Does anyone have suggestions for where I might find an arduino compatible low temperature probe? Or if no, is there somewhere else I should try asking this question? Another forum?
I want to monitor a freezer that should stay at -80 C. But am thinking maybe I should have some wiggle room in the downward direction.
That is an interesting question. But, I suppose you have researched Google, already and discovered your only sensor for that low a temperature is to use a silicon diode. I found several discussions and circuit descriptions. I bet you found the same.
Paul_KD7HB:
Paul
PT-100 probe - 196 C to + 150 C
Thermocouples works fine at low temperatures a well.
