
#include <NoiascaLiquidCrystal.h> // download from https://werner.rothschopf.net/202009_arduino_liquid_crystal_intro.htm
#include <NoiascaHW/lcd_4bit.h> // parallel interface, 4bit
LiquidCrystal_4bit lcd(rs, en, d4, d5, d6, d7, bl, cols, rows); // create lcd object
const byte arrowUp[8] = {0b00000, 0b00100, 0b01110, 0b10101, 0b00100, 0b00100, 0b00100, 0b00000};
const byte arrowDown[8] = {0b00000, 0b00100, 0b00100, 0b00100, 0b10101, 0b01110, 0b00100, 0b00000};
enum {btnRIGHT, btnUP, btnDOWN, btnLEFT, btnSELECT, btnNONE};
// define some values used by the panel and buttons
byte lcd_key = 0; // the pressed button
int adc_key_in = 0; // the readed ADC value
int adc_old = 0; // the previous ADC value
// read the buttons
byte read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
Serial.println(adc_key_in);
// my buttons when readed are centered at these values: 0, 99, 254, 407, 639
// we add approx 50 to those values and check if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this...
lcd.begin(); // start the display
lcd.backlight();
lcd.createChar(5, arrowUp);
lcd.createChar(6, arrowDown);
lcd.setCursor(0, 0);
lcd.print(F("LCD KeyPad Shield ")); // print a simple message
lcd_key = read_LCD_buttons(); // read the buttons
if (adc_old / 4 != adc_key_in / 4) // only print the new value, if different to the old one - avoids flickerin of LCD
lcd.setCursor(7, 1);
if (adc_key_in < 1000) lcd.print(" ");
if (adc_key_in < 100) lcd.print(" ");
if (adc_key_in < 10) lcd.print(" ");
lcd.print(adc_key_in);
adc_old = adc_key_in;
lcd.setCursor(12, 1);
lcd.print(millis() / 1000); // display seconds elapsed since power-up
lcd.setCursor(0, 1);
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
lcd.print(F("RIGHT "));
case btnLEFT:
lcd.print(F("LEFT "));
case btnUP:
lcd.print(F("UP "));
case btnDOWN:
lcd.print(F("DOWN "));
case btnSELECT:
lcd.print(F("SELECT"));
case btnNONE:
lcd.print(F("NONE "));
