Store time data from a SIM900 - Arduino Uno
Hello,
First of all, English is not my mother tongue; please excuse any errors on my part.
I'm an internship for my studies in a Electronic/Programming business, and i'm a noob in Arduin so i may need your help if it's possible. I went to the french forum but i got no answer at all, so now i'm here.
I'm using an Arduino UNO with a SIM900 module from Epalsite ( http://wiki.epalsite.com/index.php?title=SIM900_Quad-Band_GPRS_shield_with_Micro_SD_card_slot )
I want to store the time that i get from the AT+CCLK command in some variables.
I succeded to connect the my SIM to the network, sent sms and see the time i get on the serial, but here i'm stuck. I'm completely unable to write decent data time on the variables.
This doesn't seem very complicated to do (theoretically speaking), so i guess i'm missing something, somewhere.
I tried many codes, some of mine, some that i found on the web, some mix of both...but again, i get no satisfying results, and I am starting to despair of this..
This is the last code i used :
#define DEBUG //  Mode debogage
#include <SoftwareSerial.h>
SoftwareSerial SIM900(2,3);
int i=0;
#define CCLK_MSG_LEN 28  // le nombre total de caractère dans le message CCLK
#define TIME_STR_LEN 18  // le nombre actuel de caractère
char timeStr[TIME_STR_LEN];
char timePreamble[] = "CCLK: \"" ;
int dateToDecimal(char * date){
 int value = ((date[0] - '0') * 10) +  (date[1] - '0');
 return value;
boolean getTime(){
  // Check for available bytes
 if(SIM900.available() < CCLK_MSG_LEN )
    return false;  // Pas assez de caractère pour un message complet
   if(SIM900.read() != '+')
     return false;  // Pas encore synchronisé
     for(int i=0; i < strlen(timePreamble); i++) {
       if(SIM900.read() != timePreamble[i] )
         return false; //  Fin si les données reçues ne remplissent pas le preamble
     // Preamble checked.  Début des données temporelles
     for(int i=0; i < TIME_STR_LEN; i++)
       timeStr[i] = SIM900.read();
     return true; // timeString rempli avec des données valables
void GetSIM900()
  delay(2000);
  if(SIM900.available())
    Serial.print("\n");
    delay(3000);
    while(SIM900.available())
      Serial.print((char)SIM900.read()); // On vide la mémoire tampon du SIM900
    Serial.print("\n");
  SIM900.begin(9600);
  Serial.println("configuration par defaut");
  SIM900.println("ATZ"); // Pour remettre les configuration par defaut
  GetSIM900();
   Serial.println("affichage du numero des erreurs");
   SIM900.println("AT+CMEE=1"); // Pour afficher le numero de l'erreur
  GetSIM900();
  Serial.println("Code PIN");
  SIM900.println("AT+CPIN=1379"); // Code PIN
  GetSIM900();
  delay(5000); // Connexion au réseau
  #ifdef DEBUG
  Serial.println("Operateur");
  SIM900.println("AT+COPS?"); // Opérateur
  GetSIM900();
  delay(5000);
      //SET center number server needed for free provider
  Serial.println("envoi de la commande: AT+CSCA=\"+33689004000\"");
  SIM900.print("AT+CSCA=\"+33689004000\"\r");
  GetSIM900();
  Serial.println("Etat de la connexion au reseau :");
  Serial.println("La connexion est etablie si +CREG: 0,1");
  SIM900.println("AT+CREG?"); // Connexion au réseau
  GetSIM900();
  #endif
  Serial.println("Tentative de récupération de l'heure");
  //SIM900.println("AT+CLTS=1"); // Il semblerait que cette ligne soit optionnelle
 // GetSIM900();
  SIM900.println("AT+CCLK?");
  GetSIM900();
  Serial.println("Activation du mode SMS");
  SIM900.println("AT+CMGF=1"); // Activation du mode SMS
  GetSIM900();
  Serial.println("Envoi du numero de telephone");
  SIM900.println("AT+CMGS=\"+33782764416\""); // Envoi du numéro de téléphone
  GetSIM900();
  Serial.println("Corps du message");
  SIM900.println("Bonjour"); // Corps du message
  Serial.println("CTR+Z");
  SIM900.write(0x1A); // CTR+Z
  GetSIM900();
  int years, months, dates, hours, minutes, seconds;
 if (SIM900.available())
 SIM900.println( "AT+CCLK?" );
 if(getTime() == true){
   delay(120000); //2 minutes
   years    = dateToDecimal(&timeStr[0]) ;
   months   = dateToDecimal(&timeStr[3]) ;
   dates    = dateToDecimal(&timeStr[6]) ;
   hours    = dateToDecimal(&timeStr[9]) ;
   minutes  = dateToDecimal(&timeStr[12]) ;
   seconds  = dateToDecimal(&timeStr[15]) ;}
//else Serial.println("Ada yang salah");
   Serial.print("YY/MM/DD HH:MM = ");
   Serial.print(years,DEC);
   Serial.print("/");
   Serial.print(months,DEC);
   Serial.print("/");
   Serial.print(dates,DEC);
   Serial.print("  ");
   Serial.print(hours,DEC);
   Serial.print(":");
   Serial.println(minutes,DEC);
   delay(2500);
I think my function getTime never get a true response, but i don't know how to make it works. So at the end of the program, i get non-sense value on the serial port.
Any help would be really appreciated.
Why am i the only one not getting answers ?...
Print how many characters are available when getTime() is called. Print how many are needed to constitute a response.
Understand that getTime() and GetSIM900() are reading the same source of data. Explain how that is going to work.
