Strcat (with MRE)
char gLog [5];
char gCode[3];
byte idx;
  Serial.begin(19200);
  gCode = "E";
  for(idx = 0; idx < 3; idx ++)
    strcat(gLog, gCode);
    Serial.println(gLog);
    delay(2000);
  gLog = "";  // blank gLog, start over
Desired / Anticipated Result:
E
EE
EEE
E  // and so on ...
Verify/Compile --
incompatible types in assignment of 'const char [2]' to 'char [3]'
I don't get it.
C/C++ does not allow copying one array to another using "=". Instead,
strcpy(gCode,"E");
To use strcat, assuming gCode is initialized to zero,
strcat(gCode,"E");
Serial.println(gCode);  //should print E
strcat(gCode,"E");
Serial.println(gCode); //should print EE
strcpy(gCode, "E");
@jremington and @sterretje
Thank You.
char gLog [5];
char gCode[3];
byte idx;
  strcpy (gCode, "E");
    delay(2000);
  strcpy (gLog, "");  // blank gLog
I thought strNcat was advised in Arduino c++ code over strcat... (and strncpy ... et c.)
It is indeed. The OP and other readers are hereby reminded that this construction can safely contain a C-string consisting of only two ASCII characters, plus the terminating zero.
char gCode[3];
Although not part of the C standard library, the 'l' versions (strlcat() and strlcpy()) are considered safer as you always pass the full size of the destination buffer.
