Storing struct variables in EEPROM PROBLEMS
Hi to all. I've this sketch, surely simple for the vast majority of you but it doesn't work for me.
// Storing struct variables in EEPROM
// Sequential read / write of variables.
#include <EEPROM.h>
#define BUTTON_TEST 5
#define EEADDR 0  // Start location to write EEPROM data.
// Put variables into structure.
struct Settings_s {
  char SSID[21];  // Always number of characters + 1 (null)
  char PASS[21];
  float BlrPWR;
  float maxSuppTemp;
  float minOutdTemp;
  float SetPoint;
  float SetBack;
Settings_s Settings = { "SSID012345678", "01234567890123456789", +20000.00, +60.00, -5.00, +21.00, +19.00 };
void show_vars(Settings_s *p) {
  Serial.print("SSID       :");  Serial.println(p->SSID[21]);
  Serial.print("PASS       :");  Serial.println(p->PASS[21]);
  Serial.print("BlrPWR     :");  Serial.println(p->BlrPWR);
  Serial.print("maxSuppTemp: "); Serial.println(p->maxSuppTemp);
  Serial.print("minOutdTemp: "); Serial.println(p->minOutdTemp);
  Serial.print("SetPoint   :");  Serial.println(p->SetPoint);
  Serial.print("SetBack    :");  Serial.println(p->SetBack);
  pinMode(BUTTON_TEST, INPUT_PULLUP);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  Serial.println("EEPROM struct read and write.");
  // Read EEPROM
  EEPROM.get(EEADDR, Settings);
  show_vars(&Settings);
  static unsigned long timeWas, timeNow;
  int a = 0;
  Settings.SSID[21] = a++;
  Settings.PASS[21] = a++;
  Settings.BlrPWR = a++;
  Settings.maxSuppTemp = a++;
  Settings.minOutdTemp = a++;
  Settings.SetPoint = a++;
  Settings.SetBack = a++;
  Serial.println("Press button to write struct to EEPROM");
  if (digitalRead(BUTTON_TEST) == 0) {
    digitalWrite(LED_BUILTIN, HIGH);
    timeWas = micros();
    EEPROM.put(EEADDR, Settings);
    timeNow = micros();
    Serial.println("EEPROM Written");
    Serial.print("EEPROM Write time  (us)         :"); Serial.println(timeNow - timeWas);
    Serial.print("EEPROM Write time per byte (us) :"); Serial.println((timeNow - timeWas) / (sizeof(Settings)));
The serial monitor presents these data:
SSID :ÿ
PASS :ÿ
BlrPWR :nan
maxSuppTemp: nan
minOutdTemp: nan
SetPoint :nan
SetBack :nan
EEPROM Written
SSID :
PASS :
BlrPWR :2.00
maxSuppTemp: 3.00
minOutdTemp: 4.00
SetPoint :5.00
SetBack :6.00
EEPROM Write time (us) :64152
EEPROM Write time per byte (us) :1034
I ask for your suggestions, thanks and regards,
What do you get when put an integer into the last slot of an array of characters?
Try setting the components of your structure to sensible values.
Also and BTW, since you declare
    int a = 0;
a will be recreated and set to zero every time you loop
Also, you read eeprom into the struct variable right away in setup(). Call show_vars() first. At least then you would see your initial values.
a7
char SSID[21];
char PASS[21];
The elements of the array are zero indexed, and the index numbers for an array of size 21 are 0-20. You are writing out of bounds.
There is no reason to give an index to a null-terminated char array, especially when you are indexing past the end of the array:
  Serial.print("SSID       :");  Serial.println(p->SSID);
  Serial.print("PASS       :");  Serial.println(p->PASS);
You need to convert the integer to text when storing to a char array.
  int a = 0;
  itoa(a++, Settings.SSID, DEC);
  itoa(a++, Settings.PASS, DEC);
< edit >
Getting an accurate time measurement for put() is going to be difficult. The EEPROM is read first, compared with the value being written, and only written to EEPROM if the value differs (this is done for each byte of the struct). To get the maximum write time, you will need to read the data from EEPROM, then alter the value of every byte, before doing the write. If you just read the data from EEPROM, and immediately write back to EEPROM with no changes, then no actual writes will be done.
Thanks to the three of you, alto777, cattledog and david_2018, I understand that I have at least 3 errors but I have not been able to understand any of them.
Could you give me the line or lines with the corrected code? Please excuse my ignorance.
Once again, thank you for your time and attention.
Yes, good eye.
@Breixo, first, move
  int a = 0;
to outside the loop, or change it where it is to
  static int a;
this will give you an a that will remember and grow as you increment it, not start over every loop.
Next, using @david_2018's suggestion for the character arrays, write
  static int a = 0; // or make a global
HTH
forum tip: we get notified if you proceed out user names with an at sign '@', @alto777 <- like that, so you can scare someone up who may have turned his attention to the grill and lost interest in other things…
a7
Single character variable names are bad form.
(Searching for 'a' will highlight every instance of a in your sketch - not helpful.)
Thanks, @alto777, something has improved but...
SSID :0 (It should appear: SSID012345678)
PASS : (It should appear: 01234567890123456789)
BlrPWR :20000.00
maxSuppTemp: 60.00
minOutdTemp: -5.00
SetPoint :21.00
SetBack :19.00
EEPROM Written
SSID :1 (?)
PASS : (?)
BlrPWR :16.00 (?)
maxSuppTemp: 17.00 (?)
minOutdTemp: 18.00 (?)
SetPoint :19.00 (?)
SetBack :20.00 (?)
EEPROM Write time (us) :80144
EEPROM Write time per byte (us) :1292
Please post your latest code.
Here it is (I followed @anon85221860's recommendation to avoid single char as a var).
#include <EEPROM.h>
struct Settings_s {
  char PASS[21];
  float BlrPWR;
  float maxSuppTemp;
  float minOutdTemp;
  float SetPoint;
  float SetBack;
  // Read EEPROM
  //show_vars(&Settings);
  /*int a = 0;
  static int eeaddress;
  itoa(eeaddress++, Settings.SSID, DEC);
  itoa(eeaddress++, Settings.PASS, DEC);
  Settings.BlrPWR = eeaddress++;
  Settings.maxSuppTemp = eeaddress++;
  Settings.minOutdTemp = eeaddress++;
  Settings.SetPoint = eeaddress++;
  Settings.SetBack = eeaddress++;
    timeWas = micros();
    timeNow = micros();
You are still incorrectly using an index on the arrays in the show_vars function.
The values you see are going to depend on how many times loop() has executed at the time you press the button
Thanks, david_2028, I'm sorry but what should the sentence be?
#include <EEPROM.h>
struct Settings_s {
  char PASS[21];
  float BlrPWR;
  float maxSuppTemp;
  float minOutdTemp;
  float SetPoint;
  float SetBack;
  Serial.print("SSID       :");  Serial.println(Settings.SSID);
  Serial.print("PASS       :");  Serial.println(Settings.PASS);
  // Read EEPROM
  static int eeaddress = 0;
  timeWas = micros();
  timeNow = micros();
  Serial.print("EEADDR :"); Serial.println(eeaddress);
  eeaddress += sizeof(Settings_s);
  delay(5000);
That's a better name than a for sure, but a bad name as it is not in any way associate with the eeprom or addresses.
It's just an integer that you change (increment) every time you use it, just so you can see different data getting read and written.
@kolaha makes a half step towards writing and reading successive areas large enough for you struct, viz:
and doesn't increment it otherwise. Left using the defined constant EEADDR, however, are the actual calls to the eeprom library.
a7
:sweat_smile: yes, that's typical me. better i make it proper.
#include <EEPROM.h>
struct Settings_s {
  char PASS[21];
  float BlrPWR;
  float maxSuppTemp;
  float minOutdTemp;
  float SetPoint;
  float SetBack;
  static int eeaddress = EEADDR;
  while (digitalRead(BUTTON_TEST)) {
    timeWas = micros();
    EEPROM.put(eeaddress, Settings);
    timeNow = micros();
    EEPROM.get(eeaddress, Settings);
    while (!digitalRead(BUTTON_TEST));
Many thanks to everyone and, in particular to kolala, the sketch already works!.
@kolaha, sorry.
You could put in some of those lines that change the struct values, then see them go in and out of eeprom with those changes.
To sorta prove you are writing differently to different addresses in the eeprom.
a7
I will adapt and debug the sketch, as soon as I have something more serious, I will put the sketch to serve many others. I have seen that there is quite a demand for a solution like the one you have provided me. Thanks @anon85221860, @cattledog, @david_2018, @kolaha and @alto777
