Hello, I'm trying to get the length of the string t.hour from the ds3231 library but I'm having a hard time understanding why it's not possible..
Help will be appreciated, thank you!
Because t.hour is NOT a string. It's not even a String. It's a byte.
Is it possible to make it a string then?
Can I make the byte to a string then by using something like this?
byte timeHByte= t.hour;
String timeH = timeHByte;
TobiasBrage:
Can I make the byte to a string then by using something like this?byte timeHByte= t.hour;
what if, for example you looked at the magnitude of the number...
for example,
if(t.hour < 10)
ug8.print("0");
Well played sir, think I'll do that..
