switch case and logical test
I'm writing a code to restore a relay based flipper with an arduino hw. I then need to test several DI at the same time to identify the following actions. In other word I read a a byte where each bit is setted by a contact and I need to do action if the bit is on.
Instead of a sequence of if statement I thought it is more practical to use the switch case instructions.
The problem I have is that in each case I need to test if a single bit is on or off inside the DI byte .
To test this idea I created the following code but it is in error where I try to compare the incoming byte with a bit mask.
Any idea to solve correctly my problem?
many thanks
// costanti
int incomingByte = 0;
int mask1 = 0x01;
int mask2 = 0x02;
int mask3 = 0x04;
int testbyte = 0;
  if (Serial.available() > 0) {
    // read the incoming byte:
    incomingByte = Serial.read();
    // say what you got:
    Serial.print("I received: ");
    Serial.println(incomingByte, HEX);
    testbyte = incomingByte;
  switch (incomingByte) {
    case ((testbyte&&mask1)>0):
      { Serial.println("caso 1 vero");
    case ((testbyte&&mask2)>0):
      { Serial.println("caso 2 vero");
    case ((testbyte&&mask3)>0):
      { Serial.println("caso 3 vero");
test_switch_case.ino (733 Bytes)
Clearly, the type of a variable named incomingByte should be long float.
int mask1 = 0x01;
int mask2 = 0x02;
int mask3 = 0x04;
int testbyte = 0;
Pissing away memory uselessly.
There is NO reason to copy incomingByte to testbyte.
Your case statement evaluates to true or false. A case value MUST be a constant.
There are times when using a switch statement is like wearing a pink tutu to a funeral. You look silly in a tutu.
An example to examine and modify to meet your needs
  if (Serial.available())
    byte inByte = Serial.parseInt();
    Serial.print("\nReceived : ");
    Serial.println(inByte);
    for (int bit = 0; bit < 8; bit++)
      Serial.print("bit : ");
      Serial.print(bit);
      if (bitRead(inByte, bit))
        Serial.println(" on");
        Serial.println(" off");
What part of the error messages do you not understand?
sketch_aug16a.ino:7:5: note: 'int testbyte' is not const
sketch_aug16a:33: error: the value of 'testbyte' is not usable in a constant expression
Each case must be a constant. Those constants are compared to the value in switch().
The switch/case statement is not a good match for your needs. Perhaps 'if' statements would work.
johnwasser:
This is what was not clear to me. I wanted to perform a computation in the case statement
many thanks
UKHeliBob:
      Serial.print(bit);
thanks for the suggestion . This is similar to my other code I tested, but I was attracted by the switch instruction. It seemed to me more elegant but unfortunately it does'nt work as I would like. Now I know.
I am a big fan of switch/case but you must use the right horse for the course. By using a for loop my code has only one if in it and you can, of course, do whatever you want if/when you find a bit set. You could even use switch/case on the bit variable to determine which code or function to execute when you find the bit set or unset.
