Take a search engine of your choice and ask the WWW for '26:1: error: 'Loop' does not name a type; did you mean 'loop'?' and learn how other users provide solutions.
Tinkercad Arduino simulator
really no one can point me in the right direction
As I said, that error message was not caused by the sketch that you posted, or if it did then Tinkercad has bugs in it
Please copy the code that causes the error from Tinkercad into a new reply here
I'v remove one of the void loops and when i press on switch on simulator the simulated servo just wiggle and doesn't go to 40% as per sketch when i press the other simulated switch nothing happens.
#include <Servo.h>
Servo PWM; // Produces a pwm output based on servo angle
int SwitchLow = 2; // Pin designation for Switch Medium Low
int SwitchMed = 3; // Pin designation for Switch Medium Speed
int val; // variable to read the value from the analog pin
PWM.attach(9); // attaches the servo on pin 9 to the servo object
val = digitalRead(SwitchLow); // reads SwitchLow
val = map(val, 0, 1, 0, 45); // Once Switch Low pressed Arduino will output 40% duty cycle of PWM
PWM.write(val); // sets the PWM according to the scaled value
delay(15); // waits 15ms
val = digitalRead(SwitchMed); // reads SwitchMed
val = map(val, 0, 1, 0, 60); // Once Switch Med pressed Arduino will output 60% duty cycle of PWM
what does the Val, 0, 1, 0, 45 mean i understand the 45 is the angle output of pwm signal but what doe the other values mean?
Corrected negative to switch on left. now when I press either switches the simulated servo just wiggles a few degrees
That sketch compiles OK
You cannot just add a second function whose name implies that it is a loop and have it work
An Arduino sketch must have a function named setup() and a function named loop(). setup(), as its name implies, runs once and you use it to set things up. loop() repeats forever but only because there is hidden code that calls it again and again in the background
Try this sketch. I cannot guarantee that it does what you want but it does compile
#include <Servo.h>
Servo PWM; // create servo object to control a servo
If it works then study how it is put together, ie a setup() function and a loop() function
NOTE that there is more that it should contain, but we can get to that, and it could also be made much simpler
yeah i have tried that already, but both switch just produce a wiggling servo. How do i get each of the buttons to give individual function ?
OK. We have made progress. You have a sketch that compiles and does something. Now we can improve it
The problem with it at the moment is that whether or not SwitchLow is pressed the value of what is returned by digitalWrite() is written to the servo and the same for SwitchMed
One solution is only to do something when one or other of the switches is actually pressed and otherwise leave the output as it is
Try this sketch
#include <Servo.h>
pinMode(SwitchLow, INPUT_PULLUP); //set the modes for the inputs explicitly
pinMode(SwitchMed, INPUT_PULLUP); //they will both be held HIGH until pressed
if (val == LOW) //it is pressed
PWM.write(45); // output a value of 45
PWM.write(60); // output a value of 60
NOTE wire the switch inputs so that they are taken to GND when the switches are closed
Once again the sketch could be improved but let's try it first
won't compile on simulator
In function 'void loop()':
30:5: error: expected '}' at end of input
very last line!
very silly question why do i have to change the wiring of the switch its the exact way arduino tutorial says?
I would guess you did not copy the final closing } into Tinkercad
I will explain the wiring change when you have it working
needed a } below line 30 so it has compiled however the simulated servo is now wiggling as 45 degrees!
Congratulations, you just debugged and fixed the code
Did you change the wiring ?
i cannot wire two switch outputs to ground !
Why not ?
Oh, and they are inputs, not outputs
