Switch statement executing all cases regardless of value.....
Can someone explain to me how in the world, the following code is printing out this:
5
6
Default
1
2
3
default
Status:False
boolean setMode(int mode)
  boolean command_status = false;
  boolean result = false;
  int testint = 0;
  switch(testint){
    case 0:
      Serial.println("5");
    case 1:
      Serial.println("6");
    default:
      Serial.println("Default");
  switch (mode) {
    case 1:
      Serial.println("1");
      // command_status = sendAtCommand("AT+CWMODE=1",2000,false);
    case 2:
      Serial.println("2");
      // command_status = sendAtCommand("AT+CWMODE=2",2000,false);
    case 3:
      Serial.println("3");
      // command_status = sendAtCommand("AT+CWMODE=3",2000,false);
    default:
      Serial.println("default");
      // command_status = false;
  Serial.print("Status:");
  if(result)
    Serial.println("True");
    Serial.println("False");
  if(command_status)
    if((unsigned int)strstr(gResponse,"no change") != 0 || (unsigned int)strstr(gResponse,"OK") != 0)
      result = true;
  return result;
You need a break statement at the end of the code for each case.
Didn't you notice the pile of warning messages pointing out the possible problem?
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:19:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:20:5: note: here
     case 1:
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:21:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:22:5: note: here
     default:
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:29:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:31:5: note: here
     case 2:
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:32:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:34:5: note: here
     case 3:
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:35:21: warning: this statement may fall through [-Wimplicit-fallthrough=]
/Users/john/Documents/Arduino/sketch_jul29a/sketch_jul29a.ino:37:5: note: here
     default:
Rule of Thumb: If your sketch acts strangely, make sure the warning level is set to "All" and look at any warnings you get.
Thanks, still getting used to C++, and didn't know the break was required. I will set the warnings to all now as I didn't get that message. Thanks!
There is a language reference that shows the syntax for most of the Arduino functions.
And the cplusplus.com has a reference for C++.
