Hi
On serial monitor I have sensor reading, I need to average them, how I can do that ?
Looks like avey2 being 0 is significant here? (You didn't actually say that....)
Keep track of something like avey2previous or whatever. When avey2 goes to non-0 from 0 start a counter and start accumulating the running total. When it goes to 0 from non-0 calculate the average.
static long avey2Total = 0;
static int avey2Count = 0;
if (avey2 != 0)
avey2Total += avey2;
avey2Count++;
else if (avey2Count > 0)
int average = avey2Total / avey2Count;
Serial.print("Average = ");
Serial.println(average);
avey2Count = 0;
avey2Total = 0;
Exactly as you said: sum the data in a variable and then divide by n
Thanks, it is what I was looking for, For some reasons I don't see
Serial.print("Averagex2 = ");
Serial.println(averagex2);
I changed y by x.
Serial.print(" avx = ");
Serial.print(avx); //X , green
Serial.print(" avy = ");
Serial.print(avy); //Y black
if ((avy > 200) && (avy < 250))
Serial.print(" avx2 = ");
Serial.println(avx2);
Serial.println(0);
static long avx2Total = 0;
static int avx2Count = 0;
if (avx2 != 0)
avx2Total += avx2;
avx2Count++;
else if (avx2Count > 0)
int averagex2 = avx2Total / avx2Count;
avx2Count = 0;
avx2Total = 0;
Because you show a value of 0 for avx2 if avy is not between 200 and 250 but you don't set avx2 to 0. That removed the clue (avx2 == 0) that a run was beginning and ending.
You can merge the two 'if/else' statements into one:
avx2Total += avx2;
avx2Count++;
Serial.println(0);
avx2Count = 0;
avx2Total = 0;
Perfect, THANK YOU
I changed
//Serial.println(0);
Serial.print(0);
so serial monitor looks better
but there is the problem the " averagex2 "
is displayed for very short time, only one line, will be nice to have it displayed all the time until the value of it is changed
I tried if and while, but have an error
Uy_at_Ux__C:174:23: error: expected ')' before '!' token
while (averagex2 ! = 0) {
Uy_at_Ux__C:174:25: error: expected primary-expression before '=' token
Uy_at_Ux__C:174:28: error: expected ';' before ')' token
Uy_at_Ux__C:182:18: error: 'averagex3' was not declared in this scope
Serial.println(averagex3);
int avx3;
if ((avy > 90) && (avy < 150))
avx2Total += avx2;
avx2Count++;
Serial.print(0);
Serial.print(" Averagex2 = ");
Serial.print(averagex2);
//if ((averagex2) ! = 0) {
int averagex3 = averagex2;
avx2Count = 0;
avx2Total = 0;
Serial.print(" Averagex3 = ");
Declare these at the top of the program and then just use them in the main part of the program... at the moment they only exist within the scope of those {}.
consider a running average
// running average (leaky integration)
float avg;
const float K = 0.125;
void
loop ()
int samp = analogRead (A0);
if (0 != avg)
avg += (samp - avg) * K;
avg = samp;
Serial.println (avg, 0.01);
delay (250);
void
setup ()
Serial.begin (9600);
static int averagex2 = 0;
avx2Total += avx2;
avx2Count++;
Serial.print(0);
// If a run of more than 0 values has ended,
// calculate a new average
if (avx2Count > 0)
// Prepare for the net run
avx2Count = 0;
avx2Total = 0;
Serial.print(" . averagex3 = ");
If you always want the current average on the right, just change ".println" to ".print" in this part:
avx2Total += avx2;
avx2Count++;
