Switch-Case Statement & Printing to Serial Monitor
So I'm new to Arduino and experimenting with switch-case statements. I want to have a basic for loop count 3 times and print a message to the monitor. When I run the code nothing shows up on the screen. Any ideas about what I am doing wrong?
int x;
for(int x = 0; x < 0; x++);{
switch (x) {
  case 1:
    Serial.println("My name is Bob");
  case 2:
    Serial.println("Sike");
  case 3:
    Serial.println("No it's not");
  default:
Oops
The last semicolon is the only code in the for loop code block. Delete it
I did that but still nothing prints to the monitor
Please post your revised code
int x;
for(int x = 0; x < 0; x++){
switch (x) {
  case 1:
  case 2:
  case 3:
  default:
x < 0;
Will x ever be less than 0 in the for loop ?
Yeah I realized that x would never be less than zero and adjusted it but now it only prints the first string of text.
Shouldn't it theoretically keep going and print all 3 because the for loop will keep incrementing?
Once again, post your revised sketch
It would be interesting for you if you printed the value of x inside the for loop
  for (byte x = 0; x < 4; x++) {
    switch (x) {
      case 1:
      case 2:
      case 3:
      default:
void loop() {}
Ah I figured it out now thx
