struct or typedef
I ran into this problem today trying to define a pointer to the typedef struct inside the very struct I'm defining :
I retreated to struct myStruct syntax as the following:
struct phi_prompt_struct
  buffer_pointer ptr;
  four_bytes low;
  four_bytes high;
  four_bytes step;
  byte col;
  byte row;
  int option;
  LiquidCrystal *lcd;
  phi_buttons **btns;
  DS1307 *RTC;
  void (*update_function)(phi_prompt_struct *);
}; //26 bytes
See the last line in my struct.
If I did it this way with typedef, the struct is not define as complained by the compiler:
error: 'phi_prompt_struct' has not been declared
Following code used:
typedef struct
  buffer_pointer ptr;
  four_bytes low;
  four_bytes high;
  four_bytes step;
  byte col;
  byte row;
  int option;
  LiquidCrystal *lcd;
  phi_buttons **btns;
  DS1307 *RTC;
} phi_prompt_struct; //26 bytes
Any remedy some guru can offer so I can use typedef syntax? Thanks!
This compiles:
typedef struct phi_prompt_struct
 // blah blah
  byte col;
  byte row;
  int option;
void setup () {
  phi_prompt_struct foo;
void loop () {}
This
  buffer_pointer ptr;
  four_bytes low;
  four_bytes high;
  four_bytes step;
  byte col;
  byte row;
  int option;
  LiquidCrystal *lcd;
  phi_buttons **btns;
  DS1307 *RTC;
  void (*update_function)(struct phi_prompt_struct *);
or this
typedef struct phi_prompt_struct phi_prompt_struct;
  buffer_pointer ptr;
  four_bytes low;
  four_bytes high;
  four_bytes step;
  byte col;
  byte row;
  int option;
  LiquidCrystal *lcd;
  phi_buttons **btns;
  DS1307 *RTC;
} ; //26 bytes
...should work.
I like the second way because it makes the type of update_function() be the typedef, rather than the identical struct.
Thanks guys. I didn't know I could write the typedef the way you described :slight_smile: I'll consider the second way.
