how about a solar attic fan (or some passive venting) so that you are not creating positive pressure inside your attic space
First off, I found out that my little AC unit isn't suppose to have the exhaust run vertically; I also found that you can't have the hose bent much when it is run horizontally (the proper position) - doing either will cause the compressor to overheat and the unit shuts down.
Even running vertically, though - there's no way positive pressure is being developed; we have eave vents in three different areas (one is right over my shop), plus two turbine vents that we had installed last year when we added insulation to our attic.
you could also install a radiant barrier and/or better insulation while you are up there.
Well - its a thought, but it ain't happenin' during the summer; a couple of weekends ago I was outside on the roof, cleaning the gutters (prep work for monsoon season), and I almost passed out up there; a couple of times I thought I burnt my hands/legs. Hot doesn't begin to describe Phoenix right now; there is no way I would be able to last in the attic.
For instance, right now (11:53 PM AZ MTN) outside it is 102 degrees F, with 20% humidity. At night. Nice, huh? It probably won't drop below 90-95 F tonight...
One thing I didn't have done when they did the insulation (and we got new doors and windows installed), was any work on my shop; so I still have little insulation above it, and single pane windows. I didn't do the insulation because blown-in makes a mess like you wouldn't believe, and I have a ton of electronics and junk in my shop (not to mention my servers); I didn't have the windows re-done at the time simply because it wasn't a lived-in part of the house, plus the shop was very cluttered and impossible to get around (we had to move a lot of stuff around and out of the way to let the contractor work to install what we did put in).
I tried an experiment tonight; blocking off the gap like I did before (which failed the first time), and running the hose of the AC unit out the bottom, but propped up so that it was more level, less bent, and straight. I ran the unit for a couple of hours while I did some parts sorting; I managed to get my shop down to a temp of 90 degrees F from 95 F or so. I think either the unit is bad, or it is too small for the amount of heat in the room and contents to effectively get rid of it. The unit didn't overheat and shut down this time, though, so that was a good sign.
I think tomorrow night I will try my swamp cooler, and see if I can stand the humidity, and see how cool it gets with it; otherwise, I am trying to think up a way I can set up a larger window-shaker unit (as someone else put it), which may be able to overcome the heat issue.
