Hi, I'm new and doing a college project and it is a vending machine. I have 4 servos and 4 push buttons. When a specific button is pressed, a specific motor will turn clockwise. I've wrote out the code and tested it multiple times and had work but when I tested it again today, it somehow stopped working. I've tested each motor individually and bought another set of buttons. Hope someone here could help or give advice. Thank You.
#include <Servo.h>
Servo myservoA; //Servo pin A
Servo myservoB; //Servo pin B
Servo myservoC; //Servo pin C
Servo myservoD; //Servo pin D
const int buttonPinA = 8;
const int buttonPinB = 10;
const int buttonPinC = 9;
const int buttonPinD = 11;
int buttonStateA = 0;
int buttonStateB = 0;
int buttonStateC = 0;
int buttonStateD = 0;
//LCD DEDICATED PROGRAM STARTS HERE:-
#define RST A0
#define CE A1
#define DC A2
#define DIN A3
#define CLK A4
static const byte ASCII[][5] =
{0x00, 0x00, 0x00, 0x00, 0x00} // 20
,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e �
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f →
void LcdWriteString(char *characters)
while(*characters) LcdWriteCharacter(*characters++);
void LcdWriteCharacter(char character)
for(int i=0; i<5; i++) LcdWriteData(ASCII[character - 0x20][i]);
LcdWriteData(0x00);
void LcdWriteData(byte dat)
digitalWrite(DC, HIGH); //DC pin is low for commands
digitalWrite(CE, LOW);
shiftOut(DIN, CLK, MSBFIRST, dat); //transmit serial data
digitalWrite(CE, HIGH);
void LcdXY(int x, int y)
LcdWriteCmd(0x80 | x); // Column.
LcdWriteCmd(0x40 | y); // Row.
void LcdWriteCmd(byte cmd)
digitalWrite(DC, LOW); //DC pin is low for commands
shiftOut(DIN, CLK, MSBFIRST, cmd); //transmit serial data
//LCD DEDICATED PROGRAM ENDS HERE:-
pinMode(buttonPinA, INPUT);
pinMode(buttonPinB, INPUT);
pinMode(buttonPinC, INPUT);
pinMode(buttonPinD, INPUT);
pinMode(RST, OUTPUT);
pinMode(CE, OUTPUT);
pinMode(DC, OUTPUT);
pinMode(DIN, OUTPUT);
pinMode(CLK, OUTPUT);
digitalWrite(RST, LOW);
digitalWrite(RST, HIGH);
LcdWriteCmd(0x21); // LCD extended commands
LcdWriteCmd(0xB1); // set LCD Vop (contrast)
LcdWriteCmd(0x04); // set temp coefficent
LcdWriteCmd(0x12); // LCD bias mode 1:40
LcdWriteCmd(0x20); // LCD basic commands
LcdWriteCmd(0x0C); // LCD normal video
for(int i=0; i<504; i++) LcdWriteData(0x00); // clear LCD
LcdXY(20,2);
LcdWriteString("Welcome");
delay(5000);
LcdWriteData(0x00);
LcdXY(20,2);
LcdWriteString("Please");
LcdXY(05,3);
LcdWriteString("Insert Token");
//-------------------------SERVO A-------------------------
myservoA.attach(4);
buttonStateA = digitalRead(buttonPinA);
if (buttonStateA == HIGH)
myservoA.writeMicroseconds(1000);
delay(18.5);
else (buttonStateA == LOW);
myservoA.writeMicroseconds(1500);
//-------------------------SERVO B-------------------------
myservoB.attach(6);
buttonStateB = digitalRead(buttonPinB);
if (buttonStateB == HIGH)
myservoB.writeMicroseconds(1000);
delay(18.5);
else (buttonStateB == LOW);
myservoB.writeMicroseconds(1500);
//-------------------------SERVO C-------------------------
myservoC.attach(5);
buttonStateC = digitalRead(buttonPinC);
if (buttonStateC == HIGH)
myservoC.writeMicroseconds(1000);
delay(18.5);
else (buttonStateC == LOW);
myservoC.writeMicroseconds(1500);
//-------------------------SERVO D-------------------------
myservoD.attach(7);
buttonStateD = digitalRead(buttonPinD);
if (buttonStateD == HIGH)
myservoD.writeMicroseconds(1000);
delay(18.5);
else (buttonStateD == LOW);
myservoD.writeMicroseconds(1500);
