Im currently in year 10 and I'm doing the only electronics class at school and Ive being asked to make a Sine wave generator with a couple of racks of parts (things that you would find at a Jaycar, radio shack, tandy etc (depending were you guys are from)). My teacher wants me to display the waveform on a 20MHZ oscilloscope so I can't do any high frequencies. Preferably running of a 6v supply and don't know how more advanced this will make it the sine wave goes to a negative voltage.
Does anyone have any simple schematics for this project.
Hi, sounds like you just need a simple audio sinewave oscillator.
There are some simple circuits around, google. simple audio sinewave oscillator circuits
Look at the phase shift oscillator that outputs 250Hz, its simple, uses available components, will run off a 9V battery.
To get the output to go negative you will need to decouple the DC part of it, so just put a 0.47uF capacitor between the output and the oscilloscope input.
Check with your teacher to see if it will do the job.
