Hi
I have and strange error when I use the directive #define and #ifdef, because if I try to compile the next code, this it doesn't compile and shows multiples mistakes, but if the directive #define is uncomment, this code compiles fine.
//#define DEBUGMEM
#ifdef DEBUGMEM
uint8_t _VARINI_;
#endif
int led = 13;
pinMode(led, OUTPUT);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
What's wrong?? . . . It is assumed that all inside of the directive #ifdef is ignored if this is not met?
Thanks
PD: The code of blink is only used how example, this is not the real code that I am working
