substrings are empty ?
Hello,
I am faced with a problem I don't understand... the substring returns 'empty' values.
I use Arduino 1.0.5 with the SoftwareSerial.h included, on an Arduino Uno.
Here is the code :
// csms is a String coming from SIM900 serial : String csms = String("");
Serial.print("CALL WEB WITH : ");
  Serial.println(csms);
  int i1;
  int i2;
  i1 = csms.indexOf('"');
  i2 = csms.indexOf('"' , i1+1);
  // REC UNREAD
  i1 = csms.indexOf('"',i2+1);
    Serial.println(i1);
    Serial.println(i2);
  String num = csms.substring(i1+1,i2);
    num.replace("+33","0");
    Serial.print("CALLING NUMBER : ");
    Serial.println(num);
  i1 = csms.indexOf('"', i2+1);
     Serial.println(i1);
    Serial.println(i2);
  // EMPTY
    Serial.println(i1);
    Serial.println(i2);
  String date = csms.substring(i1+1,i2);
    Serial.print("DATE : ");
    Serial.println(date);
  String psms = "mytel="+mytel+"&num"+num+"&date="+date+"\0";
  Serial.print("POST PARAMS : ");
  Serial.println(psms);
And here is the log :
CALL WEB WITH :
+CMGR: "REC UNREAD","+33612345678","","14/03/10,17:34:36+04"
21
34
CALLING NUMBER :
36
37
39
60
DATE :
POST PARAMS :
so the i1 and i2 parameters are well computed, but the substrings are empty...
Any help is welcome. Thanks.
Olivier
The time to print num is IMMEDIATELY after extracting the sub-strng, not after extracting and diddling with it. Which step is failing? You don't know. Fix that.
Thanks Pauls for your answer.
I must say I don't understand why it is not possible to modify this parameter before printing it. I've tried to do what you said, and it works... but, if I add it again, it works also... Don't understand, is it a memory allocation problem ?
Moreover, I am still unable to create my psms variable, which is still empty. I've shorten the code as far as I can do :
  String psms = String("TEST")+String("1234");
And here is what I have in the console :
+CMGR: "REC UNREAD","+33673058933","","14/03/13,16:02:42+04"
21
34
CALLING NUMBER : 0673058933
36
37
39
60
DATE : 14/03/13,16:02:42+04
POST PARAMS :
It drives me crazy, I must say... thanks again for any advice.
Olivier
And, it will continue to do so until you quit using Strings. There is NOTHING that the String class does that can't be done with strings, except piss away resources like you have a terrabyte of memory.
So... you mean String class must not be used ?!
I agree, it looks like it doesn't work indeed... as it looks like I am faced with kind of heisenbugs :frowning:
If I have to use char[], I can of course, but is there any code to help ? If String class is so buggy, I imagine somebody may have done his own library ? I will have a look on google... and add any relevant code here, if I find any.
Olivier
