I've been trying to set up a program to read UIDs from an RFID card/key chain and I get errors that aren't present in some of the examples.
My code:
#include <MFRC522.h>
#include <SPI.h>
#define RST_PIN 5
#define SS_PIN 53
#define LED_PIN 47
MFRC522 mfrc522(SS_PIN, RST_PIN);
#define CARD_UID {0xFF, 0xFF, 0xFF, 0xFF}
#define FOB_UID {0xFF, 0xFF, 0xFF, 0xFF}
MFRC522::MIFARE_Key key;
pinMode(LED_PIN, OUTPUT);
while(!Serial);
SPI.begin();
mfrc522.PCD_Init();
delay(4);
mfrc522.PCD_DumpVersionToSerial();
Serial.println(F("Scan RFID card"));
if (! mfrc522.PICC_IsNewCardPresent())
return;
if (! mfrc522.PICC_ReadCardSerial())
return;
if (mfrc522.uid == CARD_UID)
Serial.println("RFID Card detected");
delay(3000);
if (mfrc522.uid == FOB_UID)
Serial.println("RFID fob detected");
delay(3000);
Example code:
- Example to change UID of changeable MIFARE card.
- This is a MFRC522 library example; for further details and other examples see: GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522
- This sample shows how to set the UID on a UID changeable MIFARE card.
- @author Tom Clement
- @license Released into the public domain.
- Typical pin layout used:
MFRC522 Arduino Arduino Arduino Arduino Arduino
Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
- Signal Pin Pin Pin Pin Pin Pin
- RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
- SPI SS SDA(SS) 10 53 D10 10 10
- SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
- SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
- SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
- More pin layouts for other boards can be found here: GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522
#include <SPI.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
/* Set your new UID here! */
#define NEW_UID {0xFF, 0xFF, 0xFF, 0xFF}
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Warning: this example overwrites the UID of your UID changeable card, use with care!"));
// Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
// Setting the UID can be as simple as this:
//void loop() {
// byte newUid[] = NEW_UID;
// if ( mfrc522.MIFARE_SetUid(newUid, (byte)4, true) ) {
// Serial.println("Wrote new UID to card.");
// delay(1000);
// But of course this is a more proper approach
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle. And if present, select one.
if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
delay(50);
return;
// Now a card is selected. The UID and SAK is in mfrc522.uid.
// Dump UID
Serial.print(F("Card UID:"));
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
// Dump PICC type
// MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
// Serial.print(F("PICC type: "));
// Serial.print(mfrc522.PICC_GetTypeName(piccType));
// Serial.print(F(" (SAK "));
// Serial.print(mfrc522.uid.sak);
// Serial.print(")\r\n");
// if ( piccType != MFRC522::PICC_TYPE_MIFARE_MINI
// && piccType != MFRC522::PICC_TYPE_MIFARE_1K
// && piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
// Serial.println(F("This sample only works with MIFARE Classic cards."));
// return;
// Set new UID
Serial.println(F("Wrote new UID to card."));
// Halt PICC and re-select it so DumpToSerial doesn't get confused
mfrc522.PICC_HaltA();
return;
// Dump the new memory contents
Serial.println(F("New UID and contents:"));
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
delay(2000);
Output:
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino: In function 'void loop()':
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino:10:18: error: expected primary-expression before '{' token
#define CARD_UID {0xD3, 0x37, 0xED, 0x2E}
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino:37:22: note: in expansion of macro 'CARD_UID'
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino:10:18: error: expected ')' before '{' token
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino:11:17: error: expected primary-expression before '{' token
#define FOB_UID {0x13, 0x54, 0x0C, 0xB7}
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino:42:22: note: in expansion of macro 'FOB_UID'
C:\Users\Richardson Family\Documents\Arduino\RFID_test\RFID_test.ino:11:17: error: expected ')' before '{' token
exit status 1
Compilation error: expected primary-expression before '{' token
