Hi!
Im looking for a conversion, but i still cannot find the right way. I read the data to a string, and this string is going to be the MAC address, but i still cannot find a way to convert it properly. This is my code:
GivenMacAddress[0] = String(readedData[21]) + String(readedData[22]);
GivenMacAddress[1] = String(readedData[23]) + String(readedData[24]);
GivenMacAddress[2] = String(readedData[25]) + String(readedData[26]);
GivenMacAddress[3] = String(readedData[27]) + String(readedData[28]);
GivenMacAddress[4] = String(readedData[29]) + String(readedData[30]);
GivenMacAddress[5] = String(readedData[31]) + String(readedData[32]);
EEPROM.write(EEPROM_MAC0, GivenMacAddress[0]);
EEPROM.write(EEPROM_MAC1, GivenMacAddress[1]);
EEPROM.write(EEPROM_MAC2, GivenMacAddress[2]);
EEPROM.write(EEPROM_MAC3, GivenMacAddress[3]);
EEPROM.write(EEPROM_MAC4, GivenMacAddress[4]);
EEPROM.write(EEPROM_MAC5, GivenMacAddress[5]);
Ethernet.setMACAddress(GivenMacAddress);
The readedData is 30 AE A4 07 0D 64. How can i convert these values from string?
b707
November 7, 2022, 9:15am
2
Why do you convert this values to String, if you need it in DEC?
If you do not convert them to a String, there will be no problem how to extract them back
How is readedData array defined? as chars, bytes, ints?
Where does this data come from?
Please show all your code.
Because i send it from a Delphi program, where I cannot convert the values properly. The readedData is a char array.
b707
November 7, 2022, 9:33am
4
So what are the values :
frozenhore:
30 AE A4 07 0D 64
Is 30 means two chars '3' and '0' or one char with code 30?
Why do you need to convert it to DEC?
What for?
It means two chars. The first char is "3" the second is "0". I want to convert it to DEC, because i cannot set the MAC address[0] with two Strings.
b707
November 7, 2022, 9:38am
6
Look this thread. It contains ready-to-go code for proper conversion:
consider
output
D45A130064f9
D4 5A 13 0 64 F9
212 90 19 0 100 249
code
char buf [] = "D45A130064f9";
unsigned val [6];
void
setup (void)
Serial.begin (9600);
Serial.println (buf);
sscanf (buf, "%02x%02x%02x%02x%02x%02x",
& val[0], & val[1], & val[2], & val[3], & val[4], & val[5]);
for (int n = 0; n < 6; n++) {
Serial.print (" "); Serial.print (val [n], HEX);
Serial.println ();
Serial.print (…
horace
November 7, 2022, 9:44am
7
you can parse a char array using sscanf() converting each hex value to an integer, e.g.
char s[]="30 AE A4 07 0D 64";
unsigned int mac[6]={0};
sscanf(s,"%x%x%x%x%x%x",&mac[0],&mac[1],&mac[2],&mac[3],&mac[4],&mac[5]);
for (int i=0;i<6;i++)
{ Serial.print(" "); Serial.print(mac[i],HEX);}
a run gives an int array with the MAC address
30 AE A4 7 D 64
Ethernet.setMACAddress() requires a byte array as a parameter so you would have copy the data
Yes, but i cannot convert the GivenMacAddress[0] to a char array[0].
b707
November 7, 2022, 9:56am
9
You have char array already -
horace
November 7, 2022, 10:02am
10
as I read the problem you receive from Delphi a char array called readedData which contains "30 AE A4 07 0D 64" which represents a MAC address
to set that MAC address you have to convert the readedData char array to a byte array which is a parameter for Ethernet.setMACAddress()
Exactly, but i cannot convert it.
b707
November 7, 2022, 10:12am
12
Your data is in char array already - in readedData[] . You don't need to convert it to String. Throw out your code from the post 1 .
Just put your readedData[] array in the code in post #7 instead of s[] array
The data comes in like:
readedData[21] = C
readedData[22] = 3 etc..
So the MAC address numbers are splitted.
horace
November 7, 2022, 12:02pm
14
have a look at
#include <SPI.h>
#include <Ethernet.h>
char readedData[] = "30 AE A4 07 0D 64";
unsigned int imac[6] = {0};
// parse char array to get MAC values into int array
sscanf(readedData, "%x%x%x%x%x%x", &imac[0], &imac[1], &imac[2], &imac[3], &imac[4], &imac[5]);
// priint MAC values and copy to byte array
byte mac[6];
for (int i = 0; i < 6; i++) {
Serial.print(" ");
Serial.print(mac[i] = imac[i], HEX);
Ethernet.setMACAddress(mac); // set MAC address
Serial.println("\nMAC address set");
void loop() {}
a run gives
30 AE A4 7 D 64
MAC address set
or is readData not "30 AE A4 07 0D 64" but also contains other information?
if so give an example
Yes the readedData contains other information. Like messageID .. I read the other information from 0-20, and from 21 the MAC address comes. Example code:
if (arrayIndex == 11) {
msgVersion = (unsigned long)readedData[8] << 24;
msgVersion |= (unsigned long)readedData[9] << 16;
msgVersion |= (unsigned long)readedData[10] << 8;
msgVersion |= (unsigned long)readedData[11];
char recVersion[] = { "Recieved the version." };
ws.send(WebSocket::DataType::TEXT, recVersion, strlen(recVersion));
horace
November 7, 2022, 12:17pm
16
in that case you parse from readedData[21], e.g.
char readedData[] = "01234567890123456789 30 AE A4 07 0D 64";
sscanf(&readedData[21], "%x%x%x%x%x%x", &imac[0], &imac[1], &imac[2], &imac[3], &imac[4], &imac[5]);
when run gives
30 AE A4 7 D 64
MAC address set
So i did that:
sscanf(readedData[21] + readedData[22], "%x%x%x%x%x%x", &imac[0]);
sscanf(readedData[23] + readedData[24], "%x%x%x%x%x%x", &imac[1]);
sscanf(readedData[25] + readedData[26], "%x%x%x%x%x%x", &imac[2]);
sscanf(readedData[27] + readedData[28], "%x%x%x%x%x%x", &imac[3]);
sscanf(readedData[29] + readedData[30], "%x%x%x%x%x%x", &imac[4]);
sscanf(readedData[31] + readedData[32], "%x%x%x%x%x%x", &imac[5]);
Serial.println(imac[i], HEX);
but the output was:
4:10:19.175 -> MAC:
4:13:45.173 -> 1382
14:13:45.173 -> 2
14:13:45.173 -> 2
14:13:45.173 -> 441F
14:13:45.173 -> F00
14:13:45.173 -> 1035
The readedData[21] is the first letter or digit of the MAC address. The readedData[22] is the second.
b707
November 7, 2022, 1:18pm
18
frozenhore:
So i did that:
No, it is wrong.
You were given a ready-made code....
Do it EXACTLY as in example post #16 if you don't understand how to work with arrays...
Yes but the ready-made code is wrong for me. It gives this output:
15:48:57.759 -> D64
15:48:57.759 -> 0
15:48:57.759 -> 0
15:48:57.759 -> 0
15:48:57.759 -> 0
15:48:57.759 -> 0
When i print it out like this:
I did exactly as above.
b707
November 7, 2022, 2:51pm
22
frozenhore:
show your code
Add this lines before or after sscanf() function and show the output
for (int i = 21; i < 21+12; i++) {
Serial.println( readedData[i]);
