storing an array of bytes into a DeviceAddress object (onewire devices)
I have a project hooked up with a single dallas ds18b20 temp sensor. As of now I stored the unique address in the code and accessed the devices which is supposed to be faster than accessing them by index and my project is taking up a lot of overhead as is.
I am now banging my head trying to figure out how to make it so I can plug ANY ds18b20 into the device as my project is to be completely modular and has all replaceable parts.
I need to read the address which gets stored into an array containing 8 bytes as per the generic example then I need to store that in a variable of type DeviceAddress (which is an array of 8 uint8 elements from the DallasTemperature library) that I would name myTempSensorAddress.
Im pretty new to having to use all these data types and it is making my head hurt. Any help?
This is from DallasTemperature.h
typedef uint8_t DeviceAddress[8];
It gets called in my code like this above void setup()
DeviceAddress myThermalSensorAddress = { 0x28, 0x4B, 0x43, 0x3D, 0x07, 0x00, 0x00, 0x9B };
Now I just need a way of making myThermalSensorAddress = the 8 byte array instead.
You need to make the array named myThermalSensorAddress equal WHAT 8 byte array?
PaulS:
the addr array down below. the function search(addr) returns the address of the onewire device. I need to store that in the DeviceAddress from DallasTemperature library from my example above.
void loop(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
Serial.print("No more addresses.\n");
ds.reset_search();
delay(250);
return;
Do you understand that DeviceAddress is not a real type? The name is an alias for a byte array with 8 elements.
DeviceAddress daAddr = { 0x28, 0x4B, 0x43, 0x3D, 0x07, 0x00, 0x00, 0x9B };
byte baAddr[8] = { 0x28, 0x4B, 0x43, 0x3D, 0x07, 0x00, 0x00, 0x9B };
do EXACTLY the same thing.
how do I access the element index of DeviceAddress? I notice it lacks the [] brackets. I would test it but I am away from my project.
as simple as this?...
for (int x = 0; x <8; x++)
DeviceAddress[x] = addr[x];
It doesn't lack them. It is just that the typedef statement hides the actual declaration of the array.
DeviceAddress someAddr = {0x10, 0x20, 0x30, 0x40, 0x50, 0x60, 0x70, 0x80 };
for(byte b=0; b<8; b++)
   Serial.print(someAddr[b], HEX);
   Serial.print(" ");
csheffield90:
Close, but since your variable is named myThermalSensorAddress you use:
  myThermalSensorAddress[x] = addr[x];
johnwasser:
yeah that is what I meant. Its been a long night. Thanks.
I know this is very old but it contains very helpful posts and I needed to say thank you to all that participated!
I've been searching hours to find this perfect example for a newbie like me.
The key message was "Do you understand that DeviceAddress is not a real type? The name is an alias for a byte array with 8 elements"
I can now read all my sensors (20 of them) and store them in my two dimensional byte array for later use.
byte DS18B20_DeviceByteAddresses[20][8];
// as you read the device addresses with one of the many examples call this procdure
// to store the Device Address in the DS18B20_DeviceByteAddresses array.
void Temperature_storeDeviceAddress(int position, DeviceAddress deviceAddress) {
	// function to convert a device address in a printable string
	for (uint8_t i = 0; i < 8; i++) {
		DS18B20_DeviceByteAddresses[position][i] = deviceAddress[i];
void Temperature_printAllDS18B20() {
	sensors.requestTemperatures();
	byte addr[8];  // temp storage as we put the serial number back together
	for (int i = 0; i < 20; i++) {
		Serial.print("Device: "); Serial.println(i);
		// put the address back together
                for (int f = 0; f < 8; f++) {
	               addr[f] = DS18B20_DeviceByteAddresses[i][f];
		Serial.print("Serial: "); Temperature_printAddressDS18B20(addr); Serial.println("");
                float tempC = sensors.getTempCByIndex(i); // call by index number
		Serial.println(tempC);
		float tempC = sensors.getTempC(addr);  // call by stored device address
void Temperature_printAddressDS18B20(DeviceAddress deviceAddress) {
	// function to print a device address
		if (deviceAddress[i] < 16) Serial.print("0");
		Serial.print(deviceAddress[i], HEX);
I'm curious if there is a better way but after hours of playing and reading different examples most of which required me to hard code the Device Address into variables I'm really quite happy with this.
Kev
@bionicbone
I believe your code is exactly what I have been searching for going on two days now. I haven't started working with it quite yet, but is there anyway you can post more of the code/setup you are using?
The Arduino I have setup will have a handful of sensors that I want outputted by Serial for processing with a Raspberry Pi. Your code will give me the ability to have multiple temperature sensors without already knowing their device address.
Thank you VERY MUCH for posting what you have so far! My code looks like this (I'm still in the process of testing and trying to figure out how to output my data and addresses in the correct format):
#include <OneWire.h>
#include <DallasTemperature.h>
int tp = 5; // temperature power
int ti = 7; // temperature input
int loopDelay = 2000; // loop delay
OneWire ow(ti);
DallasTemperature sensors(&ow);
DeviceAddress device;
uint8_t* devices;
int deviceCount;
void setup(void)
  pinMode(ti,INPUT); // setup temp pin
  digitalWrite(ti,LOW); // turn down temp input
  pinMode(tp,OUTPUT); // setup temp power pin
  // Setup oneWire sensors for initial read
  digitalWrite(tp,HIGH); // turn on power to temp
  sensors.begin();
  sensors.begin();
  if (!sensors.getAddress(device, 0)) Serial.println("Unable to find address for Device 0");
  //Serial.print(device[2],HEX);
  Serial.print(sensors.getAddress(device[1], 0));
  deviceCount = sensors.getDeviceCount();
  for (int i = 0; i < deviceCount; i++) {// Create w1 device index array
    DeviceAddress devices[i];
    if (sensors.getAddress(devices[i],i));
  Serial.print(sizeof(devices[0]));
  Serial.print(deviceCount);
  //devices = sensors.getDeviceCount();
  //if (digitalRead(tp)) digitalWrite(tp,LOW); // turn off power to temp
  Serial.print("[");
  get1w();
  Serial.println("]");
  delay(loopDelay);
void get1w()
  //if (!digitalRead(tp)) digitalWrite(tp,HIGH); // turn on power to temp
  uint8_t address[8];
  int* count = 0;
    sensors.setResolution(&devices[i],9);
    Serial.print(sensors.requestTemperaturesByAddress(&devices[i]));
      if (count>0) Serial.print(",");
      Serial.print("'");
      for (int j = 0; j < 8; j++)  {
        Serial.print(sizeof(&devices[i]));
        if (j < 1) Serial.print("-");
      count++;
  //Serial.print(devices);
  //ow.reset_search();
  /*if (ow.search(address))  {
    do {
      // Print Sensor ID
      Serial.print("'");
        //addr += address[i].toChar();
        //if (i<1) addr += "-";
        //if (address[i] < 16) Serial.print("0");
        Serial.print(address[i]);
        if (i < 1) Serial.print("-");
      Serial.print("':");
      // Print Sensor Data
      sensors.setResolution(address,9);
      float tempC = sensors.getTempC(address);
      Serial.print(tempC);
      count++;
    while (ow.search(address));
This is very doable with the Arduino-Temperature-Control-Library that everyone uses. But, here's a Wrapper Library to go with it that makes this task a little easier. Check out the example program.
Thanks for the quick reply. I'll be honest though, I'm new to Arduino programming and the wrapper you posted is way over my head. I wish I had the time to devote to learning more about the language but I'm behind as it is.
I was hoping to get bionicbone's code as a launch pad to make mine work.
Thanks again.
Here is my completed code if anyone is interested in the future. I set it up for debugging, which I'll remove for production.
bool DEBUG = false;         // for outputting debugging information
bool stopFlag = false;      // stopFlag: when true, loop will stop processing
int serialByte;             // variable for receiving commands from serial
boolean newData = false;    // does new data exist?
int tp = 5;                 // digital pin number for temperature sensor power (4.7v)
int ti = 7;                 // digital pin number for temperature sensor input
int loopDelay = 2000;       // loop delay in milliseconds
byte tempDevices[5][8];     // Up to five temperature sensors
int tempDeviceCount;        // temperature sensor count
OneWire ow(ti);
void setup(void)
  Serial.begin(9600); // Start serial port
  sensors.begin(); // initialize sensors
  sensors.begin(); // sensors need to be initialized twice or all sensors won't be detected
  tempDeviceCount = sensors.getDeviceCount(); // temperature devices
  if (!tempDeviceCount) { // if can't find temperature sensors, turn on debugging and trouble shoot
    tempTroubleshoot();
  if (DEBUG) {
    Serial.print("Device Count: ");
    Serial.print(tempDeviceCount);
  for (int i = 0; i < tempDeviceCount; i++) {// Create w1 device index array
    if (sensors.getAddress(tempDevices[i],i)) ;
  //if (digitalRead(tp)) digitalWrite(tp,LOW); // turn off power to temp after setup is complete
  Serial.flush();
void serialEvent() { // Get Serial Data and Process
  if (Serial.available()) {
    serialByte = Serial.read();
    newData = true;
    processNewData();
void processNewData() { // process new data received from serial port
  if (newData) {
    if (serialByte == 84) { // Byte: 84 ("T")
      // Do something with Temperature setting
    else if (serialByte == 43) { //Byte: 43 ("+")
      // Increase coeffecient value by 0.1
    else if (serialByte == 45) { //Byte: 45 ("-")
      // decrease coeffecient value by 0.1
    else if (serialByte == 68) { // Byte: 68 ("D") - Turn on debugging
      DEBUG = true;
    else if (serialByte == 100) { // Byte: 100 ("d") - Turn off debugging
      DEBUG = false;
    else if (serialByte == 108) { // Byte: 108 ("l" or lowercase L) - Turn off Loop
      stopFlag = true;
      Serial.print("\n************************\nSTOPPING MAIN FUNCTION\n************************\n\n");
    if (DEBUG) { // output serial data if DEBUG is true
      Serial.print("/nNew Serial Data: ");
      Serial.println(serialByte);
    newData = false;
//void stopLoop () if (!stopFlag) return;
  if (!DEBUG) Serial.print("[");
  else Serial.println("DEBUG MODE");
  getTemps();
  if (!DEBUG) Serial.println("]");
  delay(loopDelay);
  while (stopFlag) { } // stop main function
void getTemps() {
  sensors.requestTemperatures(); // Instructions to get temps
  delay(250);
  if (DEBUG) {
    Serial.print("Devices: ");
    Serial.println(tempDeviceCount);
  for (uint8_t i=0;i<tempDeviceCount;i++) { // loop through devices
    if (i>0) Serial.print(",");
    Serial.print(getTempByDevice(tempDevices[i])); // print temperature
    if (DEBUG) {
      Serial.print("\nLoop Counter: ");
      Serial.println(i);
float getTempByDevice(DeviceAddress deviceAddress) {
  byte addr[8];
  if (DEBUG) Serial.print("addr: ");
  Serial.print("'");
    addr[f] = deviceAddress[f];
    Serial.print(addr[f],HEX);
    if (f < 1) Serial.print("-");
  if (DEBUG) {
    Serial.print(" addr sizeof: ");
    Serial.print(sizeof(addr));
  Serial.print("':");
  if (DEBUG) {
    Serial.print("\nTemperature sensor reading: ");
  return tempC;
void tempTroubleshoot() {
    DEBUG = true;
    // trouble shooting
    if (!digitalRead(tp)) { // Step 1: Check power on sensor pin
      Serial.print("No power to temperature sensor pin ");
      Serial.println(tp);
    // other trouble shooting options
I have a question as this is something I've been searching for as the onewire bus reindexes the sensors if one goes down, the question I have is, trying to understand the multi array.
in the code you have declared.
and later you have this
even though you have been given a declared size, if the tempDevices is less would it only account for less and leave the rest empty, and what happens if you don't know how many sensor devices you are going to use is there a correct method to leave the size open e.g something like.
byte tempDevices[][8];     // Up to five temperature sensors
I'm still new at this and my job doen't allow me to use this everyday its every now and again. thanks in advance. fingers crossed.
As far as I can tell, this question was answered in Your Previous Thread.
