I'm trying to use Switch - case structure for change parts of my code from one state to another.
I'm using UDP protocol for communication with my server. Whem my server sends me a value non zero I change the variable estado for another value, in this case showed is to 1.
But for some reason that I could understand my switch-case seams not to work propely. It doesn't get in the switch after the value modification.
The output from my Serial is showed below as it is the code. Can someone help me trying to find where I'm mystaking?
17:26:04.713 -> Entrei no case wait
17:26:05.688 -> Estado: 0
17:26:05.688 -> Entrei no case wait
17:26:06.700 -> Estado: 0
17:26:06.700 -> Entrei no case wait
17:26:07.692 -> Estado: 0
17:26:07.724 -> Entrei no case wait
17:26:08.710 -> Estado: 0
17:26:08.710 -> Entrei no case wait
17:26:09.717 -> Estado: 1
17:26:10.689 -> Estado: 1
17:26:11.698 -> Estado: 1
17:26:12.693 -> Estado: 1
17:26:13.702 -> Estado: 1
17:26:14.719 -> Estado: 1
17:26:15.696 -> Estado: 1
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Wire.h>
// Defindo IPs
IPAddress ip(192,168,1,92);
IPAddress serverIP(192,168,1,2);
int localPort = 5005;
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xDD};
EthernetUDP udp; // Object used in communication protocol
// SETUP
// Your setup code here
Serial.begin(9600); // start serial
Ethernet.begin(mac, ip); // start ethernet
if (!Serial) {Serial.println("not Serial.");}
if (udp.begin(localPort)) {Serial.println("UDP Protocol initialized!");}
// Variaveis Loop
int estado;
enum estado {waitForCommand, movement, stop};
// LOOP FUNCTION
Serial.print("Estado: ");
Serial.println(estado);
float defasagem;
switch (estado) {
case 0:
Serial.println("Entrei no case wait");
int packetSize = udp.parsePacket();
char packetBuffer[packetSize];
newData(packetSize, packetBuffer);
defasagem = atof(packetBuffer);
clearBuffer(packetSize, packetBuffer);
if (defasagem > 0.00){
estado = 1;
else{
estado = 0;
case 1:
Serial.println("Entrei no case movement");
// do something with StepperMotors
estado = 1;
case 2:
Serial.println("Entrei no case stop");
// wait for continue messsage
estado = 0;
udp.beginPacket(serverIP, localPort);
udp.write("COMOK");
udp.endPacket();
// FUNCTIONS:
void newData(int packetSize, char packetBuffer[]){
if (packetSize>0){
udp.read(packetBuffer, packetSize);
udp.write("OK");
udp.endPacket();
packetBuffer[packetSize] = (char)0;
void clearBuffer(int &packetSize, char packetBuffer[]){
for(int i =0; i<packetSize; i++){
packetBuffer[i] = (char)0;
packetSize = 0;
Just complementing my question, I try to declare the estado variable only as an int and I atribute the initial value as 0, and the behaviour was the same. And for finishing I used if else statement and it works, but to the code stay more beatiful and easy to ready if I use Switch-case. So It is it.
I tryied without the enum too. And the behaviour was the same. And I have another example here where my friend used enum too, and in his case works fine. I tryed to use the same structure that he used. But somehow it didn't work.
you can't define new variables directly in the switch case unless you make a compound statement
if you compile with warnings on, you probably saw something like
warning: jump to case label
so packetSize and packetBuffer can't be there as they are in
case 0:
estado = 1;
else{
estado = 0;
you need to do
case 0:
{ // <<==== START A COMPOUND STATEMENT SO THAT THE VARIABLES ARE LOCAL TO THE STATEMENT
if (defasagem > 0.00) {
estado = 1;
else {
estado = 0;
side note :
that's not great to have the type and variable with the same name
and you should use the enum
switch (estado) {
case waitForCommand:
case movement:
case stop:
Keep calm my friend. Sorry if I didn't pay attention to your answer. And thank you very much for your effort. I change my code to the correctly one, your advice apparently wasn't doing nothing wrong in my code, but as you said can happen strange effects.
The new code is below and again thank you @PaulRB .
Also @alto777 thank you.
#include <SPI.h>
#include <Wire.h>
// Defindo IPs
// SETUP
// Variaveis Loop
int estado = 0;
// LOOP FUNCTION
float defasagem;
switch (estado) {
case 0:
char packetBuffer[packetSize+1];
newValueData(packetSize, packetBuffer);
estado = 1;
else{
estado = 0;
case 1:
sendData("MOVEOK");
delay(100);
estado = 2;
case 2:
if (defasagem == 1000.00){
Serial.println("Voltando o movimento.");
estado = 1;
else {
Serial.println("Remain stopped");
estado = 2;
sendData("COMOK");
// FUNCTIONS:
void newValueData(int packetSize, char packetBuffer[]){
if (packetSize>0){
sendData("OK");
for(int i=0; i<=packetSize; i++){
packetSize = 0;
