I have a program of 17,906 bytes and it behaves very strangely, in that it hangs on lines of code even before it reaches them.
It hangs on say lcd.print lines using a 4 line display, if I delete the last 2 lines then it then doesn't hang anymore. I have code calling the lcd in 10 places and confident it's not a programming bug.
Another example to quote code is:
void decode_one_key ()
menuoptions = 1;
This above works fine. But I had to cut out lines from the original else it hung.
This version below crashes, the serial monitor crashes and all but odly well before this line is reached.
if ( menuoptions == 1 ) // then this pressing of 1 must be to pick auto mode so lets set it to 1
numbercalc(1);
menuoptions = 1;
I have had other occurrences of it hanging well before it reaches line of code.
It behaves as if I have hit a memory limitation.
It behaves the same if running in serial monitor or standalone.
I will be very grateful for a pointer on how to overcome this issue.
Many Thanks
Les
