Hi all!
I just finished a project, but I would like to add it to the Arduino Cloud. I added all my libraries to the online editor, tried to compile it, and im getting the error that "String.h - File Not Found".
Here is my code:
#include "DFRobot_GDL.h"
#include <XPT2046_Touchscreen.h>
#include <SPI.h>
#include "DFRobot_GNSS.h"
#include "DFRobot_BMI160.h"
#include "DFRobot_AHT20.h"
#include "DFRobot_GR10_30.h"
#include <EEPROM.h>
#include "thingProperties.h"
//Testing
bool testing = false;
//Motor Driver
#define brakepin 16 //D11
#define cruisepin 4 //D12 // actually enable pin, so able to push scooter manually when on
#define speedpin 13 //D7
#define rpmpin A4
// PWM properties for motor driver
const int freq = 5000;
const int speedChannel = 0;
const int resolution = 8;
//Display
#define TFT_DC 25 //D2
#define TFT_CS 14 //D6
#define TFT_RST 26 //D3
#define TFT_BL 12 //D13
#define TOUCH_CS 4 //D12
//Throttle
#define throttlepin A0 //throttle pin
int throttleoffvalue = 0;
int throttleonvalue = 4095;
int throttleval = 0;
//Touch coordinates for calibration
#define touchxmin 290
#define touchxmax 3750
#define touchymin 300
#define touchymax 3700
#define backcolor COLOR_RGB565_WHITE
#define erasecolor backcolor//COLOR_RGB565_LGRAY
#define backgroundcolor COLOR_RGB565_CYAN
//gnss / display
long readgnssinc = 1000;//time between GNSS readings
unsigned long lastreadgnss = 0;
long readdisplayinc = 1000;//time between display updates
unsigned long lastdisplay = 0;
sTim_t utc;
sTim_t date;
sLonLat_t latitude;
sLonLat_t longitude;
double altitude;
uint8_t satelites;
double knots;
double course;
//AHT20
float temperature = 0;
float humidity = 0;
//WS2812
#define LEDPIN 5
#define NUMPIXELS 19
float lastcoursereading = 0;
float coursechangetime = 1000;
float lastcoursereadtime = 0;
float courseturnsignalinc = 50; //degrees of turning for turning signal to turn on
float lastspeedreading = 0;
float speedchangetime = 1000;
float lastspeedreadtime = 0;
float speedbrakeinc = -0.5;//decrease in speed before brake light turns on
int leftturn1 = 0;
int leftturn2 = 1;
int leftturn3 = 2;
int rightturn3 = 2;
int rightturn2 = 3;
int rightturn1 = 4;
int brake1 = 16;
int brake2 = 17;
int brake3 = 18;
int brake4 = 19;
unsigned long startmillis = 0;
int animationcount = 1;
//Password
bool locked = false;//true
uint16_t gestures;
int passwordlength = 3;
#define EEPROM_SIZE passwordlength
int password[] = {GESTURE_UP,GESTURE_DOWN,GESTURE_LEFT};//Adjustable gesture password; can adjust password length (right now it is set to 3 in the "passwordlength" integer)
int passc = 0;//pass count
//battery
float batteryvolts = 0;
#define batterypin A2
int batteryreadings = 10;//number of readings to average, more for a smoother more reliable response
long readbatteryint = 20;//time in milliseconds between battery readings
unsigned long lastbatreading = 0;
long R1 = 15000;//15k ohms
long R2 = 1000;//1.1k ohms
int curbatread = 0;
int batsum = 0;
#define batteryamps 5
#define batteryvoltage 36 //voltage and amp hours of battery, or uncomment "batterywattage" below instead
//#define batterywattage 180
#define motorwattage 350
#define maxcruisespeed 15 //mph //20
bool lastebrakeon = false;
unsigned long lastebrakechange = 0;
bool ebrakeon = false;
bool lockbtnon = false;
bool lastcruiseon = false;
unsigned long lastcruisechange = 0;
bool cruiseon = false;
float cruisesetspeed = 0;
int previousotherx1 = 0;
int previousothery1 = 0;
int previousotherx2 = 0;
int previousothery2 = 0;
XPT2046_Touchscreen ts(TOUCH_CS);
DFRobot_ILI9341_240x320_HW_SPI screen(/*dc=*/TFT_DC,/*cs=*/TFT_CS,/*rst=*/TFT_RST);
DFRobot_GNSS_I2C gnss(&Wire,GNSS_DEVICE_ADDR);
DFRobot_BMI160 bmi160;
const int8_t i2c_addr = 0x69;
DFRobot_AHT20 aht20;
DFRobot_GR10_30 gr10_30(/*addr = */GR10_30_DEVICE_ADDR, /*pWire = */&Wire);
Adafruit_NeoPixel pixels(NUMPIXELS, LEDPIN, NEO_GRB + NEO_KHZ800);
//BMI160
struct dat{
float x = 0;
float y = 0;
float z = 0;
dat accel;
struct data{
float x = 0;
float y = 0;
float z = 0;
data gyro;
float baseyangle = 0;
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
digitalWrite(speedpin, LOW);
pinMode(rpmpin, INPUT);
EEPROM.begin(EEPROM_SIZE);
for (int i=0;i<passwordlength;i++){//read password from EEPROM
password[i] = EEPROM.read(i);
pinMode(batterypin, INPUT);
pinMode(throttlepin, INPUT);
pinMode(brakepin, OUTPUT);
pinMode(cruisepin, OUTPUT);
pinMode(speedpin, OUTPUT);
attachInterrupt(rpmpin, interruptRoutine, FALLING);
ledcSetup(speedChannel, freq, resolution);
ledcAttachPin(speedpin, speedChannel);
if(!gnss.begin()){
Serial.println("NO GPS device !");
gnss.enablePower();
gnss.setGnss(eGPS_BeiDou_GLONASS);
gnss.setRgbOn();
if (bmi160.softReset() != BMI160_OK){
Serial.println("bmi160 reset false");
//while(1);
if (bmi160.I2cInit(i2c_addr) != BMI160_OK){
Serial.println("bmi160 init false");
//while(1);
readAccelGyro();
baseyangle = gyro.y;
//baseyangle = 20;
uint8_t status;
if((status = aht20.begin()) != 0){
Serial.print("AHT20 sensor initialization failed. error status : ");
Serial.println(status);
pixels.begin();
pixels.clear();
startGestureSensor();
ts.begin();
ts.setRotation(3);
screen.begin();
screen.setRotation(3);
startDisplay();
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
if (locked){
lockedloop();
return;
if (ts.touched()){
TS_Point p = ts.getPoint();
handleTouch(abs(map(p.x,touchxmax,touchxmin,0,320)),abs(map(p.y,touchymax,touchymin,0,240)));
if ((millis() - lastreadgnss) > readgnssinc){
readGNSS();
lastreadgnss = millis();
readAccelGyro();
readTempHum();
readBattery();
readThrottle();
if (((millis() - lastdisplay) > readdisplayinc) && (satelites != 0)){
handleSlowDisplay();
lastdisplay = millis();
handleFastDisplay();
handleDisplayButtons();
float handleAngleLineValue = (baseyangle*100) - (gyro.y*100);
handleAngleLine(handleAngleLineValue);
handleGestures();
handleMotordriver();
handleLeds();
handleSpeedLimit();
if (locked){
if (knots > 2){
stolen = true;
else {
stolen = false;
void onLockChange() {
locked = lock;
void handleSpeedLimit(){
if (knots > maxspeed){
throttleval = throttleval/2;
void handleTouch(int x,int y){
Serial.print("Touch X = " + String(x));
Serial.println(" | Touch Y = " + String(y));
if (x >= 215 && x <= 320){
if (y < 45){
changepassword();
else if (y >= 45 && y <= 104){
if ((millis() - lastebrakechange) > 1000){//wait 1 second between reading button as pressed
if (knots < 5){
ebrakeon = !ebrakeon;
lastebrakechange = millis();
else if (y >= 105 && y <= 160){
if ((millis() - lastcruisechange) > 1000){//wait 1 second between reading button as pressed
cruiseon = !cruiseon;
cruisesetspeed = knots;
lastcruisechange = millis();
else if (x >= 5 && x <= 105){
if (y < 45){
changepassword();
else if (y >= 45 && y <= 105){
if (!lockbtnon){
lockbtnon = true;
else {
screen.setTextSize(2);
screen.setCursor(15,115);
screen.setTextColor(COLOR_RGB565_RED);
screen.print("Unlock with gestures!");//display unlock warning
delay(3000);
screen.fillRect(14, 114, 290, 20, erasecolor);//erase display unlock warning
void handleSlowDisplay(){
//satelites
screen.setCursor(287,15);
screen.fillRect(286, 13, 26, 18, erasecolor);//backcolor
if (satelites <= 5){
else if (satelites > 5 && satelites <= 8){
screen.setTextColor(COLOR_RGB565_ORANGE);
else if (satelites > 8){
screen.setTextColor(COLOR_RGB565_GREEN);
screen.print(String(satelites));
//Serial.println(satelites);
//speed (knots)
screen.setTextSize(4);
if (knots >= 10){
screen.setCursor(100,62);//118,62
screen.fillRect(92, 58, 132, 37, erasecolor);//117, 57, 90, 30,
else {
screen.setCursor(110,62);//118,62
screen.fillRect(100, 58, 105, 37, erasecolor);//117, 57, 90, 30,
if (knots <= 1.00){
screen.setTextColor(COLOR_RGB565_BLUE);
else if (knots > 1.00 && knots <= 12.00){
else if (knots > 12.00 && knots <= 19.00){
else {
screen.print(knots);
//if (knots >= cruisesetspeed+4.00){//reset cruise if current speed goes above cruisesetspeed + 4
// cruiseon = false;
//temperature
screen.setCursor(12,215);
screen.fillRect(11,214,55,17,erasecolor);
screen.print(temperature,1);//temperature with only one decimal
screen.drawCircle(64,209,2,COLOR_RGB565_GREEN);//degrees symbol
//humidity
screen.setCursor(270,215);
screen.fillRect(269,214,40,17,erasecolor);
screen.print(humidity,0);//humidity with no decimals
screen.print("%");//percentage symbol
//battery
screen.setCursor(140,215);
screen.fillRect(139,214,65,17,erasecolor);
float batpercent = map(batteryvolts*10,300,420,0,100); //map battery voltage to a percentage value of 0 - 100
if (batpercent > 80.0){
else if (batpercent <= 80.0 && batpercent > 50.0){
screen.setTextColor(COLOR_RGB565_DGREEN);
else if (batpercent <= 50.0 && batpercent > 25.0){
screen.setTextColor(COLOR_RGB565_YELLOW);
else if (batpercent <= 25.0 && batpercent > 12.0){
else if (batpercent <= 12.0 && batpercent > 5.0){
else {
batterywarning();
screen.print(batpercent,0);//battery percentage with no decimals
//dist to empty; for 36V 5AH (180W) that would be (at 20mph) 8 miles or 0.4 hours
float batwatts = 0;
#ifdef batterywattage
batwatts = batterywattage;
#else
batwatts = batteryvoltage * batteryamps;
#endif
float bathours = batwatts / motorwattage;
float batmiles = maxcruisespeed * bathours;
float batmilesleft = map(batteryvolts*10,300,420,0,batmiles*100);//map function cant map floating values
batmilesleft = batmilesleft / 100;
float bathoursleft = map(batteryvolts*10,300,420,0,bathours*100);//map function cant map floating values
bathoursleft = bathoursleft / 100;
float batminutesleft = map(bathoursleft*100,0,100,0,600);//map function cant map floating values
batminutesleft = batminutesleft / 10;
screen.setTextSize(3);
screen.setCursor(75,187);
screen.fillRect(74,186,198,24,erasecolor);
screen.print(abs(batmilesleft),1);//miles with no decimals
screen.print("m|");//miles symbol
screen.print(abs(batminutesleft),1);//hours with two decimals
screen.print("m");
//Angle
screen.setCursor(140,95);
screen.fillRect(139,94,65,17,erasecolor);
screen.print(gyro.y*100,1);//temperature with only one decimal
void handleFastDisplay(){
//Angle
screen.fillRect(139,94,75,17,erasecolor);
screen.print((baseyangle*100)-(gyro.y*100),1);//angle with only one decimal
void handleDisplayButtons(){
//e-brake button
if (ebrakeon != lastebrakeon){
if (!ebrakeon){
screen.fillRoundRect(220,45,90,60,12,erasecolor);//erase
screen.drawRoundRect(225,50,80,50,12,backgroundcolor);
screen.setCursor(235,70);
screen.print("E OFF");
else {
screen.fillRoundRect(225,50,80,50,12,backgroundcolor);
screen.print("E ON");
lastebrakeon = ebrakeon;
if (!lockbtnon){
screen.fillRoundRect(12,45,90,60,12,erasecolor);//erase
screen.drawRoundRect(15,50,80,50,12,backgroundcolor);
screen.setTextSize(1);
screen.setCursor(25,70);
screen.print("Unlocked");
else if (lockbtnon || locked){
screen.fillRoundRect(15,50,80,50,12,backgroundcolor);
screen.setCursor(20,70);
screen.print("Locked");
ebrakeon = true;
locked = true;
if (cruiseon != lastcruiseon){
if (!cruiseon){
screen.fillRoundRect(220,105,90,60,12,erasecolor);//erase
screen.drawRoundRect(225,110,80,50,12,backgroundcolor);
screen.setCursor(235,130);
screen.print("C OFF");
else {
screen.fillRoundRect(225,110,80,50,12,backgroundcolor);
screen.print("C ON");
lastcruiseon = cruiseon;
void handleAngleLine(float angle1){
int x=160,y=140; //center point of the two lines
screen.drawLine(x, y, previousotherx1, previousothery1, erasecolor);//line going right
screen.drawLine(x+1, y+1, previousotherx1+1, previousothery1+1, erasecolor);//double thick line
screen.drawLine(x, y, previousotherx2, previousothery2, erasecolor);//line going left
screen.drawLine(x+1, y+1, previousotherx2+1, previousothery2+1, erasecolor);//double thick line
#define DEG2RAD 0.0174532925
float screenangle1 = 135; //value for right line to make it level
float screenangle2 = 315; //value for left line to make it level; appears to be one line instead of two separate ones
float angle2 = angle1;
int w=100,h=100; //length of each line; one going right and one going left
#define linecolor COLOR_RGB565_NAVY
float cosa1 = cos((screenangle1+angle1) * DEG2RAD), sina1 = sin((screenangle1+angle1) * DEG2RAD);
int otherx1 = x - ((w * cosa1 / 2) - (h * sina1 / 2));
int othery1 = y - ((h * cosa1 / 2) + (w * sina1 / 2));
screen.drawLine(x, y, otherx1, othery1, linecolor);//line going right
screen.drawLine(x+1, y+1, otherx1+1, othery1+1, linecolor);//double thick line
float cosa2 = cos((screenangle2+angle2) * DEG2RAD), sina2 = sin((screenangle2+angle2) * DEG2RAD);
int otherx2 = x - ((w * cosa2 / 2) - (h * sina2 / 2));
int othery2 = y - ((h * cosa2 / 2) + (w * sina2 / 2));
screen.drawLine(x, y, otherx2, othery2, linecolor);//line going left
screen.drawLine(x+1, y+1, otherx2+1, othery2+1, linecolor);//double thick line
previousotherx1 = otherx1;
previousothery1 = othery1;
previousotherx2 = otherx2;
previousothery2 = othery2;
void batterywarning(){
void changepassword(){
screen.fillScreen(backcolor);
screen.fillScreen(COLOR_RGB565_DGRAY);
screen.fillRoundRect(0, 0, 320, 240, 15, backgroundcolor);
screen.fillRoundRect(5, 5, 310, 230, 15, backcolor);
screen.setTextColor(backgroundcolor);
screen.setCursor(30, 11);
screen.print("Change PASS");
screen.drawFastHLine(10, 35, 300, COLOR_RGB565_GREEN);
screen.drawFastHLine(10, 36, 300, COLOR_RGB565_GREEN);
screen.setCursor(40, 100);
screen.print("Do three gestures to set new password...");
password[0] = 0;
password[1] = 0;
password[2] = 0;
int gesturepasscount = 0;
redo:
if(gr10_30.getDataReady()){
gestures = gr10_30.getGesturesState();
if(gestures&GESTURE_UP){
Serial.println("Up");
password[gesturepasscount] = GESTURE_UP;
if(gestures&GESTURE_DOWN){
Serial.println("Down");
password[gesturepasscount] = GESTURE_DOWN;
if(gestures&GESTURE_LEFT){
Serial.println("Left");
password[gesturepasscount] = GESTURE_LEFT;
if(gestures&GESTURE_RIGHT){
Serial.println("Right");
password[gesturepasscount] = GESTURE_RIGHT;
if(gestures&GESTURE_FORWARD){
password[gesturepasscount] = GESTURE_FORWARD;
if(gestures&GESTURE_BACKWARD){
password[gesturepasscount] = GESTURE_BACKWARD;
if(gestures&GESTURE_CLOCKWISE){
password[gesturepasscount] = GESTURE_CLOCKWISE;
if(gestures&GESTURE_COUNTERCLOCKWISE){
password[gesturepasscount] = GESTURE_COUNTERCLOCKWISE;
if(gestures&GESTURE_WAVE){
password[gesturepasscount] = GESTURE_WAVE;
if(gestures&GESTURE_HOVER){
password[gesturepasscount] = GESTURE_HOVER;
if(gestures&GESTURE_CLOCKWISE_C){
password[gesturepasscount] = GESTURE_CLOCKWISE_C;
if(gestures&GESTURE_COUNTERCLOCKWISE_C){
password[gesturepasscount] = GESTURE_COUNTERCLOCKWISE_C;
EEPROM.write(gesturepasscount,password[gesturepasscount]);
EEPROM.commit();
gesturepasscount++;
Serial.println("gesturepasscount: " + String(gesturepasscount));
if (gesturepasscount != passwordlength){
goto redo;
Serial.println("Finished!");
startDisplay();
void readThrottle(){
throttleval = map(analogRead(throttlepin),throttleoffvalue,throttleonvalue,4095,0);
Serial.println("Throttle: " + String(throttleval));
void readBattery(){
if ((millis() - lastbatreading) > readbatteryint){
if (curbatread < batteryreadings){
batsum = batsum + analogRead(batterypin);
curbatread++;
else{
float batteryread = batsum/batteryreadings;
float batpinvolt = (batteryread*3.3)/4095;//3.3V and 4095 is the max resolution of ESP32
if (testing){
batpinvolt = 2.2;
batteryvolts = batpinvolt*16;//(1000/(15000+1000)); //(R2/(R1+R2));//VOUT = VIN*R2/R1+R2 ; classic equation for voltage dividers
curbatread = 0;
lastbatreading = millis();
void handleGestures(){
cruiseon = true;
cruiseon = false;
ebrakeon = true;
ebrakeon = false;
Serial.println("Forward");
Serial.println("Backward");
Serial.println("Clockwise");
Serial.println("Contrarotate");
Serial.println("Wave");
Serial.println("Hover");
Serial.println("Continuous clockwise");
Serial.println("Continuous counterclockwise");
ebrakeon = true;
locked = true;
void lockedloop(){
Serial.print("Gesture: ");
Serial.println(gestures);
if (gestures&password[passc]){
Serial.println("Correct!");
Serial.println(password[passc]);
passc++;
Serial.println("PASSC: " + String(passc));
else {
Serial.println("Wrong");
passc=0;
if (passc >= passwordlength){
Serial.println("Unlocked!");
passc=0;
locked = false;
void readGNSS(){
utc = gnss.getUTC();
date = gnss.getDate();
latitude = gnss.getLat();
longitude = gnss.getLon();
altitude = gnss.getAlt();
satelites = gnss.getNumSatUsed();
knots = gnss.getSog();
course = gnss.getCog();
void readAccelGyro(){
int i = 0;
int rslt;
int16_t accelGyro[6]={0};
//get both accel and gyro data from bmi160
//parameter accelGyro is the pointer to store the data
rslt = bmi160.getAccelGyroData(accelGyro);
if(rslt == 0){
for(i=0;i<6;i++){
if (i<3){
//the first three are gyro data
//Serial.print(accelGyro[i]*3.14/180.0);Serial.print("\t");
if (i==0){accel.x = accelGyro[i]*3.14/180.0;}
else if (i==1){accel.y = accelGyro[i]*3.14/180.0;}
else if (i==2){accel.z = accelGyro[i]*3.14/180.0;}
}else{
//the following three data are accel data
//Serial.print(accelGyro[i]/16384.0);Serial.print("\t");
if (i==3){gyro.x = accelGyro[i]/16384.0;}
else if (i==4){gyro.y = accelGyro[i]/16384.0;}
else if (i==5){gyro.z = accelGyro[i]/16384.0;}
//Serial.println();
}else{
Serial.println("err");
void readTempHum(){
if(aht20.startMeasurementReady(/* crcEn = */true)){
temperature = aht20.getTemperature_F();
humidity = aht20.getHumidity_RH();
void handleMotordriver(){
digitalWrite(cruisepin,cruiseon);
digitalWrite(brakepin,ebrakeon);
ledcWrite(speedChannel, map(throttleval,400,4095,0,255));//pwm signal for speed
void handleLeds(){
if ((millis() - lastcoursereadtime) > coursechangetime){//handle turning signal
float coursechange = 0;
coursechange = course - lastcoursereading;
if (abs(coursechange) > courseturnsignalinc){
if (coursechange < 0){
leftblinker();
else {
rightblinker();
lastcoursereading = course;
lastcoursereadtime = millis();
if ((millis() - lastspeedreadtime) > speedchangetime){//handle brake light
float speeddiferrence = 0;
speeddiferrence = knots - lastspeedreading;
if (speeddiferrence < speedbrakeinc){
brakelight(true);
else {
brakelight(false);
lastspeedreading = knots;
lastspeedreadtime = millis();
void leftblinker(){
if (animationcount == 1){
if ((millis() - startmillis) < 300){
pixels.setPixelColor(leftturn3, pixels.Color(255, 255, 0));
pixels.show();
else {
animationcount++;
startmillis = millis();
else if (animationcount == 2){
pixels.setPixelColor(leftturn3, pixels.Color(0, 0, 0));
pixels.setPixelColor(leftturn2, pixels.Color(255, 255, 0));
pixels.show();
else {
animationcount++;
if (animationcount == 3){
if ((millis() - startmillis) < 2000){
pixels.setPixelColor(leftturn2, pixels.Color(0, 0, 0));
pixels.setPixelColor(leftturn1, pixels.Color(255, 255, 0));
pixels.show();
else {
animationcount++;
if (animationcount == 4){
if ((millis() - startmillis) < 800){
pixels.setPixelColor(leftturn1, pixels.Color(0, 0, 0));
pixels.show();
else {
animationcount = 1;
void rightblinker(){
pixels.setPixelColor(rightturn3, pixels.Color(255, 255, 0));
pixels.show();
else {
animationcount++;
pixels.setPixelColor(rightturn3, pixels.Color(0, 0, 0));
pixels.setPixelColor(rightturn2, pixels.Color(255, 255, 0));
pixels.show();
else {
animationcount++;
pixels.setPixelColor(rightturn2, pixels.Color(0, 0, 0));
pixels.setPixelColor(rightturn1, pixels.Color(255, 255, 0));
pixels.show();
else {
animationcount++;
pixels.setPixelColor(rightturn1, pixels.Color(0, 0, 0));
pixels.show();
else {
animationcount = 1;
void brakelight(bool brakelighton){
if (brakelighton){
for (int i=0;i<4;i++){
pixels.setPixelColor(i+16, pixels.Color(255, 0, 0));//brake light on
else {
pixels.setPixelColor(i+16, pixels.Color(115, 0, 0));//dim brake light
void startDisplay(){
screen.setTextWrap(false);
//title
screen.print("DIY E-Scooter");
//speed label
screen.setCursor(125,40);
screen.print("Speed");
//dist and time to empty labels
screen.setCursor(91,170);
screen.print("Dist Time");
//boost button
//lock button
//cruise button
void startGestureSensor(){
if(gr10_30.begin() != 0){
Serial.println(" Sensor initialize failed!!");
/** Set the gesture to be enabled
* GESTURE_UP
* GESTURE_DOWN
* GESTURE_LEFT
* GESTURE_RIGHT
* GESTURE_FORWARD
* GESTURE_BACKWARD
* GESTURE_CLOCKWISE
* GESTURE_COUNTERCLOCKWISE
* GESTURE_WAVE It is not suggested to enable rotation gesture (CW/CCW) and wave gesture at the same time.
* GESTURE_HOVER Disable other gestures when hover gesture enables.
* GESTURE_UNKNOWN
* GESTURE_CLOCKWISE_C
* GESTURE_COUNTERCLOCKWISE_C
gr10_30.enGestures(GESTURE_UP|GESTURE_DOWN|GESTURE_LEFT|GESTURE_RIGHT|GESTURE_FORWARD|GESTURE_BACKWARD|GESTURE_CLOCKWISE|GESTURE_COUNTERCLOCKWISE|GESTURE_CLOCKWISE_C|GESTURE_COUNTERCLOCKWISE_C);
* Set the detection window you want, only data collected in the range are valid
* The largest window is 31, the configured number represents distance from the center to the top, bottom, left and right
* For example, if the configured distance from top to bottom is 30, then the distance from center to top is 15, and distance from center to bottom is also 15
* udSize Range of distance from top to bottom 0-31
* lrSize Range of distance from left to right 0-31
gr10_30.setUdlrWin(30, 30);//0-31,0-31
* Set moving distance that can be recognized as a gesture
* Distance range 5-25, must be less than distances of the detection window
gr10_30.setLeftRange(10);
gr10_30.setRightRange(10);
gr10_30.setUpRange(10);
gr10_30.setDownRange(10);
gr10_30.setForwardRange(10);
gr10_30.setBackwardRange(10);
* Set distance of moving forward and backward that can be recognized as a gesture
* Distance range 1-15
* Set rotation angle that can trigger the gesture
* count Default is 16 range 0-31
* count Rotation angle is 22.5 * count
* count = 16 22.5*count = 360 Rotate 360° to trigger the gesture
gr10_30.setCwsAngle(/*count*/16);
gr10_30.setCcwAngle(/*count*/16);
* Set degrees of continuous rotation that can trigger the gesture
* count Default is 4 range 0-31
* count The degrees of continuous rotation is 22.5 * count
* For example: count = 4 22.5*count = 90
* Trigger the clockwise/counterclockwise rotation gesture first, if keep rotating, then the continuous rotation gesture will be triggered once every 90 degrees
gr10_30.setCwsAngleCount(/*count*/8);
gr10_30.setCcwAngleCount(/*count*/8);
void interruptRoutine(){
Serial.println("Interrupt...");
And here is the error:
In file included from /tmp/869165888/DIY_E-Scooter_jun03a/DIY_E-Scooter_jun03a.ino:8:
/mnt/create-efs/webide/66/70/6670296fcbd16a09e7c95a2d4d74d1fc:kgray9/libraries_v2/DFRobot_GR10_30/DFRobot_GR10_30.h:16:10: fatal error: String.h: No such file or directory
#include "String.h"
compilation terminated.
Error during build: exit status 1
Any ideas? I cant find the "String.h" file mentioned anywhere.
Thanks in advance!
